Question about Vehicle Parts & Accessories
I have a 2006 cobalt 2.4 and I have some milky white substance on my dipstick. I'm also getting a knock at idle but only after 15 mins of hwy. Is this most likely a head gasket in need of replacement?
The car sounds and runs normal at hwy speed and cold start up. I drive 15 mins to work every day and I live right off the hwy so my car sees mainly 70mph travel.
    Genius:
  • Vehicle Part... Master
  • 2,494 Answers
Sounds like head gasket, (water in the oil).
Posted on Feb 09, 2015
    Problem Solver:
  • 15 Answers
Sad786 is right as it seems to be water in the oil, so PLEASE DON"T DRIVE CAR. The water will ruin the motor and it will need a rebuild. Get the leak (gasket or crack) fixed and flush all the contaminated oil out before driving anymore.
Posted on Nov 13, 2014
    Problem Solver:
  • 22 Answers
It is water mixing in oil, check if radiator has bubble and if it throws water when you start. If yes then its gasket if not than its cracks in any cylinder. hope its gasket...
regards
Asad
Posted on Nov 11, 2014
I HAVE THIS 2005 CHRYSLER PACIFIC HAD TRANSMISSION FLUSH AFTER DRIVING IT ..IT OVERHEAT NOW WHITE MILKY SUBSTANCE IN COOLANT RESAVOIR WHY ??
You need to check the oil and see if the dipstick shows overfill on oil or if you see the white milky substance on the dipstick you may have a blown intake gasket or head gaskets. I would think it sounds like a blown head gasket. Hope this helps.
If you are adding water to the system you have a problem somewhere you might want to run a compression check on the cylinders to see if you have a intake gasket leak or a head leak. How hot did the car get because you might have cracked a head. If you don't see the water in the oil it may be exhausting out the tail pipe.
Sep 14, 2015 | Chrysler Cars & Trucks
Can the sudden acceleration and white smoke emission be due to water in the gasoil.
White smoke usually does mean water is getting into the combustion chamber, and often the result of a blown head gasket or cracked head/block. Water in the oil will look like a milky substance on the dipstick, and again usually means blown head gasket or worse. Sudden acceleration does not fit with this pattern, however. Please provide more detail as to when this occurs.
Dec 19, 2014 | 2006 Hyundai Trajet 2.0
I was told there was a milky film around my oil cap he thought it could be a blown casket
Sometimes condensation will build up on your oil cap...So a milky substance on your cap doesn't necessarily mean you have a blown head gasket. Check your dipstick to see if it looks like chocolate milk. If it does, then you might have a cracked block or head gasket issue.
Feb 11, 2014 | 2006 GMC Canyon
White milky substance in oil resevoir
no that is cause dby oil and coolant mixing together
Apr 29, 2010 | 2002 Mitsubishi Lancer
2005 chev cobalt sputters at idle. Replaced knock
well i have got quite a few bad parts from autozone they just dnt make them like they used to hahah.....i say take that 1 back nd get another 1 if it still doing this then u can msg me at countryboy199026@yahoo.com
Mar 22, 2010 | 2006 Chevrolet Cobalt
I have a 2000 daewoo that lost power going up a hill and smoke started coming out of the tail pipe any suggestions on what the problem could be?
Head gasket failure is probable cause. Did engine get hot? Can you see milky substance on the dipstick? Is there a milky substance in the radio fill tank? All indicators of oil mixed with coolant
Dec 18, 2009 | 2000 Daewoo Nubira
White milky substance slight engine knock
lack of service probably the cause try thicker oil or stp engine wear oil has it been stood for a while? if so recomend new oil and filter make sre you flush old oil out with cheap oil then proceed with oil change you can use oil flush too the oil should be golden once started after a week check oil again for signs of emulsification on the cap
Dec 15, 2009 | 1998 Ford F150 Regular Cab
Whiteish gunk on oil dipstick
Wankel Rotary engine guys no headers or gaskets
This milky substance does not affect engine performance or any other functions of the vehicle. During cold weather, moisture contained in blow-by gases (exhaust , oil, fuel, water vapor) is cooled by the intermediate housing wall and condenses due to difference in temperature. A chemical reaction between the moisture reacts and the engine oil in the intermediate housing will yield the milky fluid. This fluid then eventually dissipates
as the engine warms up to full operating temperature.
The milky fluid does not affect the quality of the engine oil and therefore the engine performance is not affected either. Mazda has verified that the amount of moisture in the oil is within the acceptable standard for motor oils commonly found in the market.
However, you should verify that the coolant reservoir is full and that there is no sign of engine coolant leakage.
You can also go to you Mazda dealer and ask for a new oil level gauge tube plastic insert which has been developed as a countermeasure to keep the milky substance off of the dipstick (however, the substance will still be in there- it's a cosmetic fix only).
Hope this helps
Jan 22, 2009 | 2004 Mazda RX-8
My truck blows white smoke
Hello!
There are two differnt reasons for black and white smoke coming from the tail pipe.
Black smoke means fuel runs rich (car getting to much gas). Check fuel pressure/air filter.
In some cases the white smoke means car is burning oil or transmittion fluid. Have tem checked/replaced.
If you can feel a smelly smoke it can be catalytic converter.
In a worsest scenario if car blowing white smoke it can be engine coolant is getting into an engine cylinder from a bad head gasket ,or a warped/cracked head. So you need to keep your eye on coolant level and check your engine for overheat. Also might be good to check your oil for traces of coolant (on a dipstick it would be a milky substance mixture of oil and coolant).
Good Luck
Dec 06, 2008 | 2006 Ford F-250 Super Duty
Vehicle Parts & Accessories Logo
82 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
