Question about Refrigerators
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not that cold either. I hear a constant noise. Not a loud one just a slight humming but never a fan running. What is the problem? A fan? Which one?
  • 1,171 Answers
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Posted on Nov 11, 2014
3 Suggested Answers
SOURCE: kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Posted on Feb 01, 2009
  • 1122 Answers
SOURCE: Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Posted on Mar 16, 2009
My refrigerator is not cooling on the refrigerator side
There are so many things that can make your fresh food side not cool. Usually, it is a frosted up evaporator, which is blocking the air flow of cold from coming from the freezer to the fresh food section. This can be caused by a bad defrost timer, a bad defrost thermostat, a bad defrost heater, or a bad control board. It could be a week compressor that is only strong enough to cool the freezer, the evaporator fan may be bad, which blows the cold air from the freezer to the fresh food section, the damper control going from the freezer to the fresh food section, can be stuck in the closed position, or in rare cases, the light in the fresh food section can be staying on, or even the condenser fan that is responsible for keeping the compressor and condenser from getting to hot, may be bad. This is usually behind the bottom of the fridge. You might also have a dirty condenser, which is the coil that is usually underneath the fridge. So you are most likely going to have to call for service.
Jan 29, 2015 | Refrigerators
What should the temp be for freezer and refrigerator?
dont know model, do know temps. The fridges highest temp is 5deg c, preferably between 1 and 4, if freezer goes above minus(-)18deg c your are in danger zone, there should be a regulator control in the fridge, usually on left or right hand side near front(door)
Jan 25, 2012 | Kenmore Refrigerators
Have a Kenmore side by side model#363.58062893 the freezer side is cooling and making ice but the refrig. side is not cooling there is some cool air but not enough to keep food cool enough. Traci
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Kenmore Refrigerators
MY FREEZER WORKS BUT NOT MY FRIDGE WHAT CAN i DO?
Good day,
There was a time when most Kenmore refrigerators were produced by whirlpool, but no more. A model number would help. So the answers are generic.
1. The defrost system failed. Tell-tail signs included frost building up on rear panel of freezer comportment. The system is made up of three parts, and is the most common cause for your problem.
Look here for an idea on how the system functions..
http://www.appliance411.com/faq/howdefrostworks.shtml
2. The fan motor in the freezer compartment failed, not discharging cold air to the fridge compartment. You should be able to hear the fan running, when you open the freezer door.
3. Lights not going out when the fresh food compartment door is closed.
4. On some versions, if the freezer control is set too old, it will deny the fresh food compartment enough air to cool.
5. On other styles the control for the fresh food compartment is pneumatic (opens and closes to allow more or less air in as needed). This control can fail shut, not allowing any cold air to enter the fresh food compartment.
Nov 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The fridge and freezer stopped cooling. we defrosted it. There was frost in the freezer. Before that the ice on the door had stopped and now it works too.
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signaled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bought a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore elite refrigerator. both compartments (bottom freezer and top refrigerator)are not keeping with the temperature setting. the food is cool but not cold as it should be. how can I test to see if...
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Nov 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
