Question about Dryers
Timer g. E dryer dbsr463eggww - Dryers
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 120 Answers
What is your question?
Posted on Feb 03, 2015
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Picture or diagram of GE dbsr463eggww dryer control panel
theres always a schematic inside of each appliance
Jul 04, 2014 | GE DCL333EA Dryer
We have a whirlpool duet front load dryer, why does it beep during a cycle?? when clothes are still wet?
You can perform some Whirlpool electric dryer timer troubleshooting to determine if the timer is faulty or if the cause is somewhere else within the dryer.
  1. Access the Timer
    • Unplug the Whirlpool dryer power cord from the dryer electrical outlet. The timer is inside the control panel on the top of the dryer. Pull the dryer away from the back wall so that the control console can be raised without hitting the wall.
      Remove the single screw on each end of the control console that secures the control console housing to the top of the dryer. Grab the sides of the control console and raise the front of the console up and toward the rear of the dryer. With the control console in the service position you will now be able to test the timer.
    Test the Timer
    • Locate the dryer timer inside the control console. It will be directly behind the dryer timer control knob. There are two wires that connect from the dryer to the dryer timer. Place a piece of masking tape on each wire and write on the tape what terminal each wire attaches. Use a pair of needle nose pliers to remove the wires from the terminal ends on the timer.
      Set the scale on a volt-ohm meter to the RX1 setting to measure the ohms of the timer. Place one probe to one terminal and the other probe to the remaining terminal. You should get a reading between 2,000 ohms and 3,000 ohms. If you do not get this reading, replace the timer.
    Replacing the Timer
    • Pull the control knob off of the timer shaft on the face of the control console. Remove the two screws that secure the timer to the inside of the control console. Pull the timer out and take the timer with you to an appliance repair facility. Compare the new timer to the old timer to make sure that the mounting screws match.
      Place the new timer inside the console and secure the timer with the two retaining screws. Attach the wires to the timer and remove the masking tape from the wires. Lower the control console and reattach the console to the top of the dryer with the retaining screws. Push the control knob back over the timer shaft. Push the dryer back against the wall and plug the power cord back into the electrical outlet.
May 21, 2011 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool dryer model LEQ8858JQ0 - won't turn off by its self, just runs and runs no matter what cycle it is on.
  1. Access the Timer
    Test the Timer
    Replacing the Timer
Apr 18, 2011 | Whirlpool LEQ8000JQ Electric Dryer
Dries but timer does not turn dryer off.
Malfunctioning Timer...replace your timer.
If your ging to do the job yourself, be sure to get the same mfg of timer that is in your dryer.
Also only disconnect and reconnect one wire at a time.
If you do not get the same timer as came with the dryer you will have to follow the instructions on how to wire the timer,that comes with the timer.
Rate me Please
Oct 03, 2010 | Maytag Neptune MDE4000 Electric Dryer
The dryer wont turn itself off
Is the timer turning?
Actually, doesn't matter, the timer is the component that turns the dryer on and off. If the dryer won't turn off via the timer then the timer is bad!
(I'm assuming, opening the door turns the dryer off.)
Replace the timer to fix.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replaced timer module. Dryer did not run.
Check the voltage across the timer motor, make sure that you have 120 volts. If you have 120 across the timer motor, then it is bad. Also check your wiring to make sure you have wires in right place
May 01, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
