Question about Fargo DTC300 Monochrome Card Printer
HI I HAVE A FARGO DTC300 AND WHEN IT PRINTS OUT THE CARDS IT HAS MAJOR DRAG LINES DIRECTLY THROUGH THE CENTER OF THE IMAGES... IS THERE ANYWAY TO ELEMINATE THIS ISSUE WITHOUT HAVING TO COMPLETELY REPL
HI I HAVE A FARGO DTC300 AND WHEN IT PRINTS OUT THE CARDS IT HAS MAJOR DRAG LINES DIRECTLY THROUGH THE CENTER OF THE IMAGES... IS THERE ANYWAY TO ELEMINATE THIS ISSUE WITHOUT HAVING TO COMPLETELY REPLACE THE PRINTER HEAD?
    Scholar:
  • 59 Answers
Lines running the full width of the card when printing is virtually always traceable back to a problem with the print-head. Sometimes, it is just a dirty print-head, which is easily resolved by cleaning with supplies contained in Fargo's DTC printer cleaning kit (#086177), or equivalent. However, if cleaning does not resolve the issue, then you will very likely have to replace the print-head itself. These are not cheap and, with the age of a DTC300, it might be time to seek a replacement unit rather than sink money into a device that is well past its prime.
Posted on Nov 17, 2014
  • 63 Answers
Pls completely uninstall printer driver using printer disk, disconnect the printer, download compatible full driver from website and install it according to instruction....
Thanks,
Posted on Nov 12, 2014
4 Suggested Answers
SOURCE: bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Posted on May 05, 2008
SOURCE: Print quality with Fargo DTC500 printer
You might go to the print driver settings to change the way the printer prints the card. This can be found in the printing preferences. Go to the device options tab and choose "rotate front 180 degrees". Then print a card. This may fix the problem.
If not, try downloading the latest print driver from www.fargo.com.
Visit our id card printer technical assistance blog at www.safecardid.com/blog.
Posted on Nov 16, 2008
SOURCE: printer prints card with red on the id badge (Fargo DTC300) (xp)
Cleaned printer and new ribbon
Posted on Dec 02, 2009
I have Fargo DTC550 ID printer printing double image can someone help
Hi Arthur -
If by "double-image" you mean that you see multiple identical images printed, but each is slightly offset and appear in yellow, magenta, or cyan ink colors, then it seems like the card is slipping within the printer as it prints. These printers print 1 color at a time, with a total of 5 passes to complete 1 card image - 1 pass each for the yellow, magenta, cyan, black & clear overlay panels of a standard YMCKO ribbon. If the card doesn't get positioned properly for each new panel on the ribbon, then the subsequent image will have a slight offset to it.
The fix could be as simple as a thorough cleaning - with supplies from a Fargo dealer (like us!) that are appropriate for that model. It could also be that the printer requires a ribbon-sensor calibration. To do this, you could need to download the Fargo Workbench Utility program from the HID Global website here: (Drivers Downloads) . There is a "Printer Information" view in this utility, and then a "Test" you can run called "Ribbon Calibration" - do it regardless of the cleaning.
If still not resolved, contact us or your Fargo dealer for further support.
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Nov 17, 2017 | Fargo Office Equipment & Supplies
Anytime she goes to print a badge the ribbon breaks. It's the correct ribon. She's put in a new ribon and the same thing happens.
When the ribbon keeps breaking on fargo DTC300 or any similar models (the ones that share similar mechanics) three steps are to be taken.
1- Verify, clean, calibrate or replace the ribbon sensor (maybe you'll see an error like "Panel Searching" that means " the ribbon sensor can't read the ribbon panels normally).
2- Clean the "card path" (the feed and platen rollers) for dust dirt and debris using the manufacturer's cleaning kit (or a clean
lint-free cloth with isopropyl alcohol) and the "clean printer" option.
3- Clean the inside and outside of the printer (pay attention to the printhead) with dust-off, lint-free cloth, isipropyl alcohol and enjoy.
Or, for more advanced ts take it to a certified tech!
Mar 02, 2011 | Fargo DTC-300 Thermal Card Printer
Fargo DTC300, prints yellow and magenta, stops at cayn
is a printer thermal head dirty on same position. clean with a clean dry cloth, and special cleaner (see on manual)
Jul 15, 2010 | Fargo DTC-300 Thermal Card Printer
Fargo DTC400 is giving me "INVALID RIBBON" error
I think you or your machine have answered your own question. The machine said it isn't going to use the 300 ribbon and that is that.
I dont have experience with your particular model but I can tell you a Ford starter will not start a Chevrolet automobile.
I think you should take the 300 ribbon back and get a 400. If they wont take it back, trade somewhere else.
So, what do you say?
a
Sep 23, 2009 | Fargo DTC400 ID Card Printer Package
Edge to edge print problem
The Fargo DTC550 will not be able to print an "over the edge" card. Any Direct To Card printers will have a white line on the edges. There are several printers that are able to print covering the entire card, those printers are called Reverse Transfer or Fargo's High Definition Printers. One printer that I do recommend is the Fargo HDP5000, you can read more about it at: http://printers.idcardgroup.com/productdetails.aspx?item=hdp5000
Apr 22, 2009 | Fargo DTC550 Thermal Card Printer
Dtc300 is stuck in "replace ribbon" mode n there's nothing wrong with it.
are you using a ribbon made for the dtc300? there are some ribbons made for the other unit that look the same.
also, you might want to try updating the firmware.
Oct 26, 2008 | Fargo DTC-300 Thermal Card Printer
Sep 24, 2008 | Fargo DTC525 ID Card Printer
Fargo DTC300 Monochrome Card Printer Logo
71 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
