Question about Sony Playstation 3 (PS3) Console
Carn't play online with vodaphone usb modem? help.
Pluged my vodaphone usb wireless modem into laptop then laptop into ps3, ps says connection enabled but wont allow me online. iv tryed internet coinnection test but carnt find ip address. The ps says internet connection enabled, and also media server connection enabled please help.
  • Anonymous Jan 03, 2009
    dude i tryed everthing but i have a 3G thing
    got any idea how to use the thing to go online with it on the PS3
Posted on Feb 12, 2009
Connecting my ps3 with a wireless modem
ok you will need a ethernet cable connected from your pc/laptop to your ps3
1st you will need to change sharing settings on your o2 modem
to do this goto manage network connection in there right click on the o2 mobile connection go down to properties go in to properties in there go to sharing and allow other users to use this connection.
2nd when setting up the ps3 you need to change one setting.
on the ps3 go to network settings go dowm to internet connection settings
select costom >wired connection >auto detect> ip adress = automatic >
dhcp = do not set > dsn = automatic > mtu = manual set this to 1420 >proxy sever = do not use > upnp = enable . that it just test your connection .this works good for me wit o2 the only setting changed was the mtu any thing between 1400 to 1450 will work fine ps add lostxbox as friend in psn
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
I want to connect my telstra wireless modem to my PS3
I assume the Telstra wireless modem is configured correctly and the computer/laptop can access the Internet wirelessly.
The PS3 needs to be configured with the Telstra modem's wireless settings so it can communicate with the wireless modem.
To configure the PS3 please follow these steps :-
1. Power up the PS3 and login then Select Network Settings and
press X
2. Select Easy then press > button
3. Select Wireless then press > button
4. Select Scan then press > button
5. Select the wireless modem you want to use, then press X button
6. Confirm the SSID for the wireless modem then press > button
7. Select the security settings (ie WAP, WPA - this is the in the wireless modem settings) then press > button
If there is no encryption I suggest you enable the encryption on the wireless modem, use passphrase to generate the encryption key.
Write down this encryption key, you will need this key for your computers and PS3.
8. Enter the WEP or WPA encryption key (from the wireless modem) then press > button
9. Check the settings then press X button
Dec 22, 2009 | Sony Computers & Internet
If you dont have a router can u still use a cricket usb modem
with a laptop connect the laptop to ps3 with an ethernet cable and on the cricket modem connection goto properties and turn on connection sharing and choose the local are connection as device to share with
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
I have a Belkin Wireless router and I have a PS3
Actually you don't need to forward ports when playing online games. The router should automatically locate the ports for the game because it has UPnP function. Here's what you can do. Disable the port forwarding and DMZ that you set on the router. Look for the UPnP function of the router and disable, Save it. Enable it again, then save. Now power cycle your router. If you have Static IP on the PS3 network settings, try to set it first to automatic IP and automatic DNS.
Hope that helps.
Sep 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Always lose connection while playing playstation 3 online. Sometimes my computer displays a launchmodem error when trying to get on the internet. If I unplug the modem and router, it works again.
Please give some information on your router and modem brand/model, also what type of connection do you have, cable, dsl, etc. Go to and post your upload and download speeds as well.
Are you connecting to your play station wirelessly or through network cable directly to the back of the PS3?
Depending on your speeds your connection could be overloaded by the high demand the PS puts on your internet connection, or if you are wireless you could be in far range from where the router is located. Hope this helps. The extra information might help.
Sep 17, 2009 | NetGear WGT624 Wireless Router
How to hook Cricket USB Broadband Modem to my PS3
is it possible to connect my ps3 to the internet using cricket broadband modem?
May 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 and thompson ST585v6
So the WLAN is red, it means that there's no wireless connection from your router.
I might advise you to reconfigure the RCA on the wireless settings.
for the PS 3 there are port that you can gather with your PS 3 manufacturer to open on the router, it might help the PS 3 to go online simultaneously.
Mar 09, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
if you want to be able to play your ps3 downstairs with your modem upstairs, you might consider buying a Wireless Router that has Wireless G , for your PS3.
This will allow you to access your Internet all around your house without wires. I suggest looking for one that features MIMO or range plus max, or anything else that increases your signal range since there is a fair amount of distance involved.
The alternative is relocating your modem downstairs and hooking it up to the PS3. BUT your computer wont have Internet.
Aug 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
118 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
