I got a samsung tv,model #LN40B530P7F,it wont turn on,theres a red light on ,on the lower right hand corner,but the screen wont turn on,any help would be greatly appreciated,thank you
  • 26 Answers
CHECK THE T-CON BOARD
Posted on Nov 11, 2014
SOURCE: Blue Noise/Pixels Bottom Left Corner of my Samsung Plasma
You would need to have a technician remove the back of the TV and make the adjustment. There are 2 small adjusters that they change to adjust the voltage.
Posted on Jun 24, 2008
  • 98 Answers
SOURCE: lcd panel will not come on
Need to exchange the Main Board.
If you are in Vancouver, BC?
Please contact 778-893-8792 Jay Lee
Posted on Feb 06, 2009
SOURCE: Flashing red light, screen doesnt turn on
http://recycledpapyr.us/2009/03/26/blown-power-supply-on-philips-plasma/
I found this solution in an other forum , don;t now if you are experiencing the exact same problem though
Posted on Oct 12, 2009
  • 148 Answers
SOURCE: TV will not turn on.
Most likely your powerboard. Inside those are capacitators that are known to "pop". They have been widely used in many newer tv/monitor units since around '97 I believe. Anyway, Some problems with these things are a little harder to figure out, but a problem that shows a light(flashing/blinking/on for while/off for while) is to my new found knowledge a bad capacitor or 2 in your powerboard. I found a 19" lcd monitor that didnt come on, but the power light is on. I bummed then googled it and found this to be a VERY common problem! I watched a video on youtube how to fix your monitor and openend mine. I found 1 bad capacitator(bad caps show a buldging top and/or fluid leaking from them. one trip to Radioshack and $1.59 The problem was fixed! A rapair man woul;d order your board, install it and charge you around $300 or more. You could change your board yourself(saves money) or you could open your unit and inmspect it yourself first, your fix could be $5 or less!....There are many pic etc to be found on google image for "popped" capacitaotrs(caps), also there are video's on how to replace them on youtube...I hope this helps some!
Posted on Feb 01, 2010
SOURCE: tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Posted on Feb 22, 2010
Samsung tv #LN40B530P7F wont turn on,theres a little red light inlower right hand corner,so its gettin power,but it wont turn on
Are you using two remotes, the TV's and the cable box'? Is so, then you possibly may not have an understanding of how the cable box remote operates. Play around with it, or it could be something more serious with the TV, like the power switch button is defective.
Nov 11, 2014 | Televison & Video
40 samsung lcd tv problems
remove batteries from remote control and adjust volume to desired level. If the volume stays the same then there is a problem with the remote. If the volume lowers again then the problem is with the TV. the volume button on the TV or on the remote may be malfunctioning. Hopefully it will be on the remote. If it is the remote, take it apart and clean it with damp cloth. after allowing it to dry, re-assemble and try it out.
Sep 12, 2013 | Televison & Video
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
Tv wont turn on and red and yellow light are blinking together in lower right hand corner
power supply faulty it stays in protckt mode or the fan is not workin that cools the heatsink
Jan 06, 2011 | Televison & Video
Lcd panel will not come on
Feb 06, 2009 | Samsung LN40A550 LCD TV
I have a 56 inch JVC HD TV model# HD-56G647. yesterday when I turned the set on there was a black shadow in the lower hand corner. today it's bigger. i called jvc and they told me to make sure the...
Red light lamp indicator is blicking on my 56 inch mode;# 56G647 tv and the Tv screen is black with no vision of tv and no sound. What sould I do
Oct 17, 2008 | JVC Televison & Video
On the lower right corner of the tv a green light is on when the tv is on should there not be a yellow or other color light when the tv is off?
Not really if the set is turned completely off there will be no light at all, normally a yellow or red light on a tv is not a good sign .
Aug 14, 2008 | Televison & Video
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
