Question about Marantz SR7008 9.2 Network Home Theater Receiver
Overheating light flashing. How do I reset
When powered on, unit shuts itself off. I have allowed cool down but does not have any effect
    Genius:
  • Marantz Master
  • 1,054 Answers
Sounds like youprobably have a short in the amp that will need to get repaired
Posted on Nov 11, 2014
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
My Denon AVR3805 shuts down during sound spikes in music. I have to keep the volume at a lower level to keep this from happening. I keep the receiver on a rack in a closet system with fans to keep it cool...
Try a hard reset first unplug all the cords from the ck and allow the unit to reset for 30min and then plug in the cords back.
I will be posting more troubleshooting steps..
Goodluck..
Apr 05, 2008 | Audio Players & Recorders
Dell dimension 370 randomly shuts down orange light flashes on pwr button
I suspect your graphics card or processor is overheating and shutting itself off to prevent damage.
Cool the unit down with additional fans, introducing cool air and exhausting warm air is key to a reliable, stable computer system.
The reason for this sudden problem is most likely because a higher resolution on the new monitor is supported, therefore making the computer work much harder than before.
Take care!
damnor01
Jun 09, 2012 | Dell Dimension Computers & Internet
Unit will not stay on
Is the fan that cools the projection high intensity bulb running? This sounds like an overheating condition, there is a temp sensor that will shut the machine down if it senses the temp is to high and poses a fire hazard or further damage to the projector.
Jan 15, 2012 | Optoma HD80 Projector
Shuts down not allowing Windows XP to start
If the Computer shuts down automatically, then the issue might usually be due to the overheating issues.
The overheating issues develop, if the Cooling Fan in the Computer is malfunctioning.
The Processors are designed to shut down automatically, if there are any overheating issues.
For such issues, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan should resolve the issue.
Hope this helps.
Jul 07, 2010 | Toshiba Satellite A105 Notebook
My ps3 starts to turn on for 1 second. Yellow light flashes, system shuts off, and red light blinks. Help?
HI, this is an emergency shut down, due to overheating. the yellow light is an indicator of a previous overheating issue that has damaged the power unit.
unplug the unit and, let it sit for 10 minutes to cool. after the cool off, plug the unit into the wall socket once more and, power up. if it continues to shut down and, flash the red light, this will confirm a major fault within the power unit. Contact Sony for the replacement of the power unit in this case.
***NOTE(If the unit begins to play normally after the cool-down period, you will need to purchase a cooling device to prevent future overheating issues).
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Infocus led diagnostic
it might be overheating. clean off the dust filters (bottom towards the front). if there's not enough airflow to cool it down, the projector will shut off to save itself from damage.
Jul 01, 2008 | InFocus LP210 Multimedia Projector
Shuts off on its own.
This can be from a number of issues. I must answer you genericaly, because I have no service information for your model type or worked on the model you have.
Common problems that cause power down for the lamp:
Failing power supply, most likely due to components that are changing spec with temperature. These are parts that have become thermo sensitive.
The lamp or its load effect is causing some over heating in the unit, or one or more of the boards themselves are overheating. This can be from a cooling problem. It is very common that maybe a cooling fan is not functioning properly. Faulty components in the power supply, or the lamp supply can also cause this effect.
A defective lamp can also cause the power supply, and or the lamp supply to go in to protection mode.
The service tech would start by replacing the power supply for the lamp, and testing the cooling fan's performance. He will also try a new lamp. If the unit still has a fault he will try the main power supply. The next step is to start replacing modules (boards) to find the one that is cauing too much current pull.
After the unit is serviced and apears to be working, the service tech should run a temperature test on the unit over a number of hours to make sure that there is no overheating. He should also run a current draw test to make sure that the set is in specs.
Jerry G.
May 13, 2008 | LG RU-52SZ51D 52" Rear Projection...
Projector indicates overheating and shut down
HI there
Is there any on scren messaes before shutting down and when shutting down - which of the LED's on the unit is flashing and what colour ?
Apr 21, 2008 | Eiki LC-X50M Projector
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Marantz SR7008 9.2 Network Home Theater Receiver Logo
195 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
