Question about Samsung RF266AE (260 cu ft) Refrigerator
Rf 266 is leaking gas.
It runs out of gas in 24 hours.
  • 3 Answers
Thats a very big leak. open freezer do u smell it? Look mat the lines any of them oily thats a good indication of the leak.Pump down , repair leak , pressure test an vacuum then a charge an your good.
Posted on Nov 11, 2014
How do I find out what account 003-266-5155 is
Facebook Customer Support:
Phone Number: 1-650-543-4800
Average Wait: 12 minutes - 24 hours, 7 days
Oct 15, 2014 | Facebook Social Network
Need a free T4 RF Wireless Room Thermostat British Gas manual
I have T4 RF wireless thermostat.When you turn off heating from thermostat,for some reasons after 1 hour boiler kick on and radiator feel hot again.please give me solution.
Jul 14, 2011 | Heating & Cooling
The fridge isn't cooling though the freezer half is working fine. It was recently transported quite a distance in its side (well braced and padded), and left to stand 20 hours before being plugged in. We...
There are 2 reasons. While transporting if they lifted with won wards to discharge side, chances are there to oil entering. And while switch on it starts pumping the oil.Secondly, chance for gas leak.
It's advisable to remove gas and check for leak. If no leak, flush out the system and replace drier.
Vacuum and do gas charging. Please write if it's helpful.
Dec 31, 2010 | Heating & Cooling
When my chainsaw is on its side it leaks gas what needs to be replaced
I would think that if it's just a small amount of gas that it's probably comeing from vent on gas cap. Also check that gasket on the inside of the cap is still in good shape and tighten securely. I hope this helps you. Thanks
Nov 23, 2010 | Husqvarna 162 266 272 Chainsaw Oil Pump...
It hasn't made ice i9n 24 hours. Before that it was fine
Shut it down and check if the compressor motor is acheiving the RPM required , if suspicious connect a capacitor in parallel to see if there is any change.
Now put the fridge on for about two hours to check for ICE formation , if not the possibility if the compressor or lack of gas must be checked. If you have tried to do any maintenance before this did it lead to any gas leak.?
If so check the leak onthe system with a compressed air before gas is filled.
Sep 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My York Stellar PLUS furnace (Model P2UDD12N07601C) will not stay on; The ventilator fan runs, the main blower runs, the igniter comes on for approximately ten (10) seconds and you can hear the gas valve...
Check gas pressure, inspect manifold & make sure there is not a blockage.Make sure gas is present and main gas shut off valve to furnace is on also check the knob on the 24 volt gas valve and see if it is in the on position , check the MV terminal on the gas valve to 24 volt common with a volt tester to see if you have 24 volts present, if you do have 24 volts at gas valve, replace valve. if you do not have 24 volts at gas valve check high limit control & roll out limits for a open circuit, Good luck.
Feb 20, 2010 | York Furnace Draft Inducer Blower Fasco #...
Idles runs really rough can smell fuel
1. Could be changing the fuel filter
2. Leaking injector
3. The gas cap (tank gas input) is clogged - Gas tank does need some air
4. Pressure check you gas line - should be in the 20s and hold steady for hours. Could be slow leak
Oct 14, 2009 | 2000 Dodge Grand Caravan
Submerged one t5710 unit crossing a river; no longer transmits.
Probably not.
The electronics in the transmit / recieve circuitry (RF = radio frequency) work very differntly from those in the display and control circuits, which prob ablyexplains why the display works, but not the rest.
The major problem with water in RF circuits is that even after it dries out, it leaves a residue, or worse still some corrosion, which adversly affects the tuning of the RF circuits.
It may be worth trying to dry it out a bit more - put it somewhere warm but not humid like near but not too close to a central heating boiler, for a few days. However, I suspect it is now beyond repair.
Oct 07, 2009 | Motorola T5710 (22 Channels) 2-Way Radio
New Onan 4000 watt gas RV generator cuts out
The generator engine is jetted for sea level. When you run at 24 hundred feet, it's flooding out. That's what you smell. The carb will need to be jetted for high altitude.
Jun 30, 2009 | Electrical Supplies
Samsung RF266AE (260 cu ft) Refrigerator Logo
69 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
