Question about Vacuums
How do I fix the non-functioning sprayer on the Avenger AV12QX floor cleaner?
It just recently stopped spraying the solution into the carpet.
    Sergeant:
  • 311 Answers
I'll guess that the nozzle is plugged.
Posted on Nov 12, 2014
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: Bissell ProHeat Clear won't spray from floor nozzels but it does stray from hand cleaner
I agree - just got done fixing 1 of these tonight. The heater plugs up and no spray. Easy Fix, the heater is in the handle and pretty easy to remove. then a straightened paper clip and a blast of air and you should be go to go.
Posted on Apr 19, 2008
  • 14 Answers
SOURCE: Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
Posted on Mar 06, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
SOURCE: Bissell ProHeat Carpet Steam Cleaner stopped spraying.
The problem was a clogged heating unit which is located in the lower handle. There are two clear hoses going up the inside of the left leg of the lower handle that go to the heater and to the in-line water switch all within the lower handle. I unplugged the metal heating unit water lines and electrical connections (label the connections as you take them apart if you have a hard time remembering things...there were seven connection in all be it water and/or electrical). Removed the heat unit out and then removed the 6 screws holding the heater cover. Inside was a white powdery pasty debris (lime deposit ?) and the water path was clearly blocked in four different places. I cleansed the water trough with a little water and soft toothbrush and several toothpicks then reassembled. If you need new washers go to Orchard or ACE hardware. Take the old rubber washers(they are red) with you for comparison. I didn't need new washers...I just gently cleansed them. I immediately ran clear water through the machine and actually cleaned the carpet with a water rinse only. Will go back and finish the carpet the right way tomorrow. I had only used my machine three times before this happend over a three year period. A friend told me to always rinse it two maybe three times with clear water after using it and before storage. This took me exactly 42 minutes to disassembly and reassemble. Cost savings is several hundred dollars since I have a 5 bdrm house and would need a professional cleaner to do the small dirty traffic lanes all around the house.
Posted on Sep 19, 2009
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
How to prime pump in bissell carpet cleaner
Turn off and unplug unit. Remove both tanks. Fill Solution tank and install it. Fill Heat Tank and install it. Plug unit in and turn on, wait one minute and engage sprayer till spraying. Stop sprayer. Consumer Care # 1-800-237-7691 for further assistance.
Aug 06, 2015 | Bissell Vacuums
BISSELL LIFTOFF WONT SPRAY CARPET
replace the sprayer you can get one of those at guarantee vacuum and sewing center cheaper than any where else
Mar 21, 2014 | Bissell Lift-Off Deep Cleaner 94Y2
Sprayer stop working
if it stopped spraying all lines may be clogged up try taking it apart and clean each line one by one i say one at a time so you dont mix up lines i had same problem when i was fixing a friends 2 main lines were clogged with old soap if unsed for some time that soap build up a grud this should help you can us a small pipe cleaner
Nov 13, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Pump doesn't work
remove the sprayer at the end of the wand clean the tip with a needle then replace
Apr 16, 2009 | Vacuums
Oct 09, 2008 | Karcher K DS 5500 Vacuum
Bissell carpet cleaner will not spray the cleaning solution
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hgjdg
Jul 21, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Usually when the hand tool works ok, then the heater inside the handle asm. is clogged. The water bypasses the heater when you use the hand tool. Other then that it could be a bad pump.
Apr 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
