Question about Sewing Machines
The hook rotates but the bobbin &bobbin case does not rotate.
  • 42 Answers
Sounds like the timing belt has broken. Needs repair by tech.
Posted on Nov 11, 2014
bargainbox
  • 1388 Answers
SOURCE: kenmore sewing machine 15008100 not working
Was all well and working before you did work on the bobbin area ?
Ensure the machine is unplugged & bobbin winder is set OFF as there is a clutch preventing the needle arm to operate when bobbin winding......remove the needle.
If you take the bobbin and hook out, can you manually rotate the handwheel forwards ?
If yes, this suggests they are not inserted quite right, or the timing is out of adjustment.
Can you rotate the handwheel backwards ? On some machines the clutch allows for reverse travel freely, but only around the 15 degrees you mention forward when the top cover is off.....there may be a broken or dislodged spring unit/armature inside top near the handwheel and bobbin winder assembly that is acting as though the top cover is open (a safety feature)....generally towards the rear of machine and acting like a log thrown into a gear.
This may help straight away, or only just start to unravell the cause....
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 16, 2008
  • 6 Answers
SOURCE: Pfaff 2040 Tiptronics bobbin case rotating out of position
Sounds like you need to put a drop of clear sewing machine oil in the raceway of the hook. Then sew on some scrap material to soak up the excess oil.
Posted on Mar 12, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 18 Answers
SOURCE: Rotating Hook won't fully turn-Singer 2210
The nylon gear driving the hook has probably broken a tooth. Replacements are available if you search the web.
Make sure you get the matched set of driving gear and driven gear.
Posted on Oct 05, 2009
  • 255 Answers
SOURCE: brother pe150 won't pick up bobbin thread
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
Hope this helps!
Happy Sewing,
Robbie
Posted on Mar 15, 2010
The bobbin case is not threading up???
cases do not thread bobins do when outside of the case and usually on top of the machine. then put into the case and put back in case holder
Jun 24, 2016 | Sewing Machines
Reinsert the bobbin case in Viking 500
after removing the needleplate and gray bobbincase retainer, manually rotate the handlwheel so that the tip of the hook is between 11oclock and 10oclock. carefully insert the bobbincase into the hook assembly so that the gap in the bobbincase is centered below the feeddogs. manually rotate the handwheel slowly to confirm that the bobbincase is fully seated into the hook assembly. reinstall the gray retainer and then the needleplate. again manually rotate the handwheel to confirm that everything is seated correctly.
Feb 11, 2015 | Husqvarna Sewing Machines
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
Singer scholastic
Open up the bobbin case and remove the bobbin and case. There may be something catching on the hook (random thread) that is preventing the motion. The bobbin case could be off-kilter as well. If that is not it, take the cover off the sewing head and see what is blocking the mechanical parts of the levers.
Jul 30, 2014 | Sewing Machines
Singer sewing machine bobbin case keeps moving causing the needle to break.
Is this a front loading bobbin or top? If it is a vertical front loader with the little metal bobbin case, the metal case has to be lined up and snapped firmly into place. You should hear it snap and lock into place.
If it\'s a horizontal or top loading bobbin, and the plastic bobbin "tray" is rotating, then it may not have been nested in properly, before replacing the plate, or may be "jagged" somewhere... If there is a burr on the casing, or as in the case of one machine I worked on, still have a piece of needle stuck in it, the thread will snag on it before it finishes rotating and the rotating motion catches half way and will jerk the case right around and the next stitch will break the new needle.. Those plastic bobbin "trays" are usually easy to find and replace if they have become too burred to use. I have also sanded them smooth again as well though.
To test it, unplug the machine, thread your machine on top, but leave off your bobbin lid and leave out your bobbin, hold the top thread (like when you are about to crank to pull up a bobbin loop) and hand crank toward you, or counter-clockwise one complete rotation. Watch to see if the top thread is caught by the rotation hook and slips all the way around and back over the top of the bobbin tray, or if it snags on it somewhere.... Good luck!
Jan 15, 2014 | Singer Sewing Machines
Bobbin case moves
it would be a good idea to have the sewing machine checked
to see if the bobbin case needs to be replaced or see if something
is wrong with the hook & hook race.
Oct 09, 2012 | Elna Sewing Machines
Brother pc-420 bobbin case shifts and jams everything up and I've went through 20 needles where they keep breaking off...can anyone tell me why the bobbin case is rotating completely out of...
it's possible that the bobbin case is damaged, it's also possible that the hook or hook race could be damaged,,it's also possible that the hook & hook race are
out of time. only a sewing machine repair shop can say for sure
Oct 13, 2011 | Brother PC-420
I can not figure out how to raise the feed dog. the needle will not pick up the bobbin thread. Are these connected? thanks, Pauline paulinemccracken@gmail.com
Possibly. First put in a NEW needle. Then check when you rotate the handwheel to see if the hook is rotating around the bobbin case. If not, then probably the timing belt has come off. If the hook is rotating around the bobbin case and the feed dogs are not coming up, then check that you have the feed dogs engaged. Another sinario is that the timing is off just enough to not pick up the bobbin thread. Check for these symptoms first, and then well go from there.
Apr 26, 2011 | Singer 7462 Mechanical Sewing Machine
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Mar 10, 2009 | PfaFF Tiptronic 2040
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
