Question about Cell Phones
How do I turn off the little light at the top of my SoundLogic XT 5200 mAh Portable Charger?
The charger is for my cell phone. It was just hanging out in its case and I noticed a light coming from the case. There is a little light, like a little flashlight (LED maybe) on the top of the unit. It came on and has just stayed on for days. I've tried pressing on the light itself, turning the unit off and on and plugging it in to my computer to recharge. The light will NOT go off. I can't find the user manual or a manual online on those "FREE USER MANUAL" websites because I don't know if "SoundLogic" is the name of the manufacturer or not! Help! The light being on is using the charge that portable recharger/back up batter is supposed to have available for my cell phone! Thanks!
  • Scott johnsob Sep 10, 2015
    Omg!!! Lol. This just happened to me and I figured it out. Tap the on/off switch 3 times fast to turn the flashlight on and off. Yay
  • Sean Cooper
    Sean Cooper Sep 19, 2017
    Fantastic, I had the same issue!
  • 452 Answers
SOURCE: i bought a cell phone saturday, didnt come with a user manual i been on every motorola website to no avail. i just want to know about the motorola v66.Help!
 for this u can visit motorola care center ,, they  will provide u the required -- manuall
Posted on Oct 23, 2007
Bajanguru
  • 7752 Answers
SOURCE: Cell phone do not recharge !!
your chargering port need to be replaced or service so take it into a service center and have it fix.
Posted on Jun 22, 2008
Bajanguru
  • 7752 Answers
SOURCE: Cannot recharge cell phone.
the charger port may need to be service or replaced so take it to a mobile service center and have it check out to see what the problem is that is causing it from charging
Posted on Jul 05, 2008
  • 726 Answers
SOURCE: how to recharge a phone
no the only thing you need to do is plug it in ,some phones if there dead flat take a while for the phone to show its charging
if it still does not charge there is something wrong with the charger or the battery
SOURCE: Cobra PR3850WX will not recharge batteries
There is a contact in the upper left hand corner of the batt compartment.This has to touch the metal of the last batt.If your batts have paper around them scrape it off where it contacts that contact point.
Posted on Nov 18, 2008
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Apr 20, 2015 | Olympus Camedia Cameras
SoundLogic XT #BOW-6/5998 No power anymore. Won't recharge anymore.
Make sure the charger is working properly. if ok, replace the battery.
Apr 13, 2015 | Audio Players & Recorders
My portable charger wont stay on. How do you make it stay on to charge the phone?
If you're using the charger supplied with the phone, it should either work or not. If it doesn't; either the phone battery, charger or both require replacement.
If the battery is "good" and you are using a "3rd party" (non-original equipment) charger, you may not have one that is incapable of providing the correct voltage, charge current or both. If the charger can not provide adequate charge current or voltage, it is very possible that the charger is shutting off due to excessive heat. Once sufficiently cooled, it charges again.
Make sure that you've got the correct charger - or one that is designed to charge the type battery in your phone at the correct voltage and current rates.
Apr 08, 2015 | Cameras
Want turn on when charging green & red light flashes
Normally if you have a VXi, B250-XT on its charger and you are seeing both a Green and Red light the headset is changin over from charging to fully charged. The headset is designed to be able to use while it is on the charger however once you place it on the charger you must turn it on to reconnect to your phone before you can do this. Put the headset on and press the Multifunction Button for 2 to 3 seconds, you should hear two rising tones and the headset should reconnect with your phone. Note* your phone may require you to accept the connection request.
If the headset will not turn on either on or off the charger I recommend calling VXi at 800-742-8588 for warranty repair information. A headset that will not turn on indicates the unit is having an issue with one of its control circuits.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
Can i replace my 800 mah cell phone battery with 1000 or 1300 mah battery
You can replace current battery 800 mAH with higher mAH, but make sure the voltages are really same so that, you still can use your charger and the new battery will not damage your phone.
Regards,
Jan 16, 2011 | Cell Phones
My nokia 5200 show when i am connect the charger then show charger not supported
hi
make sure that charger pin of your charger supports your mobile or not. if so then there must be fault in that charger pin of your mobile. kindly change the charger pin of your mobile.
thank you
Dec 19, 2010 | Nokia 5200 Cellular Phone
Charger not supported for nokia 3600s....Help please
May 31, 2009 | Nokia 5200 Cellular Phone
Charger not supported for nokia 5200
Get a replacement charger. Original Nokia charger
May 29, 2009 | Nokia 5200 Cellular Phone
Cell Phones Logo
419 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
