Dell 4700 blinking yellow light - Computers & Internet
    Scholar:
  • 105 Answers
Its likely a failed fan. Do you hear any fans come on when booting the PC? New fans are ~$20 or less..
Posted on Nov 11, 2014
  • 3940 Answers
SOURCE: Dell 4700 desktop, will not boot up. Light remains
A solid Amber power LED is an indication of a motherboard problem. Remove any external connections and see if LED indications change. If no change, remove all PCI expansion cards, try again. If still no go, disconnect all drives, try again. If still no change, ensure the CPU heatsink is firmly attached (If loose you need to replace the retention module) If nothing loose and no changes from other steps, replace motherboard
Posted on Mar 11, 2010
eagle338
  • 4889 Answers
SOURCE: dell dimension 4700 blinking yellow light
You clearly have an SMPS(power supply issue). Not 3 days ago I worked on my dad's PC that had the same problem. I found that the board had some leaky caps, and the circuit board inside it partially burnt. I could get it working by replacing the caps, but dont know how long it will last(I'll be getting a new PC soon anyway). Its advicable you replace the power supply. Should cost you around 30-50$ at MOST!
Posted on Apr 08, 2009
SOURCE: Dell 5150c shuts down orange flashing light
As a temporary measure, taking the side panel off the dell 5150c stopped it from shutting down, so in my case it was clearly a heat problem, as suggested by previous the poster. The following instructions assume you're comfortable replacing computer hardware components - do at your own risk!
The solution is to buy an 'air duster' and some thermal compound for the CPU heat sink. If your CPU fan doesn't sound healthy (mine didn't), also buy a new one (ca. £20 on ebay: search for G9474 ).
Read the service manual: http://support.dell.com/support/edocs/systems/dim5150C/en/sm/index.htm for details on how to install / remove the fan and heat sink.
Clean out dust from the heat sink with air duster. Remove the fan, and clean or replace (recommended). Also clean the grill in front of the fan. Clean off old thermal compound from the CPU / heat sink and replace with a thin layer of fresh compound. Replace heat sink and side panel and you're done.
Posted on May 12, 2009
  • 212 Answers
SOURCE: yellow light blink when powered up
that is the hard drive. does it work? If it does I wouldn't worry about it.
Posted on May 25, 2009
Sphynkter
  • 221 Answers
SOURCE: won't turn on only blinking yellow light
The blinking yellow light on the power button is almost always a power supply failure of some kind. You should try disconnecting the PC from the wall and letting it sit for 10 minutes to let all the power in the capacitors drain. This will do a mini-reset on the power supply. Plug the power back in and then try it again. If that doesn't work, find the 110/220V red switch on the power supply, unplug the power from the wall, flip the switch a few times, make sure it lands back on 110, then connect the power and try turning it on again. If those don't work, you'll need to replace the power supply unit.
Posted on Aug 04, 2009
Fast blinking light on drive a slow blinking light on b on dell dim 4700
Yes, the HDD LED will Blink when active. "slow blinking light on b", what is b?
Dec 23, 2012 | Dell Dimension 4700 PC Desktop
Green power light comes on but disk drive lights keep blinking and my screen is black on my dell dimension 4700
Remove ALL media from the machine DVD, CD, USB, etc. Check/reseat all Monitor cables. Reboot. If that fails, unplug , plug back in in 30 seconds or so. reboot, if you get a Dell Logo, Open the boot Menu and select Boot from HDD first.
Dell 4700 blinking amber light. nothing else happens no fans no beeps.
HERE is the troubleshooting section for your PC from dell. It will give you at least a strating point as to what the problem may be. If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Apr 27, 2011 | Dell OptiPlex SX280 PC Desktop
Blinking amber power button dell 4700 c / light blinks & after a while it boots. when its running its fine works with no problem. Is it power supply. bad fan, coms - battery , or hard drive . or all...
first remove your memory and clean it with a clean cloth the remove the processor fan and clean the surface ot the fan an the processor then apply a thin layer of heatsink compound and fix tightly to the socket
Apr 27, 2011 | Dell Dimension 4700 PC Desktop
Mar 11, 2010 | Dell Dimension 4600C PC Desktop
Won't turn on only blinking yellow light
Aug 04, 2009 | Dell Dimension 4700 PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Computers & Internet Logo
David Payne
David Payne
