Question about SIERRA-TELEFLEX Water Pump Kit for 20-25HP Johnson, Evinrude
I have a 25hp Johnson and it has set for 2 months. It turned over twice and stopped. I took the cowling off and found the linkage to the stater? was mangled....so I do not know what I need or what i
I have a 25hp Johnson and it has set for 2 months. It turned over twice and stopped. I took the cowling off and found the linkage to the stater? was mangled....so I do not know what I need or what it is supposed to look like. Can anyone help with this?
Hi i have a 1984 25hp johnson with a miss, and a kick like a horse.compresson exellent new plugs and coils. thanks
Spray clean the carb(s). Put in fresh gas and oil. Run Johnson cleaner in tank of gas.
Mar 05, 2018 | Johnson Boating
How do you advance idle rpm?
Hello R Lynn Johnson,
This question is submitted under Cars & Trucks?
Timing and Idle screw... I don't think so...?
Actually sounds like you have been adjusting the CHOKE...
I hope you are COUNTING TURNS... Because what you are describing about "timing" certainly does NOT sound like you are working on any car I've ever seen.
It would be wise to set everything back where you started...
DISCLOSE WHAT MAKE, MDDEL & YEARS...
(engine & transmission)... you are fiddling with and PERHAPS WE COULD STAND A CHANCE OF TELLING you WHICH SCREW is your idle speed screw (if any).
Else I would strongly recommend you buy the books for your car and study up...
Oct 17, 2016 | Johnson Evinrude Wiring Harness, 89-90...
Johnson 115
find the bottom carb , see where the linkage from the remote cable moves the lever on the side of the engine then disconnect the cable from the remotes ! on the bottom carb there should be a screw to adjust the tickover where the linkage meets the carb linkage , turn it in 2 turns then with water attatched to water intake on gearbox turned on start the engine , it mite be slightly high or low pending ! set at 900rpm , rev engine several times back to tickover and if ok then refit throttle cable , cable should be pushing lever against its stop and then when you select forward gear it shouldnt move till you throttle up ! when in water start engine and select forward gear and tickover should be 7 to 800rpm and idle ok if not adjust till ok !
Aug 12, 2014 | Boating
2001 mercury outboard 25hp 4sroke electric start. will not ldle. l have replaced fuel pump and had carb serviced at dealer. l have replaced the fuel filter twice. l can start with fast ldle easily and drop...
did you mop out the tank , fuel lines and fuel pump etc as water is bad news in a 2stroke ? when in water run engine and set the tickover ON THE CARB throttle stop ! see if it goes in and out nicely just above stalling , you might have to clean the carb again if water in tank !??
Sep 01, 2013 | Boating
The windshield wipers to my Ford focus stopped working today. They worked for a little while & then stopped in the up position. You can hear the motor working but they don't move. You can move them...
Your wiper linkage has come off the wiper motor. To reconnect the linkage, first remove the wiped arms, the remove the wiped cowl. The wiper cowl bolts are located under the hood and screws through the spaces in the cowl. Reconnect linkage, reinstall cowl, reinstall wiped arms.
Jul 05, 2011 | 2006 Ford Focus
What is the corrct fuel mix for 2005 25hp johnson
2 stroke is rated at 100 to 1... but I always run it a little more like 50 to 1. I would rather put plugs in it than burn up a motor for lack of oil......
Dec 25, 2009 | Boating
I have a 1970's 25hp Johnson outboard motor. Last
Hello Adam.
If your propeller is OK, your lower unit will need some repair. It may be as simple as a clutch dog worn and not engaging the gear. Usually they give warnings of problems by jumping out of gear though.
Other possibilities are broken driveshaft, propshaft, or gears. If it goes into reverse the shafts are OK and the clutch and forward gear become suspect.
It was common for these engines to break at the top of the driveshaft where they were tapered.This would give you no motion at all and no previous warning of a problem.
Check the gear lube for metal particles and signs of water intrusion. I hope your repair is an easy one.
KL
Dec 08, 2009 | Boating
What is the trick to removing the leg from a 25 hp johnson 2005, cant find were to disconect the shift linkage
Its either up under the cowl near the bottom of the powerhead, or you might have to put the outboard in gear using the lever to drop the leg an extra inch, which would then expose a shift linkage holding nut in the gap above the leg connecting point.
Oct 18, 2009 | Boating
My 1976 Johnson 6hp outboard idles OK,but won't rev up to power under load when I open the throttle. When I checked the spark pluge, I found the top one to be wet with fuel mix, but the bottom one was...
check for spark against the block. they sell a test kit, i think harbor freight sells one, where you hook it in line and should be able to see if it is firing or not.
Jul 29, 2009 | Boating
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Jun 30, 2009 | Sport & Outdoor - Others
SIERRA-TELEFLEX Water Pump Kit for 20-25HP Johnson, Evinrude Logo
Top SIERRA-TELEFLEX Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a SIERRA-TELEFLEX Plumbing Expert? Answer questions, earn points and help others
