Question about Kenmore Washing Machines
<!-- from fixya rte -->Error code F 11 Kenmore washer - Kenmore Washing Machines
    Problem Solver:
  • 15 Answers
Does anything on the washer works, it could be an electrical problem or a short somewhere
Posted on Nov 19, 2014
  • 96 Answers
SOURCE: F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Posted on Mar 17, 2008
JR JR
  • 116 Answers
SOURCE: kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Posted on Nov 30, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Iget a f-11 trouble code on my kenmore elite he4t washer.
REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
Posted on Feb 12, 2009
  • 11 Answers
SOURCE: washer error code is F 11. will not let me reset
There is a small cover on the front bottom of the washer. Remove it and there should be a door release rod that you can pullto unlock
Posted on Apr 27, 2009
livewire874
  • 618 Answers
SOURCE: What does F-11 error code
I believe it means motor control unit failure. Make sure nothing is plugged into same circuit unplug unit for 10 min. and try again . If it still does not work you will need a tech
Posted on Nov 20, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
How to reset an error code e43 on a frigidaire affinity front load washer
Hii Michael, Search online for "error code e43 reset". You should get a hit on justanswer.com. Follow that link, it looks promising.
Jul 11, 2015 | Frigidaire 131763202 WASHER DOOR LOCK...
What is the difference between codes 11 and F-11
It looks like error code 11 is most likely to be associated with windows. F11 on the other hand is worth searching online.
Jul 11, 2015 | Kenmore Kemore Whirlpool Sport Washer...
What might be causing the intermittent F-11 codes on a Kenmore Smartwash front loading washer?
f11 error is communication error.most likely bad solder joints in ccu or mcu.
May 08, 2017 | Kenmore Washing Machines
He 4t washer with a fault code of F 11
going to need th main board (pricy) F-11 is a door lock error code.
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
Feb 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he4t washer shows f-11 error
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
11 minutes timer flashing, machine locked
unplug washer over night. plug in try drain and spin, if it works after finish try to restart. an 11 minute stall is likely error code f / 11 or dl code starts intermittently then goes out possible ccu board under top at rear
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
