Question about Refrigerators
Which way do the connectors go on the control board?
We are putting in a new control board.
  • Refrigerators Master
  • 744 Answers
Hello Verlaine;
My name is Peter. I am a retired field service refrigeration technician.
Please let me help you.
You received the new control board in a silver anti-magnet bag. Hopefully, you have not removed the control board without grounding yourself first. You ground your self by rubbing your hands over something that is steel. Static electricity will kill the board.
The connectors on a control board are proof. Each connector is designed to fit a specific plugin.
After you have located the control board, refrigerator unplugged,
Usually, a 10" x 8" cover plate on the back of your refrigerator.
Ok, you have removed the control board cover plate. You will see the control board is mounted on white pins. On these pins are 2 legs protruding. With one hand squeeze the first pin, Pushing the pin legs in. With the other hand pull the control board forward toward you. Go around the board until the board is free.
Systematically, with the new board, take one connector off the old board and put it one the new board. Repeat this until all of the connector are on the new board. Push the new board on the white pins to secure.
Why do you think your problem is a control board? Send me the model number of your refrigerator and tell me what the issue is.
The manufacturer recommends a surge protector. All appliances like you computer with control boards should have a surge protector. You can get individual wall socket surge protector at Lowes or Home Depot for about $15.00.
Posted on Nov 12, 2014
2 Suggested Answers
hiltonjug
  • 612 Answers
SOURCE: ribbon connector came off at the control board
You should be able to reconnect the ribbon. There should be a plastic piece that you push back away from where it connects. Re-insert the ribbon and then push the plastic piece into the connection. This plastic piece holds the connection tight. If it will not stay in after trying this, replace the ribbon. You can get one at www.partselect.com for $9.30 + shipping. Good luck
Posted on Dec 15, 2009
Why has my freezer--including the automatic ice maker, on a Kenmore Elite side-by-side fridge, suddenly shut down?
Hello Sherry;
1.) If the refrigerator shut down for 20-30 minutes:
Your refrigerator goes into a defrost cycle every 8-10 hours. The refrigerator shuts down for 20-30 minutes. At this time, you have a heater under your freezer cooling coils (Evaporator). The heater turns on and melts the frost off your cooling coils. Then the refrigerator turns back on. This is where you get the term; "Frost Free".
2.) If your refrigerator has shut down and is still shut down:
a.) If it shut down going into defrost - Some refrigerators have mechanical/electrical defrost timers that are easy to access and manually bring it out of defrost. Unfortunately, your refrigerator defrost cycle is built into your main control board.
b.) You main control board is bad. This is a primary electrical part. It is not a uncommon failure. The control board is about $85.00 and easily replaced.
I have faith in you Sherry, lets replace it:
1.) The new control board will come in a silver bag. This is a anti-static bag. Static electricity will not the board out. Ground your self by rubbing your hands on a steel object.
Move the refrigerator out to where you can freely stand behind it. Unplug the refrigerator. There is a metal cover plate about 10" x 12" on the back. Remove the screws and lift up. There are tabs on the bottom of this cover. Now, the control board in front of you is held in place by small white retaining pins. On each side of the pin is a small leg. With one hand squeeze these legs and the other hand pull the control board toward you to free the board from the leg. There are several pins around the board. Now that the board is free, take the new board, systematically going around the board one connector at a time. Remove one connector from the old board and connect it to the new board. Repeat this one connector at a time. Each connector at the top has a clip that you must squeeze to disconnect. Make sure on the new board you hear the connector click. Do not pull on the wires. The connectors are fool proof. The connectors are designed to only fit one connection size. Remount the board on the pins. put back cover on and plug in.
Nov 09, 2014 | Kenmore Elite Side By Side Refrigerator -...
How to install
Disconnect power.
Remove the access panel on the back of your refrigerator.
Remove all the connectors going to the board. They usually have a tab on one side that you need to squeeze/push in with your thumb and finger. Don't worry, all the connectors are keyed, so you won't be able to mix them up when you put them back on (unless you are a gorilla, or something).
Remove the main circuit board by finding the locking tabs holding it in place and using a screw driver to gently unlock them. You didn't mention which model you have, so if the board is held on by little white push-thru plastic pins, use needle nose pliers to "squish" the locking tab so you can pull the board off the plastic pins one at a time.
Make sure you take note of the orientation of the old board.
Then, just put your new board in and start hooking up the connectors. Don't worry if you see an empty connector, or two when you are done. The control boards are generic and made for many different models of refrigerators by the manufacturer.
After you have all the connectors in place, clean up your wire bundles so they won't get pinched, and then, put the back access panel back on.
Plug your refrigerator in, and your compressor should start running within a few minutes. If you haven't heard your compressor kick on in about a half an hour, re-check everything.
Oct 22, 2014 | Kenmore Refrigerators
How to change the main power control board
You will need to UNPLUG DISH WASHER remove screws that are on inside of door the board is between the inside of the door and the outside of door. Unplug connectors on old board install new board reconnect and put door back togather
Aug 09, 2014 | LG 24 in. LDS 5811 Built-in Dishwasher
Error 2470 bizhub c5501
Check all your connect on the printer control board had a new board installed???????????? Power off the machine get to the printer control board, check each connection pull it off check the board connector for a bent pin the reseat connector each and every one slow process
Apr 17, 2014 | Konica Minolta Office Equipment & Supplies
Need reset sequence
o reset the control module AP2802870, you will put the dishwasher into the cancel/drain mode and let it complete the cycle. When you installed the new control remove the jumper from the original front lower right hand # 1 board male port. Starting from the extreme lower rt.corner, there is a 6-terminal connector with a jumper wire looping # 5 and # 6 terminals. (counting from the right to the left). Use this on your new board. Then reset the controls.
Apr 18, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
The "Program" control, the speed "+" and "-" controls do not work
replace the old batteries ( if you system has , clean the contacts batteries from oxide, etc) put a new one.
2) tight and cliean the ribbon cable inside from display board+tight and clean the upper and lower connector.
3) adjust the REED swtich tigth the connector , and clean it. see the diagram attached.
Oct 17, 2013 | Exercise & Fitness
Control Board wiring
How old is the unit. normally there is a tech mini manual of one or more pages inside the control panel or you might look in the upper vent area. this wiring / schematic would list the wiring positions of the relays you mentioned.
Mar 28, 2012 | Microwave Ovens
T931 not starting
1) Exchange batteries by new ones.
2)Tight the flexible cord Keypanel vs display board.
3) Tight the connector from display board vs lower board.
4) Adjust the sensor reed switch see the diagram by 1/8"
5)put your software calibration to work, for diagnostic and adjust.see the instruction in your owner manual y/o under hood.
6) Adjust the speed sensor and tigh the connector very well.
7)Test the main motor for 115VAC, see the plate from motor for to check the voltage.
8)See the main motor board or lower board, Test for 115 Vac, and +5VDC for output from the main controller board and display board
See the block diagram and take the diagnostic very effective. sincerely.
Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Dec 22, 2011 | Exercise & Fitness
My 350 bizhub has error code c0096 where is the m11 connector?
Toner Suction Fan Motor (M11) Failure:
M11 connector is on the Mechanical Control Board (PWB-A),
Also check the Power Supply Unit (PU1)
Mechanical Control Board Cover
1. Remove the Upper Rear Cover.
2. Remove the Rear Cover.
3. Remove five screws [1] and the
Mechanical Control Board Cover [2].
4. Unplug the all connectors.
5. Remove five screws [3] and the
Mechanical Control Board [4].
NOTE
? When replacing the Mechanical
Control Board, be sure to replace
the EEPROM.
? When the Mechanical Control Board
has been replaced with a new one,
check the ROM version and
upgrade the firmware to the latest
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 01, 2011 | Office Equipment & Supplies
Jenn-Air model #sve47600b. Today put new display control panel in. Didn't fix the problem. The display now works, but the oven light and fan will not stop running. Also the touchpad doesn't work. If it...
Make sure that you properly plugged in the keypad cable. There is the wide connector that brings all the keypad touches up to the display board, and there is the small 4-black wire connector that brings power to the control board.
For future reference, we repair electronic control boards at www.fixyourboard.com, maybe we can help you in the future.
Oct 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
