Question about Acer Aspire Computers & Internet
My disk died and I am missing #4 of 4 for my installing computer
  • Acer Master
  • 2,219 Answers
If your disk has "died" then your computer will not install. You need to get it repaired/replaced first.
On a new machine , take it back to the shop you bought it from under guarantee.
Posted on Feb 08, 2015
Dell e5520 freezing
Possibilities:
1. Dying power-supply is creating unstable voltages
2. Dying capacitors on motherboard are unable to stabilize voltages
3. bad RAM (compare to writing in pen on greasy paper -- nothing is realiably being recorded)
4. bad spots on disk-drive (computer is spending too much time trying to write to those "bad" spots)
5. other "dying" issues with the motherboard
Try:
1. different power supply
2. if you have more than one stick of RAM, remove one and test-drive. Repeat with the other stick(s).
3. Try different RAM.
4. Force CHKDSK ("Check Disk") utility to scan *all* of the disk-drive.
5 Inspect the motherboard for bulging/leaking capacitors.
6. Replace the motherboard.
7. Replace the whole computer.
May 27, 2014 | Dell Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
I formated my desktop HP computer when window installation finished the final step my computer displays TFGHT is missing
If the computer indicates that a critical file is missing you can always go into another computer that has the same operating system and make a copy of that file on a usb stick and then insert that file into the correct place. It is also possible that the cd rom you used to install windows did not properly read part of the install disk. You can try again or use an external cd rom to do the install. The likelihood of 2 different units both missing the same file is very remote, unless the disk is damaged and file cannot be properly read.
Nov 28, 2013 | HP Computers & Internet
When browsing the internet I picked up a Trojan Virus and immediately up came "Thinkpoint" with a Microsoft logo, telling me to download Thinkpoint and run it. When I did the answer was "23...
Buy a new disk-drive (your current disk-drive probably is a few years old, and probably the warranty on the disk-drive has expired. So, it's good "preventative maintenance" to replace it before it "dies".)
Disconnect the old disk-drive.
Connect the new disk-drive.
Re-install Windows.
Re-install anti-virus software (or pick a different one, since your current one "failed" to protect you).
Re-install programs (Microsoft Office, Adobe Reader, WinAmp).
Reconnect the old disk-drive as a "slave" drive.
Copy all your files from the "old" disk to the "new" disk.
Virus-scan the "old" disk.
Eventually, "wipe" the old disk, and then, once a week, copy all your files from the "new" disk to the "old" disk, to create a good "second" copy of all your files, to protect you, should your "new" disk-drive suddenly fail.
Nov 12, 2010 | Microsoft Windows XP Home Edition
How do I speed up my computer?
1) Run Belarc to determine what you have installed
http://www.belarc.com/free_download.html
2) Make sure you have all the software disks available. If you downloaded a program, burn it to a USB or CD
3) Using your restore disks, restore your computer to its original status.
4) Reinstall everything. If you are missing a key, Belarc print out will tell you what they were.
5) Experts say do this annually.
Aug 11, 2010 | Computers & Internet
I have a Epic notebook ACE 1314 model no. MS_1314 and when i turn it on it comes up with NTLDR is missing can anyone help me please? Cheers Dylan
the windows system is trashed - boot from a xp cd and choose repair -
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Sep 10, 2009 | Computers & Internet
Missing or bad msacm32.dll file attributed to many files not running, i.e., setup.exe, rundll32.exe, Explorer.exe and many more. is there any way to fix it without reformatting
The answer depends on why these files are missing.
Can you boot the computer at all or into safe mode?
If so you could run the "System Restore Wizard" and restore your system to a point before this problem happened. You can find the system restore wizard in the windows help.
This should fix the problem if has been caused by a virus or an accidental file deletion but if your disk had bad blocks or something then it might need replacing.
If this does not solve the problem tell us more about the exact error message and when it occurs.
Aug 16, 2009 | Computers & Internet
Ntldr is missing press ctrl alt del to restart cant install o/s
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows 2000 startup environment.
Verify That the BIOS on the Computer Is Current loadTOCNode(3, 'summary'); Make sure that the latest revision for BIOS is installed on the computer. Contact the computer manufacturer to inquire about how to obtain, and then install the latest BIOS update that is available for the computer.
Method 1: Use a Boot Disk to Start the Computer loadTOCNode(3, 'summary');
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.iniA list similar to the following list appears: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect If you receive the following message, the Boot.ini file may be missing or damaged: The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Jul 07, 2009 | Compaq Evo D500 PC Desktop
Hi, I have a sony vaio vgn-tx46gp, and the hard drive has died. Are the easy to replace ie me doing it? Thanks
usually about 4 screws is all you have to replace.
however, you'll have to fdisk it, or use the install disk that came with your computer.
Dec 02, 2008 | Computers & Internet
Missing installation cd
you,ll need to format the drive first.
connect the IDE Cable ( 40-80 Strand Ribbon )
And 4 Pin Power plug ( Molex )
you don,t need an installation disk to do this.
enter the bios setup, and ensure your drive is seen by the computer.
install windows et,c.
away you go.
Mike @ Compurepair.
Feb 23, 2008 | Maxtor Hard Drive
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
