How do i fix my tv that has so many lines going through the screen that i can't even watch it. sometimes it turns off and on all by itself. samsung is not interested since it is 5 years old. cost $2,0
Have taken off the back of the tv. all capacitors look good. could it be the mother board? any help would be appreciated, thanks, steve.
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Nov 11, 2014
Testimonial: "to The Knight: thanks for the info. have been surfing the bloodspot site. huge amount of info. no luck yet, but still at it. thanks again, will keep you posted, steve."
  • The Knight
    The Knight Nov 14, 2014
    Ok Steve; Just type in "line fault to LCD TVs" at its search box, at the top right of the display window. Might help you to locate the related page easier; I assume.
markevans
  • 148 Answers
SOURCE: ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Posted on Dec 28, 2007
ser71
  • 818 Answers
SOURCE: Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Posted on Mar 05, 2008
SOURCE: Samsung LN32A330 turns itself off after 5-10 minutes of being on.
its usually the 2200 microfarad cap on the power board that stops working. its really easy to replace and its only a 5 dollar repair part. use a 2200 mF cap rated around 25 volts instead of the usual 10 volts. samsung is famous for bad caps. if the cap feels buldged than this is the problem
Posted on Mar 30, 2010
  • 117 Answers
SOURCE: tv turns on and off by itself
check batteries on the remote/or hide remote and see if it stops/if not bigger problem
Posted on Apr 20, 2010
SOURCE: Samsung 4254 Plasma keeps shutting
take the back off the tv follow the power cord it will connect to an electrical board. Look at the board carefully you will find a few capacitors look at the top of the caps they should all appear flat if you see any that are bulged or expanded then more then likely that is your problem. I just had the exact same problem with my 50 inch plasma and I fixed it. I removed the back of the tv located two swollen caps unsolder them from the board tested them with a meter and confirmed that the larger 50volt 1500 uf 105deg was indeed burnt and the smaller swollen one 35v 1500uf was still good but changed it anyhow just because it looked like it didnt have much life left.
Posted on Apr 06, 2011
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
? 9:24
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
My samsung la40a650a1fxxy is ghosting and has horizontal lines
prob a loose wire from the inventer board to the backlight,need to open andsee.should be easy fix
Mar 19, 2013 | Televison & Video
My samsung le32r41bd keeps going up in channels on it's own, I can't stop it at all. Can anyone help?
Most likely a problem with the products manual control panel on the tv. one or more of the buttons are either stuck or corrupted. Find this part and you can fix the set.
Mar 04, 2013 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Sudden rainbow vertical lines, Loud squeel. wont turn off. Whats wrong?!
good first shut off the outlet for what is looking like this with your tv connection problems with the drain tube of images giving us the inside source for capacitors in a technical lead for the electronic exchange of capacitors and diodes for your device
Sep 06, 2012 | Samsung LN46A500 46 in. TV
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
I had a repair guy come and he's like yah I'll update the chip in your 46" samsung T.V. He leaves and also breaks my Hdmi cable to my xbox, but my parents said they'd pay cause he "fixed" it and then I...
These sets have a common problem with the power supply board. bring the set to an authorized samsung repairer.2-4 capacitors are usually at fault with parts and labour usually between $100-200.
Nov 08, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung 19" LCD TV Freezes Image and Restarts Itself
I agree with Samsung. Tuner issues can be problematic. Since it's only a 19 incher, I'd just buy a new one!
Apr 11, 2017 | Samsung LN-T4665F 46 in. LCD Television
Samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Jun 16, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
