Question about Microwave Ovens
Need to replace GE JE1540WW001 Microwave
Need to replace don't know the CU of this microwave can you help?
SOURCE: GE MICROWAVE FUSE REPLACEMENT
i have a galanz microwave i need to replace the fuse and i dont know wht to buy
Posted on Feb 08, 2008
MATRIX_MMX
  • 209 Answers
Dear Carluc
Right for this one, it is essential that you unplug the oven from the mains and leave it to dissipate any electrical current certainly for 6 hours. Once you have done this, you wil to get yourself a phillips head 6mm screwdiver and unfasten the screws on the back that hold the casing cover to the chassis. This will expose the enternal components, then all you simply need to do, is find the lightbulb, unclip this from the holder and then replace it with one of the same make and model. Fitting and re-assembly is as straightforward as it is taking the unit to bits.
go to http://www.google.com and type in GE Microwave lightbulb........this will get you the details about the bulb, and use the same google search to get your service sheet/ disassembly guide. Easy as 1,2,3.
Hope this works for you and please contact me here if you need further assistance in this or any other matter that is of a technical nature.
Yours sincerely
Oz
Posted on Apr 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
  • 149 Answers
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Posted on Jan 14, 2010
I need to replace my over the range GE microwave Model # JVM1330WW002 and don't know what size/capacity it is?
Get cubic foot size by multiplying height x width x depth.
Divide that by 1728. If oven is 12 x 12 x 12 then it's exactly 1 cubic ft.
If 6 x 6 x 6 then it's 1/2 cubic ft or. 50 cu ft
Nov 28, 2014 | GE Microwave Ovens
What is the Power of model GE Microwave JVM1631BJ03?
The GE JVM1631BJ03 microwave is a 1000 W unit. Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/6073/GE-Microwave-Hood-Combo-L0523009 .
I hope this helps.
Apr 25, 2013 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
Undercounter light & fan don't work
It is most likely one or two defective door switches, "common problem with this unit.
May 07, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Just wanted to know the size of the GE profile microwave model JVM1660BB005. Is it 1.5 cu ft? Looking at a new model JVM1540LNCS to replace it and want to use the same mounting hardware.
In GE microwaves, the first 2 digits of the model number are the cubic footage. 1660 is 1.6 cubic foot, 1540 is 1.5 cubic foot. Take care trying to use the existing hardware, the exact placement of hardware and upper installation screws may vary from year to year or model to model..
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No power. outlets is fine. please help. thanx GE Spacemaker® 1.7 Cu. Ft. Over-the-Range Microwave Oven Model # JVM1740DMCC
This will occur if the inverter has experienced a surge or, if the cut off fuse has blown. you can check the cut-off fuse by removing the cover. it is located near the magnetron tube. replace it if it is blown. if the fuse is ok, this will confirm inverter failure. replace the inverter in this case.
Aug 29, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
115 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
