Question about RupseTM 12V Car Travel Hot Water Heater Pot Car Cup with Tempreture Display Black
Heater will not get hot on the car - RupseTM 12V Car Travel Hot Water Heater Pot Car Cup with Tempreture Display Black
  • 4 Answers
You should probably ask someone that is an expert
Posted on Nov 11, 2014
Mt car blows cold air but not hot i replace the thermostat and added antifreeze but it still no hot air its for a Mitsubishi lancer 2003
there are two hoses than run through the firewall to the heater core. With the car fully warmed up those two hoses should be about the same temp. If one is hot and one is significantly cooler that the heater core is likely plugged. The hoses can be removed and the heater core can be backflushed with a garden hose. do this several times alternating between the inlet and outlet of the heater core. reconnect the hoses and see what happens. Worse case scenerio you'll need to replace the heater core.
Nov 29, 2015 | Mitsubishi Cars & Trucks
Why does the wires to the ignition and heater get very hot when the car is on?
wires get hot through either a bad connection or too much power being drawn through them, as for the heater blowing cold is there any hot water flowing through the heater check the pipes for the heater that pass through the bulk head
Mar 13, 2015 | 1987 Subaru Gl 4WD
2000 chevy silverado not blowing hot air
1: not enough liquid in the system (air in the heater core)
2: inoperative heater valve not allowing hot liquid into the core
3: hot/cold blend door in the heater box stuck on cold
4: clogged heater core
A clogged heater core will have one hot hose and one significantly cooler hose at the firewall connection; easily tested by hand. a good core will have both hoses very hot to the touch when the heater is on full blast.
Make sure that the system is full and at operating temperature, and the heater controls set on full heat. Feel the hoses at the firewall; if they are both too hot to touch then the problem is in the heater box or controls.
Mar 03, 2013 | Cars & Trucks
The heater isn't putting out hot air
check to see if there is plenty of antifreeze in radiator , may have a air bubble in system .
Jan 28, 2013 | 2005 Chevrolet TrailBlazer
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
Why would my heater blow out cool air when sitting still and then hot air when going down the road and then it's not all that hot
Try flushing or blowing high pressure air through the heater core lines. its sludge build up and need to be flushed through heater core only. check antifreeze fluid level. only put in straight antifreeze, do not mix. most people do not know what mixture should be, so be safe and add straight, it will not hurt it, i run 100% straight antifreeze and never had a problem or worry about it ever freezing and cracking my block, heads or radiator cracking.
Jan 29, 2012 | 2001 Daewoo Nubira
Heater blows out cool air only
Could be a stuck thermostat... or low coolant level. feel hoses going to heater core, if only one is hot while car is warmed up. i would say the heater core is plugged because this is where you get the heat for inside of car ! hot coolant goes through heater core and a fan blows it out to heat inside of car. if both are hot then the heater core is ok.
Oct 20, 2011 | 2000 Pontiac Bonneville
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
What if the heater hose going in is hot and the heater hose coming out is cold.the heater will blow cold air
Possibly the heater core is 90% blocked. open enough to draw hot water in, (hose feels hot) but not enough volume to provide heat from very cold air, 10% hot water gets cold quick, coming from core..
Flush heater core in reverse direction - cold side in hot side out..
Just a theory..
Dec 14, 2010 | 2000 Chevrolet Silverado
I have changed the theromast twice and flushed the coolant system.The heater core is not leaking.. the blower is still blowing cool air.
The heater in your car depends upon a flow of hot coolant going through the heater core in order to get hot air into the car. If the heater core is partially plugged, it will restrict the flow. If you have a head gasket that is putting exhaust into the cooling system, it will eventually get into the heater core. When this happens there is no coolant in the heater core to make the air warm. If the water pump vanes have corroded away the result will be very poor coolant circulation causing the heater to not blow hot air. If your car is equipped with a heater control valve that is not functioning properly, the coolant flow will be restricted. One or a combination of these factors is likely the culprit in your case.
if the car is not overheating, the thermostat is working fine.... replace or flush the heater core multiple times to try and eliminate sediment build-up.
Jan 13, 2009 | 2003 Ford Expedition
RupseTM 12V Car Travel Hot Water Heater Pot Car Cup with Tempreture Display Black Logo
43 people viewed this question
Top Rupse Computers & Internet Experts
David Payne
David Payne
Are you a Rupse Computer and Internet Expert? Answer questions, earn points and help others
