Question about Refrigerators
I have a kevinator model no ktm3900wbr frezer is fine fridge is warm can u help plse
  • Refrigerators Master
  • 744 Answers
Hello Dino;
My name is Peter. I am a retired field service refrigeration technician.
I would like to help you, but there is something wrong with the model number you submitted. KTM is for window air conditioners.
Please resubmit your question with corrected model number.
Posted on Nov 11, 2014
HVACRH20
  • 237 Answers
SOURCE: Fridge/Frezer stop working
Can you tell if the compressor (black soccer ball looking thing in the rear of the unit) is running? Is it really hot? Is the little fan running near it? If the compressor isn't running it won't cool. Also check that the coil in the freezer section isn't frozen solid blocking all air flow inside the unit. The other thing is that the defrost cycle may be "stuck" so it thinks it should be defrosting (therefore not running the compressor, etc.) Lots of things to check but that info will help decide which way to go so post what you find please.
Posted on Dec 31, 2006
  • 56 Answers
SOURCE: frezer working fine but fridge not cooling
Mo, open the freezer door and look for the model tag. There should be a manufacture date on the tag. The product has a 2 year complete warranty, 5year parts and labor on the sealed system and 5-12 years parts only. The factory number is 800-222-7820 and maybe able to tell you when it was installed, They may walk you through a couple of items to tell you what was happening.
Posted on Dec 03, 2008
  • 103 Answers
SOURCE: side by side, freezer is cold, fridge is warm, freezer is iced-up
Hi: Your defrost heater ot timer is out. Hence the frost. That also clogs the airways to the fresh food compartment. If you are handy, unload the fridge (you will need a cooler or have a bbq for everybody,) I can't give you the specifics but you will need to remove the panel where the frost is, first let the frost melt off. at the bottom of the coils will be a heater tube. Usually glass with a metal coil in it. See if there is a break in the coil. If so replace it. If that is ok it is your timer. Most likely electronic and expensive. This can be anywhere. Look at a diagram of the fridge to see. Sears parts is a good site for it. Hope I helped, Jeff
Posted on Jun 01, 2009
  • 323 Answers
SOURCE: Our frezzer is working fine but the fridge isnt
the return air ducts are frozen, not allowing cool air up to the fridge
unplug unit overnight and let defrost,you can speed up the defrost time by using a blowdryer in the freezer compartment
Posted on Jan 16, 2010
heatman101
  • 43501 Answers
SOURCE: fridge section not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 05, 2010
No temp lights on fridge or frezer panel.light on in frezer not in fridge
Try cycling the power. Switch of the fridge at its isolator (or wall socket), leave for 1 minute and switch on again.
Consult your owner manual for guidance.
If still under warranty, contact your dealer.
Apr 16, 2014 | Refrigerators
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
Temp in the refrige wont stay cold. frezer is fine. model name is rs2545sh
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Samsung Refrigerators
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Jan 16, 2010 | Samsung Refrigerators
Frezer ok, fridge warm
clean coils on back or underneath the fridge and make sure the 2 controls are set right, also check that fan in freezer is blowing. If there is a fan by the compressor see that it is working
Aug 05, 2009 | Refrigerators
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Warm fridge
check the fan in the frezer and check the defrost
Nov 29, 2008 | Amana Refrigerators
Frezer working fine but fridge not cooling
Nov 21, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
