Question about KitchenAid Kitchen Aid Architect II 24 In. Panel Ready Built-In Double Drawer Refrigerator - KDDO24RVX
My kitchenaid double drawer dishwasher top drawer keeps filling with Hot water. We've turned off the circuit breaker,but the water is still flowing
  • 73 Answers
How to Clean a Kitchenaid Dishwasher Filter
Read more : http://www.ehow.com/how_4826080_clean-kitchenaid-dishwasher-filter.html
Posted on Nov 11, 2014
2 Suggested Answers
app_3rp85790
  • 16 Answers
SOURCE: Kitchenaid side by side refrigerator causes ticking sound from circuit breaker
Homeland Security smart appliance .... ??jkThis a very educated guess but I think it is one of these three things.
1. The appliance is not grounded properly either the prong on the plug is damaged or looks good but is not good OR the plug where it is plugged is not grounded well... so what is happening is the refrigerator is finding and alternate quicker ground and electricity does.. which would the water going into your ice maker... the breaker box is also generally grounded to your plumbing as well.. so that sound is caused by the "stretch" having to get power at one distance but to alternate the current as in any 130 60 htz home it has it go further to get the ground (to harness usable power). So the plug and the plug in.
2.The breaker itself might have and excessive load and is at verge of "breaking" or it might be weak or bad breaker. Try and eliminate all possible power drawing devices on that breaker.. if that stop the ticking then plug some things in on other circuits to give ample power to the fridge. One thing to know is that anytime and appliance is operating in "low voltage" situation they fail prematurely... so make sure you got enough power.
3.Lastly this sound could be caused by what is called an "uneven breaker panel"... What that means is ..the power coming into a home is generally a :"2 pole:" 220 volt...Meaning you have a Neutral wire White, and 2 completely separate 130 volt (black wires) which share that neutral wire (ground from the power company) as the current alternates ..AC mean "alternating current". What happens because of the size and placement of items that draw power...sometimes inadvertantly one of the 130 volt legs is providing for example 90% of the power while the other only 10%. This cause great friction as the negative electrons are pulled much harder by one side than the other ..and makes that kind of noise. Fix it you need figure out how much actual each breaker is using on an average and rearrange them to get them at roughly 50% each.
I'm very sure that one of things will fix your problem. Good luck to you..and be careful around electricity....ESPECIALLY WHEN IT IS ACTING AND SOUNDING STRANGE!!
Posted on Jun 22, 2012
My double drawer kitchenaid dishwasher sold red light and beeping during cycle wont turn off and runs even with door open, turned breaker off
If you using upper or lower drawer and this shows up it means the dishwasher has water under the filter board which located on the bottom under the lower drawer. You have to disconnected power,removed the lower drawer, clean the water, replaced filter board, check the dishwasher for leaking.
Nov 26, 2017 | KitchenAid Dishwashers
12 kitchenaid DW, dashboard goes out. Turn off breaker, then on, DW works. 8 times in 90 days. Serviced after the first several times. Nothing found. Ideas?
I don't know what else is on the circuit with your Dishwasher, but it is possible that you have a defective circuit breaker, or corroded wiring at the circuit breaker or at the dishwasher. Maybe too many gadgets on he same circuit and you are tripping the breaker. The dishwasher may have an internal circuit breaker that needs replacing. some thing to think about.
Nov 02, 2017 | KitchenAid Dishwashers
Dishwasher took 3 hours to complete cycle
If you have set the unit to heated water or your hot water is not hot will delay the wash cycle. The heater in the dishwasher is very slow!
The following is from the user manual.
15
TROUBLESHOOTING
First try the solutions suggested here and possibly avoid
the cost of a service call...
Dishwasher is not operating properly
Dishwasher does not run or stops during a cycle
Is the door closed tightly and latched?
Is the right cycle selected? Refer to the "Cycle Selection
Charts."
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shut-off valve (if installed) turned on?
Dishwasher will not fill
Is the overfill protection float able to move up and down
freely? Press down to release.
Dishwasher seems to run too long
Is the water supplied to the dishwasher hot enough? The
dishwasher runs longer while heating water. Refer to the
"Dishwasher Efficiency Tips" section.
A delay automatically occurs in some wash and rinse cycles
until the water reaches the proper temperatur
Hope this helps?
http://www.repairclinic.com/UserManual/f75a81f2957b4b86b396c8c3629d9078/8531130/Use-Care-Guides-Owners-Manual/Use-and-Care-Guide-8531130
Oct 16, 2016 | KitchenAid Dishwashers
MOD KUDDODPPA O THE CENTER LIGHTS ON BOTH DRAWERS FLASH RED
What drawers are you talking about on a kitchenaid dishwasher?
May 10, 2015 | KitchenAid Dishwashers
F.P. Double drawer. When I use the bottom drawer, it pumps water into the top drawer.
Sounds like the outlet valve on the top drawer has gone.This prevents water flowing back in to the drawer.
Jul 04, 2014 | Fisher and Paykel Dishwashers
Have a kitchenaid double drawer dishwasher. While running the bottom drawer the top drawer fills up with water. Had the filler valve on the garbage disposal changed. Issue still continues. Any suggestions
Mine does the same thing! (Same model) I've finally discovered that if I start the bottom drawer first and the top drawer just after that doesn't happen as much. Also, if I run the garbage disposal (and water obviously) while it's starting (I will try to do my hand washing while the dishwasher is getting going) that seems to keep this from happening as well. I've given up running just one drawer, which totally defeats the purpose of buying the 2 drawer dishwasher. But it does keep me from having to bail the bottom drawer :-( I'd like a better solution to this too!
Sep 10, 2013 | KitchenAid 23 in. KUDD01DPPA Stainless...
Kitchenaid kuddo1dppa
test this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 22, 2013 | Dishwashers
My top drawer says it isnt getting any water and the water hose is rattling. the bottom drawer works fine
Its common for the Dual Water Valve to slowly decrease water flow to the tub. It generally faults on the top draw as its the most used...more wear on the top valve.
This is more often seen on US Models (120v) that have hot water fill.
Jul 14, 2011 | Fisher and Paykel Dishwashers
Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid Kitchen Aid Architect II 24 In. Panel Ready Built-In Double Drawer Refrigerator - KDDO24RVX Logo
162 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
