Question about Samsung RF217ABPN Bottom Freezer French Door Refrigerator
I recently bought a new rv with a samsung rf217 frig. How do I winterize it? Product lit not clear.
  • Samsung Master
  • 3,904 Answers
You do not need to do anything to the refrigerator. Just make sure it is wiped down and dry before you close it. What you need to do for winterizing is drain all of the water out of the tanks, water heater and lines. After that is done then pour RV antifreeze into your fresh water tank and pump it through all of your faucets. Once you see the pink color come out then you have it through the lines. You should have what is called a bypass valve for your water heater so you don't have to fill it completely with antifreeze. Next is to take out your battery and store it in your basement or somewhere it wont freeze. Do not put it directly on the ground. Put cardboard or something under it.
Posted on Nov 22, 2014
Can you get water in LP lines when filling RV w/ propane? Frig quit on propane,worked on electric. Had filled w/ propane two days earlier. mechanic found oily water in line; range still worked.
Yes water can do compensation build up in your propane tank. Some tanks have a drain pit on bottom reclaim propane and open the pit. If your does reclaim the propane and drain tank. If not reclaim propane and remove tank then remove filler valve turn tank over drain access water leave tank up side down over night. Put fill valve back on and mount tank. After lines are back on turn stove on leave on for 48 hours. Turn valves off and refill tank. Best of luck.
Jun 10, 2016 | RVs
Winterizing
I think you have covered it all. Just last flush !
Jun 24, 2013 | American Standard AMERICAN STD 12 RGH...
Action 1: My RM2652 runs well on auto mode when its indicator's light is lit. Auto mode is an electric mode, right? Action 2: When I press on the "gas" button, the indicator's light next to the "auto"...
Auto mode is electric 1st then gas. If no 110v is available it tries to light the gas. Do you have gas & is it turned on? You should hear a clicking from the back of the frig. Make sure the air is purged out of the system by lighting your range and let the burners come on for 30 sec or so. You might have to cycle the frig on & off a couple of times after you purge the air. Set the button to "gas only".
Apr 01, 2010 | Dometic RM2652 Refrigerator
Need mechanical info. for 2001 Timberland RV.
Regarding "Adventure Mfg, dba Timberland", the some of the execs --namely its founder, started a new RV company called "Riverside Travel Trailer, Inc." and it appears they are still in business. Here are a couple of links. I would think they still would be able to give advice about their "old" RVs.
http://www.rvbusiness.com/tag/adventure-manufacturing-inc/
http://www.rvbusiness.com/tag/riverside-travel-trailers-inc/
Oct 26, 2009 | Sport & Outdoor - Others
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Samsung RF217ABPN Bottom Freezer French Door Refrigerator Logo
85 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
