Question about Brother P-Touch 1180 Label Printer
I'm trying to print a label. Message says Text Too High. What is that exactly?
    Master:
  • 876 Answers
You have selected a font size that is too large to fit on the label. Or you have selected multiline with too much data.
Posted on Nov 11, 2014
Toshiba TEC B-472 printing only top half of label
Perform hard reset of electronics and also re install the driver.
Sep 17, 2017 | Toshiba TEC Office Equipment & Supplies
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
When printing incoming hotmail message, the subject line is printed in very large & bold letters
Click on the 'print' icon to display a print compatible version, then print. If the problem still exists, use google chrome to change the html code of the text to manually change text size
Oct 19, 2012 | Microsoft Computers & Internet
Hi I am printing barcode labels on a Zebra Tlp2844-Z. I can print resident barcodes in passthrough mode using the old Zebra driver (1.0.0.43) but the barcode does not print using the ZDesigner driver...
Have you tried creating the barcode / label using the ZDesigner software? It is available free on their website and I'm sure you'll find it easy to use. Hope this helps!
Aug 23, 2011 | Zebra TLP 2844-Z Thermal Label Printer
What does "Text too high"
When you push the print button, "TEXT TOO HIGH!" error message appears on the LCD display, why? Description: This message appears if the size of the text is larger than the width of the installed tape.
Please reduce the character size or install a wider tape.
Aug 12, 2011 | Brother P-Touch 1180 Label Printer
I want to print a label with two lines of print on it. How do I do it?
To create a two-line label 1. Type the text for the first line and press INSERT. 2. Use the arrow keys to select Second Line and press . A multiline symbol is inserted at the end of the first line, but will not print on the label. 3. Type the text for the second line.
Here's the manual, see page 12 - http://www.dymo-label-printers.co.uk/downloads/LetraTAG-LT100H-Manual.pdf
Jul 14, 2011 | Dymo LetraTAG Thermal Label Printer
Error 0x 18a0401
Try link below for specific steps in troubleshooting
An '0x ...' Error Message Displays on the Front Panel When Printing
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=1153494&tmp_track_link=ot_search
Issue The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .' c01733891.gifImportant: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) (in English) to solve this error: Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
  • If your product is in warranty , contact HP.
  • If your product is out of warranty , click here to view additional printer support options starting as low as $20.
Mar 28, 2011 | HP Photosmart C6180 All-In-One InkJet...
P-Touch Label Maker: How to get rid of "Text Too High! 1 Block" error message?
You may get this error after installing new tape which is small in width. If you reduce font size, so it will fit on new tape, the error message goes away and your P-Touch will print your label.
Sep 17, 2010 | Office Equipment & Supplies
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Dec 05, 2007 | HP DeskJet 3940 InkJet Photo Printer
Brother P-Touch 1180 Label Printer Logo
206 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
