Question about Kitchen Ranges
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
    Prodigy:
    An expert who has answered 500 questions.
  • 650 Answers
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Posted on Nov 22, 2014
  • 15 Answers
SOURCE: Conversion kit from natural gas to propane
it can be connected to propane.In order to do this on the rear of the appliance ther is an energy rating plate stateing the size of the gas jets.They vary in sizes between natural,town and lpg.the reason being is the pressure in the supplies are of different values
Posted on Jul 18, 2007
  • 1894 Answers
SOURCE: Convert natural gas range to propane
just install a new valve
Posted on Jun 09, 2008
I want
  • 172 Answers
SOURCE: Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
Is there something available to convert a hardwick propane stove / oven to run on Natural gas?
Should only be a matter of changing the jets, see a gas fitter if they can be changed.
Dec 20, 2015 | Maytag Crosley Hardwick Caloric Kenmore 8"...
I have propane. Is my range set up fpr natural gas or propane and do i need to change. I'm having issues with my oven
without knowing your model number or mfg it's tough to say 4 sure but i can say that most common mfg do offer a propane conversion kit to use there gas stoves on bottle gas , most often it's a new regulator to install
Jan 08, 2015 | Kitchen Ranges
How can you tell if a 1985 wolf range burnes gas or propane? it says propane, but we bought it saying it was for gas? And how much would it cost to change out? Thanks, Mary Kaye
Most ranges are easy to convert from propane to gas or vice versa. If there is a gas regulator installed on the back gas inlet, you could see if it is running 3-6" WC or 10-12" WC, The latter is for propane. If no regulator is present the orifice sizes will need to be checked. Propane has a higher caloric value than natural gas so the orifices are smaller. One way to see would be to install the oven. If the orifices are for propane and you are using natural gas there will be too little flame. I would estimate a conversion would cost no more than $250.00 to $300.00 depending on where you are. I would hire a professional to verify. I know it is expensive but the technician will be able to check your older oven (1985) for potentially dangerous gas leaks etc while he is there.
Jun 06, 2011 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
I will soon need to convert a 1993(?) CALORIC Kitchen Range back to Natural Gas from LP. When I installed it, NG was not available, so the propane company guys converted it to LP. I was not here to learn...
First check the regulator valve on the back of the stove. Chances are it is a dual purpose valve and once you are ready to do the converstion.. you simply will move the lever or change the setting from LP to NAT.(obvisouly before proceeding you need to have the fuel supply turned off to the appliance)
Next check under the range lid or on the back of the stove for the spare NATural gas orifices.. when they changed it out for you there were two scenarios.. the range (most do) came with a set of LP orifices..and they simply changed these out on each burner supply including brolier/oven. (orifices are interchangeable nozzles that are threaded into the supply gas burner)
If they had to swap out the regulator chances are they would have given you the one that came with your stove.. However I am fairly sure the regulator is a dual purpose and you simply need to change the setting from LP to NAT.
DO NOT DO THIS WITHOUT CHANGING OUT THE ORIFICES FIRST.
If you cannot locate the spare orifices/spud/nozzles (they are called all of these) on the stove itself you will need to buy a set. A good appliance parts store will be able to help you with these.. again.. you will need one for each burner/burner supply.
If you can locate the range manual it will have instructions on how to do this.
Chances are your Natural Gas company will be able to help you with this.. especially if the regulator is dual purpose.. even if you can't find the orifices they are inexpensive.. fairly standard and easy to acquire. Usually just called a "conversion kit".. it will just consist of four or five small threaded 5/16 brass nozzles/orifices.
The installation is pretty straightforward. Again..a good appliance parts store may recommend a service company...and if your not familiar with diy repairs on a gas appliance.. a 50 to 100 dollar service call is well worth the money.
Best of luck to you!
Apr 11, 2011 | Ovens
Whirlpool model SF385PEEQ0 Gas stove was on Natural gas we have propane is there an adj or part needed as burns yellow flame!
You need to adapt your range for the propane gas. You need to change the orifices, propane needs a larger opening than natural gas. If you contact your propane company they can help you and some will even do it as a free service (or used to).
Jun 18, 2010 | Whirlpool SF325 Gas Kitchen Range
I have a Caloric Heritage Series gas stove in which the oven will not light but the broiler does work. This stove has a analog clock and we have no idea what the model is. Please help us. Thank you,...
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Dec 29, 2009 | Ovens
How to convert from natural gas to propane
All stoves in this country come from the factory with orifices designed to use natural gas. To switch over to propane, the orifices have to be changed over. Contact your propane provider and they will obtain the proper orifices for your range. They may even install them for free. good luck.
Feb 18, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Propane coversion of kenmore 790 gas range
Most gas stoves are shipped for natural gas .You need to check the orifice on each burner to see if they are for natural gas or propane.If you ordered propane the stove should have been shipped with the orifices.They may be in a bag with your stove documents.
tk46
Jul 13, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How to check to see if gas stove has been converted to propane
The only thing you can do is look for a little (usually gold) nozzle connected to the orfice
propane burns blue and natural gas has the yellow tint to it
May 01, 2008 | Ovens
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kitchen Ranges Logo
157 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
