NO POWER PROBLEM , WHERE DO I START LOOKING FOR PROBLEM ?
TV IS DEAD.AFTER LIGHTS FLICKERED OFF, THEN BACK ON, TV NEVER TURNED BACK ON .TRYED UNPLUGGING FOR TEN MINUTS. CHANGED POWER CORD .STILL NO POWER NO LIGHT.
    Genius:
  • 1,342 Answers
Are you sure the wall outlet still works?
Posted on Nov 12, 2014
SOURCE: new Sceptre 37" LCD TV does not turn on
normally the a-v cables are color coded the white goes with white the red goes with red and yellow goes with the yellow and when putting it in the dvd player if applicable it should be the same way did your tv come with a manual showing you how to hook it up
Posted on Aug 09, 2007
  • 2336 Answers
SOURCE: totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
Posted on Dec 03, 2008
SOURCE: Blinking green power light
All,
I had the same issue after one month of use. A repair cie came and fixed the problem. It appenned to a neon connector that wasn't properly plugged in the TV.
The Technician explained to me that m TV had 16 neons and a sort of controler for those. Often - from factory - a cable is not sitting properly in its position...
Since I have no problem.
Posted on Mar 03, 2009
freetek
  • 5568 Answers
SOURCE: No power on Westinghouse LTV-46w1 Television
This kind of failure is very common; that is why I suggest that one should keep the old CRT TV, buy a converter and put them both in the garage or basement so they are handy when our s*e*x*y new sets go belly up.
With fair confidence I can say that the main power supply has failed.
If you want to try this on your own, it only will require the removal of a few screws and a flashlight.
- Unplug the set overnight. - Remove the rear housing  - Use some logic and these tips; look for a separate board with larger than average parts on it and seems closer to the power cord than others. This will be the power supply.
Check the board over for something that looks like a part number and record it. If you find more than one, one of them will be the bare board number, the second (sometimes on a sticker instead of printed directly on the board) should be the part number for the assembly.
Search for the Westinghouse service company nearest you and call them with this info. Ask if they repair these or just sell new ones. If it is the latter, don't pitch the old one, continue to look for a repair service that will take it on after you have the new one in place and can watch your favorites again. The new supply will likely cost between $90 - $150 and with a little common sense, most anyone can remove and replace these in the set. Expect any repair to cost about the same as a new supply; US technical labor costs more than Chinese assembly labor.
These supplies can be as reliable as the primitive older type but companies refuse to use the high-grade components necessary to give them a long life so they fail much sooner than the old, less efficient kind known as 'linear' supplies.
Posted on Mar 22, 2009
budmrtn
  • 11361 Answers
SOURCE: My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Posted on Oct 24, 2009
2004 chrysler pacifica no power even after jump
check for a bad connection like a bad ground at the battery, make sure both terminals are tight at the battery, the starter and the ground at the engine. the shop that installed the EGR should have erased the codes, after 50 to 100 miles you would be able to go through emissions.
Sep 01, 2012 | Chrysler Pacifica Cars & Trucks
Power flickered during thunderstorm, TV wont come back on. heard little pop from tv when lights flickered.
Unplug it and take the back off. Look too see if the fuse right next to the power cord is black. Replace it. If it pops again, you have damaged the board and need a repair guy. Look for any burnt parts before replacing the fuse.
Jun 16, 2011 | Panasonic CT-32D12D 32" TV
Power went out i tryed to turn the xbox360 back on it didnt work
Take the Hard drive off, unplug the power wire from the wall, and plug it in to a different outlet, make sure the RCA (red,white,yellow)cables are still connected from Xbox to TV(or this will give red lights when turned on) and with that done, turn the unit on. Are the lights gone?
Jul 15, 2010 | Microsoft Xbox 360 Console
Used to flicker, now dead
You possibly need to replace either the Main board, or the power board, they both can be purchased online, and you can either install yourself or go to a site like Onforce.com and accept bids.
Sep 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I own a pioneer projection monitor model SD-532HD5. It has been flickering on and off where it goes from its crisp color to a hazy type picture. Yesterday, it flickered and the picture went away...
This TV is known for bad solder joints on the Power board. Call a good TV Tech and have him resolder the Power board. It is on the right hand side of the TV looking from the back.
Jul 30, 2009 | Televison & Video
Red power light is unlit, TV is unresponsive
This has most probably blown an internal fuse in the power supply. Most have a surge protection type fuse. It is best to have a repair engineer have a look at it as the fuses are specially rated for safety.
Mar 28, 2009 | LG 42PC5DC 42 in. Plasma HDTV
MY MX5 MR1 1991 MODEL , SLOWLY LOST POWER WHILST DRIVING!!!
It sounds like your alternator.Have it checked most places will do this for free.
Nov 19, 2008 | 1991 Mazda MX-5
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
