Where can I buy a replacement lamp for a PT51HX41CE ?
    Problem Solver:
  • 16 Answers
Google the make and model and part number, it should find it for you
Posted on Nov 11, 2014
Replacement bulb/lamp availability
Google search your manufacturer make and model and the words replacement lamp. You can find reputable vendors it in the search results.
Mar 31, 2015 | Televison & Video
Fan motor is macking nosie and the lamp light on front panal is flashing
Buy a new fan and replace it.Tries websites like Partstore.com,Ebay.com to buy a new fan for the replacement.Tv should be working again,if tv still have LED "LAMP" light indication still flashing.The tv projection lamp life are over.Replace the tv projection lamp too.
Apr 03, 2011 | Mitsubishi WD-65731 65" HDTV
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
I have a sony kdf-e55a20 that cuts out picture and sound then comes back on maybee 15 seconds later. it now happens about every 5 to 10 minutes. do I have a lamp going bad or a bad lamp driver? how do I...
It is symptom of weak lamp that has been reached to end of its working hours life, replacement of lamp will solve your tv problem.
Rest of your tv is just fine including lamp driver circuit board, buy Sony original lamp and install in tv.
Lamp replacement procedure is written in user manual of tv.
Thanks.
Jan 18, 2011 | Televison & Video
Replaced bulb for a proxima c160 bulb won't strike led power button flashes red what can I do
You may have purchased an aftermarket generic lamp. The chances that the lamp is defect is about 20% with the counterfeit products....Read here for a better explanation:
http://www.fixyourdlp.com/guides/ask-proxima/sp-lamp-017/ask-proxima-sp-lamp-017-lamp-replacement-guide.php
I also suggest buying the original lamp as recommended by the above link. You may find yourself troubleshooting further for no reason simply by buying an aftermarket replacement.
Apr 26, 2010 | ASK Proxima C160 Multimedia Projector
No power
if there anre no leds lit on the top, the power supply needs to be replaced.
Jan 19, 2010 | ASK Proxima C160 Multimedia Projector
Replaced lamd power and lamp light are green for
Yes you need to replace lamp,so you buy a new lamp.
Dec 14, 2009 | Sharp Notevision PG-A10X Multimedia...
I have 42in Kdf42e2000 and it keeps cycling on and off. it stays on for 45 sec and the shuts off power light blinks for 42 times then it goes back on and the cycle starts again. Does anyone know what could...
Its symptom of weak lamp in TV, please replace lamp.
Lamp replacement procedure is easy and mentioned in instruction manual, if you need copy of manual, click Sony Support.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
You can buy replacement lamp from Sony Accessories Store under following part number..
F93087500 Lamp Block Assy XL-2400
Thanks.
Jul 09, 2009 | Sony KDF42E2000 42" HDTV
Sony 42'' kdf42we655 no picture , lamp light flashing
If the lamp light is flashing, yes you need a new lamp. Be sure to buy an original Sony lamp as the replacement lamps are garbage and are not worth the discount. Please rate this solution. Thanks!
Nov 15, 2008 | Sony KDF-42WE655 Television
LAMP REPLACE FOR PANASONIC PT-50DL54 INSTRUCTION
Pull off the panel below the screen.
Remove the two screws hold the 2nd cover from the left.
Remove one screw from the lamp module and pull it out.
Buy the lamp module. It is not worth it to try replacing the lamp. You can damage the bulb easily.
Aug 08, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
