Question about Electrolux Vacuums
How do I take the machine apart to access the wiring? I have an Electrolux Aerus Model #C153A?
While vacuuming the power went out and the power cord icon went off, I live in an old apartment building and the machine had just gone over a large threshold which I believe jarred a connection in the wiring. Have had no problems with the machine previously, so seems likely something just came loose.
Electrolux Epic series 3500 model Upright Vacuum cleaner motor(replace old one)?
I don't know what your question is, but replacing a motor for Electrolux, now Aerus, should be done by an authorized Aerus Electrolux service tech. The uprights are especially tricky to take apart and reassemble correctly. The address and phone number of the Aerus store/service center nearest you can be found at the site below.
http://www.aerushome.com/storelocator/
Mar 13, 2011 | Electrolux Vacuums
I have a electrolux 7000 my cord brok off and it got succked in. igot it apart. I DONY KNOW HOW TO PUT THE COIL SPRING ON THE POWER CORD WHEEL. NEED HELP
This is very difficult to reassemble correctly, and more difficult to explain properly. You need to take the vacuum to the nearest authorized Aerus Electrolux store for reassembly. Or call for free pick up and delivery.
Mar 13, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
I need to change the power cord on my electrolux 2100. how do i open the body to get to it?
Due to problems getting it back together, I don't recommend taking it apart. Dismantling and reassembly the cord winder assembly is also complicated and most people have problems doing so correctly. I strongly suggest taking it to an authorized Aerus Electrolux store and spending the money to have an experienced tech do the job. However, if you do decide to try this yourself, there are instructions on the second site below. The first site is for locating the nearest Aerus Electrolux store.
http://www.howtomendit.com/answers.php?id=2297
Feb 20, 2011 | Electrolux UltraLux 2000 Bagged Canister...
The retractable cord is all the way out and won't go back into the machine! How do we get the machine apart to fix this problem?
You shouldn't have to. Simply tilt the machine to 45 degree angle and gently tug and release the cord. From my own experience, this almost always works. It's possible it's due to a broken part, but not likely.
Also, the vacuum should still be under warranty. If it's disassembled by anyone other than an authorized Aerus Electrolux servich tech, the warranty is voided.
Jan 22, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
My power cord will not retract back into the housing< i would like to open the back of the unit but there no screws or bults to due so. How do you open the back of model c151d
Try standing vacuum on end, then gently tugging and releasing cord. This generally will retract it.
There are many problems that can result in disassembly and reassembly by an untrained person, including shock and fire. For those and other reasons, I don't recommend trying this yourself. Take it to the nearest Aerus Electrolux store for repair.
The back of the vacuum can only be removed by separating the top and bottom portions of the canister. The cord winder will need to be removed and the wires all disconnected. The cordwinder is then taken apart and the cord rewound and set for proper tension for rewinding. If the cord is simply stuck due to having been pulled out too far, this is generally not necessary.
Jan 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
How do i open the housing of an electrolux ambassador model #c101j to fix cord recoil
This can be a complex undertaking, so I highly recommend taking it to the nearest Aerus Electrolux store for repair. I've seen many disassembled machines come in to the shop because the owner couldn't figure out how to put it back together. Any misplaced wires during reassembly can result in nonworking vacuum, shock and even fire hazard.
Taking it to the shop may cost more, but I believe is less expensive in the long run. They'll do it right.
Dec 14, 2010 | Electrolux Lux 5500 Canister Vacuum
I need a new power cord for the power nozzle on my Electrolux 2100 canister vacuum. The power nozzle has part number N115M written on the bottom. I have found the power cord for power nozzles PN6 and PN7...
You can buy the hose at an authorized Aerus Electrolux store. If near enough, they will deliver, if too far, they can ship it. The nearest dealer can be found using the below link. Just follow the instructions.
Just provide the model of the machine. They will know what hose you need.
Dec 12, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 2100
Call your local Aerus Electrolux office. If there is a problem in the electrical system you should get that checked before you continue with the machine. As for the cord replacement- Any Aerus service dept. can do that for you. I say an Aerus office because should you let a non-Electrolux employee work on it you will void your warranty.
Dec 08, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Sep 15, 2007 | Electrolux Lux 5500 Canister Vacuum
Vacuums Logo
169 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
