Question about Garden
MY cc05 MODEL RZT50W/ 22HP BRIGGS ON IT HAS STARTED TO LOSE POWER IN THE BLADE ASSEMBLY, AS IT STOPS TURNING, NOT CUTTING ALL OF A SUDDEN, ALL ELSE WORKS, JUST DOES NOT CUT, AFTER LETTINF IT REST FOR
MY cc05 MODEL RZT50W/ 22HP BRIGGS ON IT HAS STARTED TO LOSE POWER IN THE BLADE ASSEMBLY, AS IT STOPS TURNING, NOT CUTTING ALL OF A SUDDEN, ALL ELSE WORKS, JUST DOES NOT CUT, AFTER LETTINF IT REST FOR A WHILE IT STARTS WORKING AGAIN FOR A WHILE. A CC DLR HAS LOOKED AT AND CANNOT FIND THE PROBLEM. PLEASE HELP.
  • 1,169 Answers
Most likely it is the electric PTO clutch that is failing due to an internal electrical problem; although, it be problem. The tech needs to spend more time actually using the mower to find the problem. Has to be diagnose at the time of the failure.
Posted on Nov 11, 2014
  • Eugene Rounds Nov 11, 2014
    After thinking about the problem I remember one mower that the reverse safety relay that cutoff the PTO clutch would not disengage due a weak internal spring.
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 8 Answers
SOURCE: have a cub zero turn 52 inch cut the blades wont
sounds like one of three possible problems ....one - there are safety switches that prevent engagement of the blades,,,,,two - the electric switch which engages the electric clutch blade pulley is bad....or three - the electric clutch blade pulley assembly is bad.....first.....make sure all ur connections are tight to the safety switches and electric clutchblade pulley.....then, if your able to read and follow a wiring diagram, get the wiring diagram for your tractor and a 12 volt probe light (with probe point end) with a ground lead....first, ground the clamp end to the frame and probe at the electric pulley clutch plug to see if power is getting there...if not...follow the wiring diagram to the next switch location the power lead comes from....if one side of the swtich shows power and the other side doesn't with the switch in the correct run position....then the switch or connection is bad.....if it probes okay...go to the next switch....follow this logic from both sides of the from the electric pulley blade clutch plug until you isolate the switch or plug problem....if everythin tested is good....then it's the electric clutch pulley assembly that need replacing.....hope this helps.....
Posted on Jun 07, 2009
  • 59 Answers
SOURCE: Blades engage,but stop after running for a bit.
check the wire at the clutch on the crank shaft end try spraying the clutch with P B spry
Posted on Jun 26, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
SOURCE: blades wont engage
check the clutch if it engage then check the cable and belt to if it works make sure all the bolts are tight. usually the belts is too loose or if its a clutch drive maybe the clutch doesn't engage or worn out.
Posted on Aug 16, 2009
My intec 22hp. Briggs moter blowing compressed air out dip stick
they all do that to some degree . some vent back to the carburetor and some use that pressure to power the fuel pump .
May 14, 2016 | Garden
What are valve clearance specs on a briggs 22hp Intek Model 407577
Jesus guys, the mans question was what are the valve specs for a brigs 22hp twin v OHV model 407577?
Apr 17, 2013 | Measuring Tools & Sensors
22hp.zero turn sometimes smokes then stops.
The smoke could be caused by blowby around the piston rings. Pour a small amount of transmission fluid in the spark plug hole and turn the engine over several times. Check the plug for fouling. Also check the coil wire for spark.
Apr 15, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
I have a brand new set of Oster A5 model #78005 clippers. We own two large dogs--we cliipped the first one and it worked beautifully--we were about half finished with the second one and all of a sudden...
I'm sorry if this sounds academic, but regardless of whether or not the problem lies with the clipper or the blade set itself, since it is brand new, return it to the seller.
Apr 09, 2011 | Oster Golden A5 2-Speed Universal Motor...
I have a 22hp intek v twin briggs motor while cutting it just stop now its making a popping noise when trying to start and it wont start just spinning and popping
if its popping out the intake or exhaust,then possibly you have sheared a flywheel key and its out of time,you need to remove the flywheel cover and look to see if this is what happened
Apr 29, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Cricut makes loud grinding noise and will not turn roller bar
My wifes' cricut seems to have had the same problem. Try turning off the power, then manually slide the cutting carriage to the left look inside to the right. you should see a red button pull on it until it clicks. power up the cricut and see it it works. it solved the problem for my wife.
Jan 02, 2010 | Provo Craft Toys
Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
