Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
the codes for the remote to access a Proscan TV are as follows: 11447, 10047, or 11347. I assume you know how to get into the remotes coding mode, but if you don't Here is how you go about it press setup, then press and hold the TV button until the light flashes then input one of the code sets, then if you get a confirming flash hit the power button if the TV turns off your golden if it didn't repeat the cycle with the next set of numbers I gave you. if after you have tried all three numbers you still can't get the TV to react to the remote you will need to call 1-800-COMCAST and speak to someone on their technical staff.
The standby indicator is flashing a failure code. Make a note of how many times it flashes. You apparently have a major failure and the code may give an indication of where the problem area could be. I recommend calling your local Sony dealer and have someone check it out. If you can speak to a tech, give him the code and it may help him or her. You will want an estimate.
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
