Question about Health & Beauty
Manual for Voyager TS75 Norelco steamer
Need manual. Where can I get it/
Looking For manual for norelco 885rx
Google! I imagine manuals for all consumer products are now available some where on the internet. Google Docs has the manual you are looking for as well as Norelco.
Jan 01, 2017 | Norelco Health & Beauty
Norelco 05621- need manual
Hi ellencat613,
User manuals and FAQ's for Philips Norelco products can be found at:
www.philips.com/support
You will need a model number - I couldn't find anything for 05621?
Aug 08, 2011 | Norelco Health & Beauty
Need instructions for changing Arcitec razor head
You look at Manual Norelco Arcitec Electric Shaver.
http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
And you need to Norelco Arcitec Electric Shaver replacement heads is Norelco RQ10 shaving heads.
Nov 20, 2010 | Norelco Arcitec Electric Shaver -...
How long should heads last on Norelco Arcitec razor
Norelco suggests changing the shaver heads every 12 months for best performance. If you need to buy some, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Aug 20, 2010 | Norelco Arcitec Electric Shaver -...
I have a Rotatract electric razor, HP1601. Do I need to lubricate and if so, how?. Can I still get parts, and if so, where and what?Can I get a manual somewhere. this is a very old razor that I haven't...
I have no way to get you a copy of an owner manual as this is a very old model made before Norelco begnning offering on-line user manuals.
There are some parts available for your shaver. The parts most likely to need replced are the shaver heads and the motor brushes. You will find these parts at shaveroutlet.com. See links below
http://shaveroutlet.com/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
http://shaveroutlet.com/norelco-philips-carbon-brushes-set-p-307.html
It is suggested that all shavers have the heads lubricated. Norelco makes a product for this and it is also found at shaveroutlet.com
http://shaveroutlet.com/norelco-al80-razor-lubricant-spray-p-255.html
Internal lubrication is not often needed but if your shaver is a bit noisy a 3 in one oil can be used. You will need to take off the outer case of the shaver by removing two screws on the one side and one screw on the other. Once the insides are removed, you can remove the two metal clips that hold the gear housing on. You can then remove the gears and lubricate the spindels they fit onto and oil the pinion gear.
Reassemble in reverse order
Feb 16, 2010 | Norelco Health & Beauty
Health & Beauty Logo
248 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
