Question about Garden
I have this plant which was blooming and everything
  • kitten Nov 11, 2014
    Hi Simba , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
When is the best time to prune rose plant
I like to prune mine after every blooming, but I live in a climate where it blooms year round. I am not sure where you live, but if you have a cold winter, prune them heavily just before the spring growth season. Depending on where you live that could be anytime between January and April. If these are older established roses. Prune them back after each blooming during the growing season. You will get a lot of flowering this way.
Oct 07, 2016 | Garden
Why doesn't my very healthy gardenia plant get any blooms?
It might be worthwhile to consult a book on gardening.
Mar 11, 2016 | Garden
The leaves on my peony plant turn very light green with darker green veins before it blooms...why?
Most likely the problem is a minor or micro nutrient deficiency. Iron and several other elements (including manganese and zinc) are essential plant nutrients. They are called micro only because they are needed by the plant in small quantities.
Fertilize with a complete fertilizer that contains micro nutrients.
Apr 29, 2015 | Televison & Video
Information about clematis plant.
Clematis is a wonderful flowering vine that is known to many
in the gardening world as the "Queen of the Climbers".
While clematis takes a few years to establish a strong root
base before it hits it\'s stride in the blooming department, it is definitely worth
the wait.
This plant climbs up to 12 feet high and spreads 3 to 4 feet
wide.
If planting more than one follow the steps below spacing the
plants 3 to 4 feet apart.
In the spring or early summer, dig a hole one foot deep and one foot wide.
Mix the soil from the hole with compost, working it until it maintains a loose
rich texture.
Ideally this should leave you with a very dark soil.
Create a mound in the bottom of the hole using the
enriched soil.
Place the plant above the mound and allow the roots to trail
over the mound.
Cover the roots and fill in the hole with the enriched
soil, keeping the crown of the plant about 2 inches below the soil level.
This plant likes shade on the bottom and sun on the top.
Water at planting and regularly for the first season,( I
prefer to water in the morning or evening and do so every other day.) after
that you should only need to water in extreme dryness and drought.
Install a piece of trellis or fencing behind the Clematis
to give it support as it grows and a foothold for climbing.
To promote blooming and keep your Clematis healthy, prune
as needed after the blooming season, and in preparation for the blooming season
prune in late March each year.
Aug 08, 2013 | Computers & Internet
Can orchids be inside?
As far as I know, orchids don't need sunlight. I've had one in my living room that is in bloom for about two weeks every year. Barely any sun light gets into the room and I don't think any hits the plant directly.
Aug 05, 2013 | Garden
Plants need advice
Try turn the pot around so it's not in full sun all day and try and avoid afternoon sun on it fertilize it regularly same as watering it
Jun 13, 2013 | Garden
Flower
Looks like a Asiatic Lily
May 28, 2013 | Home
Care of the plant: Water; location
Kalanchoes don't like to be wet all of the time; let it get a little on the dry side before watering. They love sun, as long as the heat isn't too excessive. They can be summered outdoors, and usually bloom in winter/early spring. Bring them inside before frost.
Apr 30, 2013 | Televison & Video
How and when do I cut my rose bush for the winter?
Why Prune Roses Encourage new growth and bloom Remove dead wood Improve air circulation Shape the plant Tools You'll Need By-pass Pruners Long-handled Loppers Thick Gloves (preferably long ones) Rose Pruning Basics Use clean, sharp tools Look at the overall plant, but begin pruning from the base of the plant. Prune to open the center of the plant to light and air circulation Make your cuts at a 45-degree angle, about 1/4 inch above a bud that is facing toward the outside of the plant. Make sure it is a clean cut (not ragged) Remove all broken, dead, dying or diseased wood (Any branches that look dry, shriveled or black. Cut until the inside of the cane is white.) Remove any weak or twiggy branches thinner than a pencil If cane borers are a problem in your area, seal the cut with a white glue, such as Elmer?s. Remove ****** growth below the graft. Remove any remaining foliage When to Prune Roses Timing is determined by the class of the rose plant and the zone in which it is growing. Most rose pruning is done in the spring, with the blooming of the forsythia as a signal to get moving. If you don't have forsythia, watch for when the leaf buds begin to swell on your rose plants, meaning the bumps on the canes get larger and reddish in color. Hybrid tea roses are the most particular about pruning. If you don't know what type of rose you have, watch the plant for a season. If it blooms on the new growth it sends out that growing season, prune while dormant or just about to break dormancy, as stated above. If it blooms early, on last year's canes, don't prune until after flowering.
Jun 09, 2011 | Garden
Algae bloom
Get some talapia fish...they eat algae...or net it out.
Jun 05, 2009 | RTO Pond Barley Straw Pellets 10 Lb
Garden Logo
548 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
