Question about Refrigerators
How do I operate my 1971 rv Dometic RM 36 refrigerator? It works on both gas and electric but I have never used this type of fridge and the people I bought it from said they had never used it.
    Problem Solver:
  • 12 Answers
Your refrigerator is a ammonia unit that boils the ammonia for it cool the box. It has a electric heat element inside the metal box you see when you look at the back of the unit. It is VERY important that you have the unit level in all directions before you use the unit., otherwise you will kill the cooling system.
As far as how to start the system first make sure that both the roof vent and the vent in back are clear. Turn the electric on to the unit and a light should show that the unit is on. turn the thermostat to the coldest setting. In a half a hour the freezer section should start to be cold. If not then you see if the back of the unit is heating up.
If it still cold in the back you should try operating it on gas. just follow the lighting instructions. If it heats up but still does not cool then the cooling is bad. It would be cheaper to by a new unit then fixing the old one.
Posted on Nov 11, 2014
Testimonial: "I appreciate your prompt response and will try it out later today. This is a restoration and my first one so I am hoping to be able to fix/operate (?) this unit to maintain that authenticity (1971 Teton), harvest-ish gold appliances. If I am unable to save this unit, what is a good option for this type of trailer that is also inexpensive enough to purchase for a sale? I am concerned about an electric only unit as it will not cool while traveling(?) Again, thank you so very much."
VtToolMan
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
Sea Breeze
  • 4654 Answers
SOURCE: the freezer seems to be working fine but the
If you want a service manual for a Dometic Brand click on the link below. They are good people they will help you.
http://www.gasrefrigeration.net/dometic_manuals.htm Aug 06, 2009- If I can help you let me know, I work and talk to Dometic a lot, Thanks Sea Breeze
appliancepartsse@yahoo.com
Posted on Aug 06, 2009
  • 98 Answers
SOURCE: Unit cools fine on 120V, selecting GAS CHECK light on.
Do you hear a clicking sound If not. there is a black box inside the out side door. Check the fuses in it.
Ken
Posted on Sep 25, 2009
Testimonial: "Worked!!!"
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
My 1987 dometic rm2600 works on electricity but not on gas. No light shows.
It is more then likely just a dirty orifice. The orifice is located just before the burner. It is a brass fitting that screws into the burner. It can be cleaned by removing it and soaking it in rubbing alcohol for a half hour then blowing it out. Do not poke anything through it! One cleaned try the fridge again, if this does not cure the problem then it is more then likely your thermostat that has failed. These thermostats are still available. They are a dometic dual stat and can more then likely be found on Ebay for around $100. For any other RV fridge issues please contact ArctiCold Refrigeration We keep it cold with locations accross North America we can help you with your RV fridge problems. ">
Aug 14, 2014 | Dometic Refrigerators
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
We just aquired a 1995 RV with a Silhouette
Should be a moedl number.RM -----# on fridge. Have that ready and go to: (www.dometicusa.com) . Click on customer support, then on left side you'll see Operation and installation manuals, click on that. Click refrigerators, for Caravans, motorhomes, RV's, and find your model and download PDF for copy of manual.
Jun 04, 2010 | Dometic RGE400 Top Freezer Refrigerator
Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
May 18, 2009 | Dometic RM2620 Refrigerator
Dometic rv fridge runs fine on elec, lights on gas but in one min shuts down. Dometic RV S1621 fridge runs fine with elec, when start gas operation. The burner runs for about 30 seconds then shuts off....
May 03, 2009 | Dometic RM2193 Compact Refrigerator With...
Refrigerators Logo
201 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
