I need a manual to set up my Boston Acoustics Subsat 6 speaker system.
SOURCE: Boston Acoustics Computer Speakers no sound
This speaker system requires a digital audio input, which most older systems don't have. The sound card that was built into your Gateway can put out either a digital or analog signal depending on how you have it set. Chances are your new sound card might be able to output in digital mode as well, but you may have to turn it on manually. Try double-clicking your volume icon in your system tray, then click the "advanced" button at the bottom left. This should bring up a window that lets you adjust the treble and bass, but it should also give you an "other options" area that lets you turn on digital output. If your new card supports digital output, the option should be there. If the card does not support it, you will have to use a different card. I hope this helps.
Posted on Apr 13, 2007
  • 7 Answers
SOURCE: Boston Acoustics Digital BA735 Speakers with no Analog input.
I use one set of BA735 with two computers. Computer A sends digital out and Computer B sends analog. BA735 plays both. I listen to music using digital while the analog from the other computer alerts me to the incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced > Select Enable SPDIF. You can leave the PC Spk Mute unchecked if you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful. My ears thank a lot for replacing those desktop speakers. BA735 hardly takes up any space . Two small speakers are perched on the hutch and the bass module is somewhere behind the desk, completely invisible.
Posted on Mar 06, 2009
SOURCE: Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Posted on Jul 16, 2009
SOURCE: My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Posted on Feb 20, 2010
martin-r
  • 151 Answers
SOURCE: I have the Boston Acoustics BA745 Computer Speaker
This could be because the speakers arn't getting a stereo signal, but first, double double TRIPLE check the wires are connected correctly. Iknow it sounds patronising but I don,t know if you are 8 or 80 years old and it's often best to go for the most obvious solution. afer making sure all connections are correct, have a look at the cable to the subwoofer - is there any damage to the cable or does the cable look like it may have been pulled - out from the sub or it's connection at the other end of the cable? Having eliminated the possibility of cable damage (it may be worth cheacking the cable to the pc) check various settings on your pc - are you getting sound from your other two speakers? if you are only getting sound from one of the left/right speakers and you're sure there's no physical failure with the speakers, then it's time to check your software. go to the little speaker ikon at the bottom right corner and right click. Select "Playback devices" select "speakers" and click "test" did you hear sound coming from the left speaker then the right? if yes then you definately have a problem with the sub. if no, click "properties" then "levels" and check the balance is set to the middle. If it is, then you should, again, suspect the speakers. Finally check the balance on your media player, if you use windows media player, go to "options" click "enhancements" then look for the balance control and make sure it's in the middle.
Finally, I would like to point-out that this particular speaker system is not known for having a loud subwoofer, put your ear against the hole in it and double check for anything happning inside (a crackling noise would indicate a danaged voice-coil.
Hope this helps.
Posted on Jan 18, 2011
Where can I download the manual for Boston Acoustics MediaTheater Computer Speakers?
Have you tried Boston Acoustics web site? Google manuals and see what you get
Jun 29, 2015 | Boston Acoustics Audio Players & Recorders
Boston soundware 5.1 subwoofer is clicking on and off all the time
I dont have a solution, but Im having the same problem, and so is someone else:
http://www.avforums.com/forums/speakers/1205745-boston-acoustics-soundware-xs-5-1-review-6.html
Bad batch maybe? Lets get your input and maybe we'll get to the bottom of it.
Jul 10, 2011 | Boston Acoustics SoundWare XS 5.1 Speaker...
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
Where can i find replacement wires?
I hope that helps.
Mar 08, 2011 | Boston Acoustics MicroMedia Computer...
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
I work at a public school in Boston, someone gave me the speaker set to hook up to my macbook. Can't get it to run.
well you probably have the digital version o the Boston acoustics speakers. you mac book may have a digital out . some mac books have a setting in the speaker setup. analog to digital.
Jan 13, 2009 | Boston Acoustics BA735 Computer Speakers
Need help no sound out of speackers
Presume you mean 790 not 970, if so you can download a manual under product detail on this page.
http://www.amazon.com/Boston-Acoustics-BA790-Multimedia-Computer/dp/B00005AR7N
Check power supply is plugged in correctly and switched on at the socket, then turn or push the button usually on the right speaker to turn it on,
good luck HPC
Sep 27, 2008 | Boston Acoustics BA790 Computer Speakers
151 people viewed this question
 Grubhead
Grubhead
