Question about Actiontec M1000 Dsl Wifi Modem In Box W/ Inst Quest Centurylink
Where can I get a quest m1000 mnual for a quest m1000 modem
Want manual for a quest m1000 modem
  • 73 Answers
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Posted on Nov 11, 2014
Why is m1000 internet light orange
Because you have limited or no internet connection. Try checking the modem first then the eathernet cable coming from the modem to your router. I actually just had this same problem and it turned out to be a bad cable.
Good luck,
Marty
Jun 21, 2014 | Actiontec Computers & Internet
How do I connect to a qwest dsl m1000 modem
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 20, 2010 | Linksys Wireless-G WRT54G Router
I have not used my M1000 for about 2 years and cannot find my manual
http://www.loadstone-gps.com/docs/gps_manuals/m-1000.txt
Jul 18, 2010 | Orange SPV M1000
The power light on my actiontec m1000 blinks green & red and now my computer can't find the modem. What does the blinking lights mean??
hey
red light on modem usually means modem is in bad state
in this case kindly try to do power cycle
way to power cycle
disconnect all the cables and leave the modem for 30-50secs
then try and connect power cable first
then connect the dsl and then ethernet and see if that resolves the problm,
Sep 18, 2009 | Computers & Internet
Can't print from local printer using remote connection
To print the reports on your local printer, go to
1.Start->Run->
2.Type 'mstsc' and click 'ok'. A window pops up for Remote Desktop Connection
3. Click 'Options' button and select the 'Local Resource' tab.
4. Select the checkbx 'Printers' from the 'Local Device'
5. Click Connect.
Aug 20, 2009 | Actiontec GT701C DSL Modem
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Programing my alpine mrd-m1000
Hello steve1914,
You can download a PDF copy of the manual here. There's no cost for the download from Crutchfield.
Hope this helps.
May 29, 2009 | Alpine MRD-M1000 Car Audio Amplifier
D-link 614+ will not connect with Qwest M1000 modem
Well what everybody really doesnt know is that if Qwest provided you with a modem named Actiontech that modem has the same ip address of router so just change routers ip address to 172.16.0.1 and subnet mask to 255.255.0.0 and the problem should be solved.Im a product specialist for dlink.
Aug 27, 2008 | D-Link AirPlus DI-614+ Wireless Router
NAT from moderate to open (xbox 360)
You need to open ports for that game on your router. Nat can't be disabled, make sure the correct ports are properly forwarded on your router. Contact the game manufacturer for the port listing.
Aug 21, 2008 | Computers & Internet
Programing
http://vault.alpine-usa.com/products/documents/OM%20MRD-M1000.pdf
Don't forget to leave "Problem Solved" feedback
Dec 02, 2007 | Alpine MRD-M1000 Car Audio Amplifier
Actiontec M1000 Dsl Wifi Modem In Box W/ Inst Quest Centurylink Logo
146 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
