I have a simpson ezisensor swt802sa. i start the wash. it starts filling for about 5 seconds then stops and the wash light flashes fast then slow?
  • 94 Answers
Sounds like the pump is clogged.
Posted on Nov 11, 2014
2 Suggested Answers
  • 713 Answers
SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Posted on Jul 14, 2012
My Simpson ezi sett 7.5 always fills to full even when set to low. i have replaced the pressure switch and still fills to full.
Check the rubber hose from the pressure switch down to the bowl for any holes or splits allowing the air pressure to escape. Also check that water valve is stopping the flow. Start to fill then press pause. Water flow should stop immediately. If it keeps flowing or is slow to stop then replace the inlet valve. Try it several times to be sure.
Dec 18, 2016 | Simpson Washing Machines
My Simpson eziload 750 will not shut off the water during cycles when supposed to
Start machine as normal. After a few seconds of filling, press the pause button. Water coming in should stop immediately. If it hesitates then stops or does not stop at all you have a faulty inlet valve. Change it.
Apr 22, 2016 | Simpson Washing Machines
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Jul 14, 2012 | Simpson Washing Machines
I have a Simpson Eziset 550 washing machine and it does not fill with water at the start of a wash - instead it will start to fill then stop and all three lights on the water temp gauge light up and start...
When mine had all 3 water temp lights blinking, it was a blocked pump, I emptied the washer, tilted it back, disconnected the hose from the pump (you will need towels) and clear out the pump, then put the hose back on.
Nov 01, 2010 | Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
