Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
I cannot get my clothes out of my he3 washer...
I have been getting the famous F 11 error code. I have read the fixes and plan to try them when I return from being out of town next week. For now, I have a load of wash in the machine and cannot get it out. I began shaking the machine a bit to try and reconnect any wires that may be missing a connection (worked earlier in the load for the f 11 error) and then finally unplugged the machine and replugged it back in. So now the door is locked but the machineis not recognizing it being locked so tries to continually lock the door and continually gives me a dl message. At this point, I just want to save my clothes and fix the machine later. I don't want to pull the door off but am ready to do so if needed. Any advice?
  • landlady6 Nov 11, 2007
    WOW! Thanks for your quick and thorough response! This may sound dumb but is it okay to tip the washer onto its back to unscrew the screws? I assume that the screws are UNDER the machine since I don't see them from the front... I am calling a neighbor to help me get the dryer off the washer and get my clothes out. I REALLy appreciate your response-thanks so much.
  • 5,911 Answers
Here's how to get your clothes out of the washer WITHOUT causing damage to your machine.
There is a manual release, but you need to remove the lower kick panel under the door. There are three torx screws (7mm) under the lower portion of the panel. Remove the panel and set it aside.
If you reach behind the front casing of the washer by the door latch there is a release tab on the lower portion of the door latch assembly. It is a plastic tab and round in shape. You're probably going to have to feel for it. Once you find it, pull straight down towards the floor while gently pulling on the door. The door will open.
With all that said, if you are experiencing an F11 error associated with an Fdl error, chances are you have a bad door latch assembly. That may be the reason why it is repeatedly trying to lock and does not recognize that it is. If you decide to replace the door latch assembly your part number is 1094190 and costs about $50. The electronic control board you would need is part number 959503 and costs about $150. The problem with the F11 error is that the problem could be caused by the control board, a bad door latch, or bad wiring. Sometimes it can be a combination of both electronic components. Here's a way you can try to narrow it down:
1. Place the washer into diagnostics mode: On the operator console select DRAIN/SPIN, NO SPIN, the under OPTIONS press any button (must be the same button) 4 times. The washer should go into diagnostics mode at this point. "C00" will be displayed on the console you should hear a distinctive "click" of the door latch. If the door latch fails to lock, diagnostics will not start. Chances are you have a bad door latch at this point.
2. Another thing to try is to remove the top panel of the washer to expose the Control Board. It is located in the center rear of the machine. You cannot miss it. With the washer unplugged, check all your connections ONE at a time. Then attempt to run diagnostics again to see if the problem persists.
3. If you are able to get the washer to start diagnostics and an F11 appears, chances are you have a control board problem.
These troubleshooting tips are not an exact science, but I have been successful with isolating the problem this way. More commonly, the door latch fails because of the constant wear it gets. However, if you wish to replace both components to be sure, they are both easily replaced by the average do-it-youselfer. At a cost of $200 it's still cheaper than buying a new washer.
I hope this helps you. Post back with comments and let me know if you need further assistance.
Posted on Nov 11, 2007
  • Jeff Rockwell
    Jeff Rockwell Nov 11, 2007
    It's much easier to lift the front of the washer and place a 2 x 4 under it so you can access the screws better. Tilting it on its back can take quite an effort as the machine is very heavy. Not to mention there are support springs that support and suspend the wash tub. I wouldn't recommend laying it on its back.
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...'s+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ... > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE3 front load washer has code F 11 it's stuck there since yesterday, and the door wont open. How can I unlock the door. All my work clothes are in there, and I am afraid they will get...
Here is what Kenmore says.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
May 17, 2011 | Kenmore 42822 Front Load Washer
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. The tech sheet says normal reading is at 6 ohms.
Apr 18, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore HE3 front load washer will not drain or open door
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
F2 error code on my Kenmore Elite HE3 washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE3 stops in middle of cycle, flashes F-11.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore He3Washer Fills then gives error code
remove lower panel right side underneath tech manual with codes
Jul 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Clean all of the lint from the inside cabinet and duct work of your dryer. Then, try to clear the odor, by running a couple of loads of old rags or towels. Good luck!
Aug 14, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
162 people viewed this question
Sal De
 Brian Main
Brian Main
