Question about Garden
New holland T7050 4wd does not de engaged in the auto setting position while turning the steering wheel left or right
NEW HOLLAND T7050 4WD TRACTOR
  • 4 Answers
It may be low on lube and binding when wheels are turned keep them straight and try that - check & change the oil in the transfer case
Posted on Dec 01, 2014
  • 5 Answers
SOURCE: JD 2030 power steering failure
either the steering arm in the bell housing on the right side of the tractor is striped or the colume is broken internaly. the is asuming that all tie rod ends and the bell crank are still atatched.
Posted on Jun 25, 2009
lester482529
  • 226 Answers
SOURCE: the steering wheel on my toro lawn tractor is
no; you'll need a new steering shaft and a steric gear.( i just did this on mine) this will be your best result.as they wear @ the same time both need to be replaced.hope this helps
Posted on Jul 29, 2009
vwmike2001
  • 74 Answers
SOURCE: Soft steering 2007 Simplicity Prestige 27hp tractor.
have you checked your fluid level
Posted on Aug 15, 2009
  • 19 Answers
SOURCE: Craftsman Lawn tractor - When turning to the left
the steering rod from one wheel to the next might be bent. it bends easly ,the daves mower shop in clarksville tn. always keeps them on hand.
Posted on Jul 19, 2010
  • 6468 Answers
SOURCE: Steering problem on John Deere LT166 lawn tractor. Too much free play in the steering wheel. Also the steering shaft can be moved up and down and too either side when holding the steering wheel. This
look at the plastic coupler that holds the shaft down to the gear
Posted on Aug 30, 2012
Lost steering to left side of my new holland sl125 skid steer, what's first place to look, trouble shoot
Faulty valve in your hydraulic line or faulty motors. More likely a valve tho. Check output pressure from joystick
Aug 29, 2016 | Cars & Trucks
Center a rack and pinion from under the dash
yes you possibly can ( depends on the room available.)
I would do the centring at the top of the rack and pinion as this is where a multi spline is that will allow for correct centring.
when you get the shaft off the box
firstly turn the rack from lock to lock ( wheels of the ground) and position the shaft at the midpoint of the turns counted fro left to right
next with the steering wheel place it in the straight ahead position
put the shaft back on the rack and tighten up the lock bolt
May 13, 2015 | 2003 Nissan Altima
What is wrong with my ignition,when I put the key in it won't turn ?
I have seen this on many vehicles. It is entirely possible that when you last parked and shut it off you had the steering wheel turned to the left or right rather than centered straight ahead. The power steering was assisting with holding it in that position until you shut it off. At that time power assist stopped and the wheel is resting firmly against the theft lock mechanism. Grasp the steering wheel firmly and if your front wheels are pointed to the left then force the steering wheel to the left a bit more and turn the key will holding the wheel, if front wheels are to the pointing to the right then force the steering wheel to the right and turn the key. Try NOT to turn off the ignition with the wheels not pointed straight.
Jun 18, 2014 | 1A Auto Parts Vehicle Parts & Accessories
How can I download a new holland L175 Skid Steer owners manuals?
New Holland might be able to supply a manual.
May 14, 2014 | Garden
I have a 2007 Hyundai Sonata...my steering wheel will not lock after turning off the ignition...however..the ignition is not stuck and I am able to insert my key and start the ignition
I have noticed this problem on various different vehicles...after you turn the car off and pull the key out, physically force the wheel to the right or left really hard...the wheel will lock. It just happens to not be in the correct position for the locking mechanism to engage where you last left the steering wheel...to experiment with this, try turning it back on, and turning the wheel just slightly to one side or the next and repeat until you find the "spot" that it engages easily...hope that helped
Jun 09, 2012 | 2007 Hyundai Sonata 2.0
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Mar 26, 2011 | Sears Craftsman 46 in Mulching Tractor...
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Turns left sharply, barely turne right
The problem is either that there isn't enough range on the steering gear in the right direction, enough length on the steering drive rod (going to one front wheel), or a bent tierod (connecting the 2 front wheels) or worn tierod bushings.
Most likely is the tierod. I do not like how these are designed so for my own tractors I make one using tierod ends available from tractor supply company, grade 8 bolts and steel tube with a 3/4" inside diameter. A bit of measuring and welding later the steering is better than new.
May 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Key stuck in ignition and cannot get key out
try turning the steering wheel off it's lock. The wheel should turn a tiny bit between stops and if you turn it to the middle it should release the key. If this doesn't wrok mae sure that the transmission gear shift is fully engaged in Park (assuming an automatic transmission)
Feb 25, 2009 | 1997 Saturn SL
Key will not turn
This is a very simple and inexpensive fix. If you look at your steering wheel on the underneath right side of your ignition you will see a small hole small enough for the tip of a pen to fit in. Place a harder object into that hole and push up. This will release the whole ignition from the console. Go to an auto body parts store ( i.e. Auto zone, Napa) and get a new one. This new one will come with a new key also and your old key will not work. Replace the ignition switch into the same whole and make sure you hear it click into place. Then turn your ignition with your new key and your car should start.
Oct 19, 2008 | 2002 Chrysler Town & Country
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
