Question about Hardware & Accessories
How do I fix a thermostat that appears to have lost its programming?
I have seven of these thermostats where I work. When you press the program button to make adjustments to anything, it always gives the current setting of the first of four settings for the day and allows you to make changes. However, these seven read "None" when you press the program button and doesn't allow any changes. The manual doesn't even cover this problem.
  • 5,089 Answers
Have you changed the battery?
usually the battery compartment (and the model number) on located on back of thermostat
Look up manual on internet
Gene
Water Heater Timers Save Money
Posted on Nov 17, 2014
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
tjt3
  • 44 Answers
SOURCE: Program knob on GE washing machine not functioning
Older washing machines had a 2 position knob push or pull to set and the other position to run, also if the timer is bad it can be replaced the parts are still available on the Internet.
Have a good day...
Tim
Posted on Mar 26, 2009
SOURCE: Utilitech Self-Adjusting Wall Timer- #0192773.
Here is the url to the pdf file. You can then magnify your computer screen.
http://www.thencc.com/LS/Instruction/LW60418_Instruction.pdf
Posted on May 14, 2010
SOURCE: how do I delete one
Clearing event on Utilitec 7-day timer:
Tiny print on instructions say: press PROG button several times to locate setting you want to clear > Press and hold MODE button > press PROG button to clear setting > to finish, press CLOCK button and display will show time of day.
In case of operational failure:
Tiny print on instructions say: press RESET button to clear all settings >> and then reprogram
Posted on Sep 21, 2010
SOURCE: If you keep hitting the program button after
The ST01C programming is long and hard to understand
Intermatic has posted a EZ-version for programming
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx
http://waterheatertimer.org/ST01C-program.html
First of all, you have to set current date on all brands of programmable timers before programming. On some timers, the wiring has to be correct before the timer will let you program.
If you have the ST01C, push the reset button with a paper clip until time flashes to 12:00, and then start over
When I have a problem with a timer, I go back to the manual and start writing out the instructions.
If you can write the instructions, then they usually make better sense >>> and then you wonder who wrote the manual.
Finally, the ST01C, and most digital timers, come with a 1-year limited warranty >> timers go bad.
Posted on Oct 20, 2010
Concern is about a wall thermostat
Change the battery. Most programmable thermostats have a backup battery so when power is lost the program isn't.
Nov 26, 2016 | Refrigerators
Programming the remote sensor to the 44665 hunter thermostat
Just fixed mine;
Note the sensor channel on face of remote
(ref: http://www.manualslib.com/manual/257219/Hunter-44665.html)
Mine was set on Ch15, well the thermostat only monitors 14 channels had to flick down dip switch #1 to set Ch7.
Then on the base unit thermostat, see page 5 of a similar unit for 44668/44665 manual (below) then wait about 10 minutes for things to sync up, and press remote button to check sensor temp.
Note the button order for Remote Sensor Programming at base thermostat:
http://www.hunterfan.com/SupportDocuments/OwnersManuals/44008-01Thermostat44668-44660WebR02102010.pdf
Feb 05, 2012 | Hunter Fan Company 5/1/1 Programmable...
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Dec 17, 2010 | Timex Hardware & Accessories
HAVE HONEYWELL DIGITAL NON PROGRAMMABLE TSTAT LOST POWER AND PROGRAMING NEED TO SET DEFAULTS MODEL TH5110D1022 WHERE CAN I FIND PROGRAMMING INSTRUCTIONS FOR DEFAULTS?
Use this link. At the bottom of the link is a section with downloadable literature for your thermostat. It appears all documentation related to your thermostat can be found here. I hope this helps. Good Luck in your endeavor! :-)
http://customer.honeywell.com/honeywell/ProductInfo4.aspx/TH5110D1022#LiteratureDownload
Feb 28, 2010 | Heating & Cooling
Lost program instructions freezing
Hi, on a programmable stat, you should be able to raise the temp with the arrow and then push hold temp. feature. This will hold the desired temp and get you heat unless you have a stat problem. Try this and let me know the settings.If this didn't work, make sure the stat is in the auto-heat posistion. Push program and set the time.press again and set the day of week. Repeat this step and set the desired temp for each day of the week and week-end and push run program.You should hear it click on. It takes a min. or so on heat as there is a delay. Make sure the batteries are strong as they run the program. Let me no. Best of Luck, Sincerely, Shastalaker7
Dec 04, 2009 | Honeywell Programmable Thermostat Heater
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
May 16, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat RTH230B
Sound like you need new one... take a look on amazon ecobee3 Smarter Wi Fi Thermostat Remote Sensor. It's not worth repairing it..
Jan 06, 2008 | Honeywell Programmable Thermostat Heater
Hardware & Accessories Logo
62 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
