I have a Panasonic tv with omnivision vhs and fm radio, but no manual & no remote, I've plugged in cable tv and it works but l need to know how to run an auto channel setup and add and remove channels without the remote.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
To do anything further, you should ave a remote control. There is no menu button to this TV at its front panel. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Posted on Nov 11, 2014
dodgecharger
  • 254 Answers
SOURCE: Lost the remote, manually need to access Menu button
VCRs since the early '90s have limited function with the machine located controls, and a remote is necessary to get into most setup options, probably including the channel add/delete. Many VCRs do have an auto program mode which searches for active channels, but I'd guess this also is activated via remote. A universal remote which specifically has the capability of performing the advanced functions is probably available. Look here for an exact http://www.electronicadventure.us/panasonic.htm Part number is VSQS1418 according to this site for PV4501.
Posted on Aug 28, 2007
SOURCE: Need an Instruction Manual for a Hitachi Video Deck Model #VTM181A(R)
any universal remote will do.
hit menu on the remote and go into setup.
next make sure it is set on catv1
then select catv1 and auto program
fallow the promts
Posted on Dec 13, 2007
pgh_pa_guy
  • 2992 Answers
SOURCE: LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
Posted on May 26, 2009
joez47
  • 61 Answers
SOURCE: I can't manually setup the Channels on my Panasonic PV 9451 VCR
In the Menu go to manual channel set-up not auto. When you're in manual set-up change channels until you get to to L-1 and L-2 (should be below Ch 2) and save both to memory. On some TV's the L-1 and L-2 are selected with a separate button labeled "input".
Posted on Aug 29, 2009
SOURCE: CABLE
The only way would be a scart lead from the cable box into av2 on the vcr
Posted on Oct 27, 2009
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
Having trouble hooking old VCR up to new LG TV and Integra Receiver. Feel like I'm missing a step...
Look at the back of the tv. What is it labeled at where you plugged the VCR into. Should probably say composite in. After that's verified, go into the tv menu and make sure you have selected composite input. Should be no need for any settings on VCR, it has to be settings on tv
Jan 11, 2013 | Panasonic Omnivision PV-7401 4 Head VHS...
Have a Hitachi Video Brain CLU-570PR. When I try to record vhs to a panasonic omnivision vhs, it records picture perfectly but NO sound. On an older TV I had to move the TV/VTR button to VTR to record,...
Hi, did the remote come with a manual?if it does,that means you will see the user's guide for the remote about the instruction and the different functions it has.
Also i guess the remote is not a universal remote or the reote is not the exact one for your system.It might not work properly with it...All buttons will not function properly..
Check those and get back to me..
May 05, 2011 | Televison & Video
FROM : ROD MYERS MYCO@SBCGLOBAL.NET I NEED TO RUN THE CABLE INPUT THROUGH THE VCR AND THEN TO THE TV. PROBLEM IS I DON'T KNOW HOW TO PROGRAM TV CHANNELS INTO THE PANASONIC VCR. IT CURRENTLY GOES TO CH 2, 3...
If you have the remote for the unit, with the incoming cable connected to the unit, on the remote, press menu/set up button, once in channel set up, select auto search...it may take a couple minutes for all the channels to be found...once complete, select done/exit, or press the menu/set up button again to exit.
any questions, let me know.
clarkco
Apr 29, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I lost my remote control for my tv/vhs panasonic omnivision
how do you access the menu without the remote panasonic omnivision tv vcr combo
Mar 31, 2009 | Panasonic PV-C2010 20 in. TV/VCR Combo
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
Panasonic Logo Constantly Across Screen
With the Power On, hold down the Play/Repeat On button for 5 seconds. This will toggle the 'feature' on and off.
Nov 06, 2007 | Panasonic PVQ-M2509 Combo
Televison & Video Logo
801 people viewed this question
Top Televison & Video Experts
Electro Med Services...
