I HAVE A Frigidaire FRONT LOAD WASHING MACHINE MODEL GLTF2940ES how many cubic ft is it
    Master:
  • 876 Answers
3.5 Cu. Ft. Capacity
Posted on Nov 12, 2014
  • 3 Answers
SOURCE: Frigidare front load washer warranty
The usual factory warrenty periord on the Frigidare Affinity washer is 1 Year from date of purchase. You can find your Model number and serial number of your washer on the inside of the door. It is on a white label towards the bottom of the dorr.
Posted on Nov 12, 2007
SOURCE: Frigidaire GLTF2940ES
Is it draining completely?
Posted on Feb 07, 2008
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
SOURCE: E10 error on Frigidaire GLTF2940ES
I searched the internet for a list of error codes for the washing machine. The E10 error code indicates an interuption in water supply among other things. We checked the supply lines and found that the screen on the cold water line had been blocked by sediment ( we have well water,and just replaced the pump).
Posted on Nov 30, 2008
  • 7 Answers
SOURCE: What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
Posted on May 27, 2009
How many cubic feet is the frigidaire FSE447GHS0 front load washing machine
Good Afternoon friend, thank you for your post!
From the information you have provided you need to know the cubic footage of your Frigidaire washer, FSE447GHS0. I have researched your model and it appears to be 4.4 cubic ft. I hope this information is helpful to some degree. -Matt
Feb 25, 2015 | Frigidaire Refrigerators
How many cubic ft. in a 2001 Frigidaire Galley model #FWT647GHS washing machine
Hello friend, that's a great question!
I understand you would like to know the cubic footage of your Frigidaire washer. Based off the model number you have provided your washer appears to be a 4.4 cubic feet washer. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Washing Machines
Capacity frigidaire fwt445ges2 load
Good Afternoon Friend,
I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
Where is the switch located on the front door of front loader washing machine
Hello Friend, that's a great question!
In order to provide you the correct location of the door switch on your Frigidaire front load washer, I will need your model number. The serial tag, which lists your model number, is typically located on the upper front, as you open the door. Thank you! - Z
Jun 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
What is the capacity of this washer
Hello Diane Swartz - If your model number to your washer is GLTF2940ES, then the capacity of the unit is 3.5 Cu. Ft. However, if that is not the correct model number, may you please provide me the correct one?
Nov 29, 2012 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire front load washer Model #GLTF2940E will not spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
The spin cycle doesn't work
heatman101
Apr 01, 2011 | Frigidaire GLTF2940ES Front Load Washer
Problem spin
heatman101
Sep 16, 2010 | Frigidaire GLTF2940ES Front Load Washer
FRIGIDAIRE WASHING MACHINE MOLDY BELLOWS
I have used www.smellywasher.com with good results
Sep 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
Nov 30, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
