Question about Microphones - Wireless (VHF/Other) Audio-Technica Cardioid Condenser Headworn Mic for A-T UniPak Wireless Systems TMP-AT-ATM75cW
Audio Technica ATW-T602 wireless microphone does not broadcast a signal when used. Receiver operates well when another mic is used with it that is set with the same frequency. I am in Huntington, West
When you switch this Microphone on, the red indicator light by the on/off switch will come on and then go out fairly quickly and stay off. When you switch it off, the red light will briefly light and go off. When the mic is off, the red AF Peak light on the ATW-R600 Receiver will flash until the mic is turned on, and then it goes off. However, I still am not able to broadcast on this mic.
  • dkmcsween640 Nov 12, 2014
    Add a Comment: Here are three more things. First, this is an ATW-602b handheld microphone, not the one shown in the picture by this post. Not sure how that got there, but I can't figure out how to get rid of it and put the correct picture in its place. Second, while trying to get this mic to work I discovered something new. When the mic is switched off, there is a red light that comes on flashing on the receiver while there is a loud, fuzzy sound or hiss until the mic is turned on. Third, I discovered that as long as I hold the mic upright, I can get some broadcast out of it, but when I tilt it to a horizontal position, it stops broadcasting. Talk about a "balanced system!". :)
My mic wireless mic sounds like it has a ground loop hum when it is in standy mode and when it is all the way on. I've switched cables and batteries what could be causing this hum?
You could try another power adapter on the receiver, maybe this one blew the filter capacitor. I doubt your problem being the mic, rather check the receiver. Luck !
Nov 10, 2014 | Audio Technica Audio-Technica ATW-T202...
Microphone cutting out during use
reduce distance between receiver and transceiver (microphone)
Adjust antennas not parallel.
Apr 09, 2014 | Audio Technica Audio-Technica ATW-T701...
I have a atw-t52 audio techina wireless mic. And when i turn it on thr crackling begins to come through the speakers and i have to play with the input and output cable and move the base unit around and...
I have the same problem in my ATW T52, in st by its ok (the rf leds show perfect signal) but when i set in on the af level start punch and i hear in the monitor a noise like a heartbeat (pum-pum-pum....) Please any answer for this problem
German
Radio del Sol 96.3 Mhz
Villa de Merlo - San Luis
Argentina
May 20, 2010 | Audio Technica ATW-T52 Professional...
I have problem with channel on Audio Technica wireless microfon How can I change the channel because the same things wireless channel digital television and she considers the work of the microphone. Type...
I don't think is possible. But its entirely my point of view,as i feel technically its not possible.
Try checking your user manual provided for microphone. That may offer you better guidance.
Oct 10, 2017 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
I have a audio-technica ATW-T51 and need to replace the cable as it makes a lot of noise. Where can I go?
to a web site called parts express.com you will find anything in audio related items there..
Nov 23, 2009 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
Two diffrent units with two diffrent frequincys . i wantto change
I hate to be the bearer of bad news but those units are fixed frequencies and cannot be changed. You either have to find a mic that matches your receiver or vice-versa. The freeway 200 series comes in 3 freqs. two of witch you have with the addition of 170.245. Maybe you can find someone who has a damaged mic but still has the receiver with the freq. that you need for your mic.
Apr 11, 2009 | Audio Technica Audio-Technica ATW-T202...
Disasimbel freeway atw-t202 for repair
might just be the mic wires came loose...I have oner and the mic is held in by a small rubber O-Ring and as people drop it it falls out and can short out
Jan 11, 2009 | Audio Technica Audio-Technica 200 Series...
HELP
Audio Technica Part number 235401550, call 330-686-2600. The cost is $21.93, plus shipping
Jul 29, 2008 | Audio Technica ATW-T52 Professional...
Vocals disappear in parts using this mic
It is very common to have the squelch on the receiver set at full or much too high. With the audio output unplugged or at least turned all the way down, and with the transmitter turned off, locate the squelch control - you may need a screwdriver depending on which model of receiver you have. Turn the squelch control counter-clockwise until the TX light turns on, then turn it back up just past the point where it turns back off.
If you turn it all the way down and the TX light doesn't come on, that's okay. If you get blasts of noise occasionally when the transmitter is turned off, then set the squelch a little (only a little) higher until it stops.
Joe
Jul 21, 2008 | Audio Technica ATW-T52 Professional...
Microphones - Wireless (VHF/Other) Audio-Technica Cardioid Condenser Headworn Mic for A-T UniPak Wireless Systems TMP-AT-ATM75cW Logo
112 people viewed this question
Top Microphones - Wireless (VHF/Other) Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Microphones - Wireless (VHF/Other) Audio Player and Recorder Expert? Answer questions, earn points and help others
