Question about Sony CDX-S2210 CD Player
Can,t figure out how to wire itAND would like to find out how to wire it up?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
You may view/download the installation manual at Owners Manual User Guide for Sony CDX S2210 CD Player
Posted on Nov 11, 2014
I have a bud light mp3 ipod tower speaker and i need to replace the rca inputs on the back
I can't help with your solution, but you might be able to help me with my problem?
I need someone with the same tower I have to take off their back cover and
describe the wiring and connections. Mine got messed up when fixing it
and now I don't know how to reconnect them.
I can be reached at rjw7@cox.net / Thanks! / Ron
Apr 11, 2012 | Audio Players & Recorders
Car will not start, could it be the solenoid
Check the wires. if there dirty or open you wont get enuf power to itand check your pwer and ground
Dec 27, 2011 | Cars & Trucks
How do I re-sync top motors for convertible on 1997 BMW 328i
i AM SURE THERE IS A WAY TO DO THAT TAKE THE OVERHEAD COVER THERE IS A SMALL BOX YOU HAVE TO TRY TO OPEN IT WITH A SMALL SCREW DRIVE AND UNSCREW ITAND PULL THE COVER CAREFULY AND YOU WILL SEE THE TOP CONVERTIBLE MOTORE AND DESCONNECT THE WIRE AND RUN A WIRE FROM THE BUTTERY AND CONNECTE IT WITH THE END OF THE MOTORE IF IT DOESN'T MOVE TRY TO SWITCH THE WIRE OK i HOPE THIS WILL HELP YOU ME TOO I HAVE A PROBLEME WITHE MY BMW 323I 1998 THE TOP DOESN'T GO DOWN THE CONVERTIBLE SWUITCH DOESN'T HVE A POWER A REACHING IT IF SOMEONE HAS UNSWER PLEASE SEND ME AN E-MAIL absi20@hotmail.com THANK GOOD LUCK.
Sep 29, 2011 | 1997 BMW 328
I just got an amcor CPLMB12000E fom a friend, it worked great for about 15 min. then the fridge turned on an blew a cecit breaker in the box. I reset itand all it does is blow harm air. I pluged it into a...
Check compressor and fan only things it can be disconnect one at a time until fault goes away and there is your prob hope this helps
Aircon chilling for a living....................
Sep 01, 2011 | Heating & Cooling
I just got the new s032g . i can't stabilize itand it's lookl ike no gyros installed. when it's come up it's start to move forward. any help? thanks, Erez
Make sure that when you turn it on, you place it on a stable and LEVEL surface until gyroscopes sync up and internal red light (not red/blue flasher in nose) stops blinking. This sets level heading for helicopter. If gyroscopes sync when craft is not level it will be trying to correct and will move forward or backward. If helicopter is level and blinking red light inside stops blinking after powering on and it still moves and wont hover. Then you have a defective board and I would return it to retailer and ask for replacement.
Hope this helps, let me know
r
Jan 23, 2011 | SYMA Toys industrial Syma S032 Ready to...
There is fuel leaking from gas tank on passengers side. there are wires and hoses hooked here its the black hose that just looks like a plug where the fuel is coming from what is this?? Not a mechanic...
that may be the vent hose fuel getting on wires wont cause a problem but stadic from your body will ignite fuel and there is few safe ways to drain the fuel with a pump or turn key on and pull the fuel line from the rail or fuel filter remove itand drain it into a can from there .from my experience every time i had to take down a fuel tank it was almost always full i think a full tank is safer than a almost empty 1 just try to repair the hose without draining the tank make sure that u ground yourself to the car so you dont cause any sparks ,if you smell fuel there is fumes and that what will cause fires and deaths try to find someone to help you with this if you just trying to replace a hose dont try to drain the tank work around the fuel the best you can wear raggs around ur wrist to prevent fuel from going to ur harm pits that burns other than that use some common since when it come to high flamable fuels remember tha body stadic is your biggest enemy
Aug 28, 2010 | 1997 Plymouth Neon
My Wii drum is not working and won't connect. there is a flashing blue light. This has been successfully hooked up in the past, but not now. Might have gotten bumped? Help?
well im not sure with the drum because i dont have 1 well maybe this will help.. *if its wireless it might need a battery change (or try swaping the battery around) *if wired (connected to the usb port) remove itand put it onto the other 1 besides it *take it to a repair shop *return to game retailer
Oct 26, 2009 | Nintendo Rock Band for Wii
""plz. connect player to PC""
Create a folder on your music player called System. Copy over the Font and Firmware update into this folder. Disconnect and then reconnect your mp3 player. It should then recognize it with Device Manager software. This took me a good two hours to figured out.
Mar 02, 2009 | Philips GoGear HDD1830 MP3 Player
Sony CDX-S2210 CD Player Logo
99 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
