Does my emerson lc320em9 32 in hdtv lcd tv have a cable card
My cable company is going all digital and I am unsure if I will need a cable box.
    Master:
  • 876 Answers
Look here at this website:
http://tv.manualsonline.com/manuals/mfg/emerson/lc320em9.html
Page 5 says you can access your cable channels
Posted on Nov 11, 2014
SOURCE: Programing codes for a Protron TV
The codes for the 32' Protron are 1004 or 1011. However be aware that this may disable your defaults permanently. When we had the cable installed they changed the codes but on doing so, the TV was useless. On power up the led will go from red to green, then go back to red instead of giving a source option. Customer service is agravating and useless; this is Chinese company that is using the name ProtRon to ride on the better make of Proton. We bought it through ShopNBC, definitely a big mistake since they are of no help either. We have taken the TV to a repair shop; they say its a main board but they are having extreme difficulty getting help from Protron; only delays and excuses. There are more issues riding on all this that has prompted my wife and I to seek a class action.
Posted on Mar 02, 2008
SOURCE: Remote Code for Emerson LC200EM8 LCD HDTV 20 inch
sony RM-VL600 remote, can be programmed remote to remote...I bought it, it works.
Posted on Apr 27, 2008
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
Posted on May 06, 2008
SOURCE: I need to hook up to digital cable
Thank you for your time.
I turned on the router supplied by Verizon, which I did not do yesterday, I'm embarrassed to say....
I called Sanyo and received step by step how to set up.
It was the same procedure I used yesterday with the exception of making sure the router was on,
I apologize for any inconvenience.
Reva L,
Posted on Apr 02, 2009
  • 814 Answers
SOURCE: Does my Insignia come digital cable ready or do I need a convertor box?
Yes you do need a digital converter box to get the digital signals converted for the analog television. The television is not set up for digital signal reception. For more information on this problem and technical help you can got to the Insignia website.http://www.insignia-products.com go to the customer support section and tell them the model number of you television and about the question of needing a digital converter box.You can also call them at their customer support telephone number 1-877-467-4289 and give them the same information. They will be able to explain the need for the converter box. I hope this information helps you with your problem.
Posted on Jun 03, 2009
Will not receive incoming cable signal
You didn't mention how you are getting your cable, but will touch on it briefly. Please clarify if you need more information.
Your cable comes in through the wall, and it should goto a converter box / receiver box. The output of this box then is connected to your TV via either HDMI, component video, audio visual connections (RCA), or perhaps the cable coax connector. Sometimes, the cable box will connect via a DVI port, but those are relatively uncommon. Almost *all* modern cable systems have gone to a digital format, which requires a converter box. There are very few, if any, cable standards that are still analog (which could be tuned by your tv at one time). If unsure, contact your cable company to find out exactly which you have, and if a converter box will be required.
You need to setup your tv to look at whatever input the cable box is using, or tell it to look for a signal on the cable coax connector. Make sure the cable box is on before you try to set it up, or you may waste your valuable time.
Feb 13, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
I have Samsung 360 Series 3 LCD using Fiber audio cable directly from cable box to television...not getting audio...checked all cable box settings...unsure...Do have alternatives in house to test box and...
As I see it this TV has no optical digital audio input. The connection on the rear of the set is "Digital Audio Out (Optical)", not in. I think you need to run a HDMI cable from the cable box to the TV to get digital audio.
Nov 05, 2009 | Samsung LN32B360 32 in. LCD HDTV
Bad picture
  1. Hello boss, here is d way to make best use of it.
    step 1.Make sure ur LCD or Plasma HDTV has an HDMI port. Hopfuly u bought 1 with it, if not, you may be stuck using component cables. Not bad, but not he best. Component cables change d digital signal frm the cable box into an analog signal. This conversion allows for signal degradation. U want to keep the digital signal transmitted frm the cable company 2 go directly into ur HDTV. An HDMI cable will provide u wid this capability n with d clearest picture.
    2. Make sure ur cable box has an HDMI port. Most cable companies do not offer a cable box with an HDMI port on the initial install. You may need to upgrade by calling your cable company and asking if they have a cable box wid HDMI capability. Ask them 2 send u 1.
    3.Purchase an HDMI cable. TIP - The longer d distance between the cable box n d HDTV, the better d quality HDMI cable. This is due to degradation of d digital signal over long distances, wiz could result in a poor quality picture. ne distance over sixteen feet should be compensated 4 by using a heavier gauge HDMI cable. Oh yea, don't get taken by buying the most expensive cables. From what I have read, companies are cashing in on this relatively new technologymag-glass_10x10.gif. I bought my "gold-plated" HDMI cables from an Ebay Store, "eforcity" for about a quarter of the price found at the local electronic store. Connect one end of your HDMI cable into the HDMI (out) port on the back of your cable box and connect the other end to the HDMI (in) port on the back of your HDTV.55
    Read the instructions that came with ur new HDMI compatible cable box. These instructions will explain the download process the cable box needs to go through before use and the Setup Wizard that will program the cable box to send the correct picture format to your HDTV. If u did not get instructions, u can get them at the cable box manufacturers website. Scientific Atlanta's website: http://www.scientificatlanta.com/products/consumers/new_cableboxes.ht64. Adjust video, audio, and screen settings to ur liking. The explanation for these settings can be found in ur HDTV's user's manual.75.Push ur "source" button on ur remote control or HDTV n select HDMI. Tune to a Hi-Def channel. Most Hi-Def channels r in the 700 channel range. Check cable company listings 4 d specific channels.
  2. Have a nice time!!
Aug 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
What is a cabel card
A cablecard is the size of a credit card use to view or record digital cable channels on a digital recorder,personal computers and tv s without the use of outside equipment like (stb) set top box provided by your cable company, below is a picture of one hope this helps.
Aug 12, 2009 | Zenith Z37LZ5D 37 in. LCD TV
I have a black box going across my screen with blue numbers it will not go away. I have an emerson 32in hdtv flat screen
Make sure closed captioning is turned off on the TV as well as your cable box or satellite receiver (if you are using them and they have that feature). Captioning is probably on and set for text mode.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
I have a Samsung 52 inch HDTV LCD television, my problem is that for about 3 days the screen says "One Moment Please" this channel should be available shortly. That is it nothing else for days I am not...
If you have a cable set-top box, then the problem is almost certainly in the cable box itself. If you have a cable card installed in the TV, it could get a little tricky. Either way, it wouldn't hurt to have the cable company come out to check your system for you, whether you need a new cable box, or to try a new cable card in your tv.
I hope this helps you.
Dec 29, 2008 | Samsung LNT5265F 52 in. LCD HDTV
Dec 29, 2007 | Televison & Video
Need TV code for Emerson HDTV LC320EM8A
I am looking for a remote code for the emerson LCD to work with the Comcast remote...any suggestions?
Dec 08, 2007 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
