How do i test my power supply on my dell 4700
    Sergeant:
  • 320 Answers
To test any power supply there are two methods.
1. using a multi-meter. This should only be done by someone who understand which wires have voltage.
2. a dedicated power supply tester. These are much safer and easier to use. They can usually be purchased from electronics shops such as Radio shack. or online at pretty reasonable prices.
Posted on Nov 11, 2014
4 Suggested Answers
tedmacaraeg
  • 181 Answers
SOURCE: i have a dell dimension 4700, soild green light,
First to be check is your power supply. Used power supply or brand new ones, does not matter as long as it is working properly, with correct voltage and ampere rating. Check your power supply with a voltmeter. Please take note also the total watts you need.. If your power supply is running good, problems will go down the line, the Motherboard. Remove all devices (hard disk, cards, memory, etc) just the motherboard, just to see if the motherboard is working right. Your should be hearing a beep sound indicating that the board is alive. If yes, you may reinstall the rest of the devices you removed.
Posted on Sep 13, 2010
  • 998 Answers
SOURCE: I have a Dell Dimension 4700, the cooling fan runs
Sounds like it to me. Could also be motherboard, or CPU fan, or PS. I would guess PS.
Posted on Jan 05, 2011
  • 4961 Answers
SOURCE: testing dell power supply
You can test it with a psu tester like one of these:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=psu%20tester&bop=And&Order=REVIEWS&PageSize=20
Posted on Aug 19, 2012
My 2005 pc desk top crushed. called dell and diagnostics tested showed problem with either motherboards or power. my warranty expired and looking for prof to look into the problem..
If computer dont starts at all it is power supply (no signs of working at all) If there is nothing on the screen it can be power supply or motherboard. Put different power supply ( you will be 100% sure)
Oct 21, 2011 | Dell Dimension 4700 PC Desktop
The power went off on my dell dimension 4700 and i press the power button and it will not come on. What can I do?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect or boot up your hard drive
Test all leads that attach from the ((motherboard to your hard drive)) including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
don
Feb 05, 2011 | Dell Dimension 4700 PC Desktop
Hi im looking to upgrade my dell dimension 4700 graphics card. I currently am running a radeon x300. the minimum improvement im looking for is 512mb. also wondering if ill need to increase my psu as I...
Since you want to upgrade your video card to a much powerful one, you can check this out ATI Radeon HD 4670 HD4670 512MB DVI PCIe Video Card.
Doing the upgrade a power supply upgrade is also advisable since new video card like now requires a high power supply, upgrade the power supply to at least 500W and for a additional fan is already recommended to avoid any overheating problem.
Oct 02, 2010 | Dell Dimension 4700 PC Desktop
I have a dell dimension 4700, soild green light, no beeps, no picture. just bought a used power supply.
Sep 09, 2010 | Dell Dimension 4700 PC Desktop
Dell desktop 4700 problem
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
If the LED Is SOLID amber, it is likely either a component connected to the Motherboard or a bad motherboard
May 15, 2010 | Dell Dimension 4700 PC Desktop
My dimension 4700 power supply gets noisy so i blow out the fan and it quiets down. this has happened several times. is my power supply starting to go bad?
Chances are it is just the fan in the power supply that is going bad. It either has dust in it, or the bearing is just wearing out. Either way, you could open it up and replace the fan with a similarly sized fan if you are careful. Power supplies contain large capacitors that can cause injury. If your case has adequate ventilation, a dead power supply fan may not cause any overheating, but it may decrease the life of the power supply.
Jul 14, 2009 | Dell Dimension 4700 Power Supply ** FREE...
Want to upgrade power supply on Dell Dimension 4700. Bought Rocket Fish RF-550wps 550 watt powersupply to install . Unable to proceede no schematics ror placing wireing
Hi there.
Rocket Fish RF-550wps PSU is standard ATX power supply.
Dell tend to use their own power supplies which differ slightly from standard power supplies.
I suggest you take or send the Rocket Fish RF-550wps PSU back as it won't fit and order one from Dell themselves, at least then you will have a guaranteed fit.
Once you have your new power supply from Dell (or a Dell ATX power supply) it should be easy to fit in.
Post back if you need any more help.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | Dell POWER SUPPLY Power Supply
Dimension 4700 series does not power up??
make sure the power cord is plug in tight, or try another power cord.
make sure the fan at the power supply comes on. if it still doesn't power up, then you need to check the power supply with a voltmeter at the output pins.
Mar 17, 2009 | Dell Dimension 4700 PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
