Question about Panasonic Car Audio & Video
I need to decode the radio in a Ford Escape I bought recently. The radio is a Panasonic Model CQ.JC179AA.
Model CQ-JC179AA
  • Panasonic Master
  • 5,480 Answers
Take to a car audio specialist, they can take the radio out and read the code!
Posted on Nov 11, 2014
Testimonial: "Not correct! The code is NOT there…only the model number! It's not as simple as you try to make it look!"
  • 3 more comments
  •  Mikey
    Mikey Nov 12, 2014
    Your right! As I said you have to have the code read by removing the radio and plugging the memory chip into a computer and reading the code programmed into the radio from new! If it was easy I would have told you to remove the radio and read the code yourself!
  •  Mikey
    Mikey Nov 12, 2014
    If the code was on the radio this would not be much of a theft deterrent!
  •  Mikey
    Mikey Nov 12, 2014
    If your car audio specialist just took your radio out to look on it to find the code I would look elsewhere for a proper car audio specialist!
  •  Mikey
    Mikey Nov 12, 2014
    By taking your radio to a proper car audio specialist they would know what is involved in reading the radio code and will show you how to input the code once read!
  •  Mikey
    Mikey Nov 14, 2014
    If you could post the name and address of the car audio specialist you used so that others do not get conned by their bad service!
murdozzz2
  • 75 Answers
SOURCE: panasonic cq-c1323nw reset button
hi there type your model number into this link and you can download the user manuall, i've tried it for your model no and it works.
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
Posted on May 02, 2008
  • 4 Answers
SOURCE: Question for radio panasonic CQ-Vd70001U Need Sercue Code
ok i just paid some authorized panasonic dude $40 to fix this problem, it was so simple i couldnt bare to see another person ripped out of $40..... all you do is power up the unit so it comes up to the code screen, then the $40 fix is, hold down the toggle button on the bottom right side till it resets takes 10-15 seconds..... YAY!!!
Posted on Sep 06, 2008
SOURCE: CQ RDP162N
i can get a general wiring diagram for now need to look into it sum more
Typical Head Unit Wire Harness Function Typical Wire Colors Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Posted on Dec 31, 2008
  • 2318 Answers
SOURCE: panasonic cq-dpx152u wiring diagram
Click here to download the user's guide and go to page # 28 for the wiring connections.
Posted on Mar 11, 2009
  • 28 Answers
SOURCE: How to remove Panasonic cq-c1301u unit from car
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Posted on Mar 25, 2009
I need the code radio for PANASONIC CQ-JC179AA PART NO EV45 66ARO B SERIAL NO R31017
this site does not have radio security codes well because they are secure. You can buy access at this site for a small fee. www.radio-codes.com
Sep 22, 2016 | 2002 Ford Escape
What is the ford escape 2006 car radio code, panasonic serial number 6HAGAG012916
Sorry I don't have an exact answer, but I suggest a call to the local Ford dealer could either give it to them, or direct where to go to get it
Apr 11, 2015 | 2006 Ford Escape
I need to a code to unlock my car (Ford Escape) radio - a Panasonic Model VQ-JC 179AA.
on some panasonic radios, this works;
hold the track button to the right for 10 sec and it will enter the code for you
Nov 11, 2014 | Panasonic Car Audio & Video
Panasonic cq-c8303u wiring diagram
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
Louie12ie@hotmail.com Hi there. I just recently bought a PANASONIC CQ-C1323NW for my car 2nd hand of my cousin and for some reason it just doesnt seem to save any of the settings a apply to it eg radio...
There are two battery supplies to your radio.
The main one via the Ignition Switch
The permanent one to feed + retain the memory...so this one is missing
Check the wiring, connectors + fuse
Aug 31, 2010 | Panasonic Car radio CD CQ-C1110GN CD...
NEED HELP GETTING THE UNLOCK CODE FOR THE
 POST ANOTHER QUESTION
quoting  ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
Otherwise try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Oct 17, 2009 | Panasonic Car Audio & Video
E1 Error on Panasonic CQ-C1110W Car CD Player
If you receive an error reading or the cd ejects automatically briefly after being inserted, the headunit needs to be repaired or replaced
Jul 01, 2008 | Panasonic CQ-VD7001U Car DVD Player
Panasonic cq-c1323nw reset button
May 02, 2008 | Panasonic Car radio CD CQ-C1110GN CD...
Car Audio & Video Logo
89 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
