Temperature the burner shuts off but the ventillation does not stop. I was told the Oil Primary Control R8184G1393 is defective would this be correct?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
It could be a bad circuit board but you would have to verify before replacing .
Posted on Nov 30, 2014
Why does my waste oil heater burner shut off after about 15-20 seconds of running?
Depends on if you have to manually reset the primary controller. You may have a bad CAD cell, primary controller, backdraft of exhaust, or high temperature limit tripping due to overheating from either a loose belt, bad blower motor or capacitor. If there is a fuel filter, that may also be somewhat stopped up.
Feb 12, 2015 | Heating & Cooling
Tip
Caterpillar Fault Codes
CID code Name
1 Injector? 1
2 Injector, cylinder number 2
3 Injector number 3
4 Injector number 4
5 Injector, cylinder number 5
6 Injector, cylinder number 6
7 Injector number 7
8 Injector number 8
9 Injector number 9
10 Injector number 10
11 Injector number 11
12 Injector number 12
13 Injector number 13
14 Injector number 14
15 Injector number 15
16 Injector number 16
17 The fuel shut-off valve
18 The fuel control valve
19 Bypass valve accelerator
20 Device change timing of fuel injection
21 Position Sensor Engine
22 Sensor fuel injection advance
23 Drive Racks
24 position sensor rail
27 is a variable geometry turbocharger number 1
28 Drive with variable geometry turbocharger number 2
41 Power ECU (electronic control unit) 8 V DC
42 Valve inclusion nozzles
70 contact with the parking sensor
71 Timer stop idling
75 Oil temperature sensor circuit hydraulic steering system
The pressure sensor 81 at the inlet trap foreign particles
82 Pressure Sensor pnevmozapuska
84 speed sensor
91 Accelerator pedal position sensor
94 Pressure Sensor fuel pumping
95 The differential pressure sensor on the fuel filter
96 Fuel level sensor
98 Oil level sensor in the engine
99 The differential pressure sensor on the engine oil filter
100 Oil Pressure Switch Engine
101 pressure sensor crankcase gases
102 turbo pressure sensor
104 Oil pressure turbocharger
105 temperature sensor intake manifold
106 sensor input air pressure
Pressure sensor 109 of coolant downstream of the engine
110 Coolant Temperature Sensor Engine
111 level sensor, engine coolant
The differential pressure sensor 112 to filter engine coolant
124 gearbox oil level
126 differential pressure sensor on the oil filter transmission
127 Oil Pressure Switch gearbox
138 Mode Switch low traction
139 Solenoid tip ago
140 Solenoid tip forward
141 Eco Mode Switch
142 position sensor door to clean the radiator
143 contact pressure sensor control unit neutral
144 horn relay reverse
145 power supply circuit 12
146 Mode Switch hitch
147 pressure sensor lock-up clutch
148 pressure sensor in the hydraulic stroke
149 Three-way solenoid stabilization system of the implement when driving
150 Speed Sensor trambovatelya
151 Solenoid trambovatelya
152 diagnostic lamp control systems course
153 speed sensor right drive motor
154 RPM Sensor left actuator motor
155 solenoid switching stroke
156 Solenoid right turn in reverse (electronic display)
157 Solenoid left turn in reverse (electronic display)
158 Solenoid right turn forward direction (electronic display)
159 Solenoid left turn forward direction (electronic display)
160 Relay working equipment paver
161 brake sensor (chassis) pedal
162 Sensor Steering Wheel
The steering angle sensor 163 rotation
164 Pressure Sensor inclusion nozzles
167 Sensor charging voltage of the alternator
168 Electric system
171 of the ambient air temperature sensor
172 temperature sensor in the intake manifold
174 Fuel temperature sensor
175 Temperature Sensor Engine oil
177 oil temperature sensor Gearbox
190 RPM Sensor engine crankshaft
191 sensor output speed gearbox
248 data channel of Caterpillar
249 data channel J1922 SAE (Society of Automotive Engineers)
250 data channel J1708 / J1587 SAE (Society of Automotive Engineers)
Block 252 calibration
253 Personal chip control unit
254 electronic control unit
256 Map adjusting engine performance
257 Level detonation
258 sensor crank angle
259 set via software point fuel injection
260 oxygen sensor in the exhaust gas
261 the fuel injection timing calibration
262 circuit sensor supply 5 V
The power circuit 263 digital sensors (8 or 12)
264 pedal revolutions reduction
265 Input circuit stopping the engine, user-defined
266 Input circuit dry scroll engine (without fuel injection)
267 Chain input remote control signal Safe Stop engine
268 Error programmed parameter
269 circuit sensor supply
Code 270 cable computerized monitoring system (CMS)
271 Sound the alarm
272 sensor has exceeded the allowable turbo
273 pressure sensor at the outlet of the turbocharger
274 atmospheric pressure sensor
275 pressure sensor at the entrance of the right turbocharger
Pressure transducer 276 at the input of the left turbocharger
277 sensor calibration injection timing
278 The indicator light turn on the automatic control of engine speed (AESC)
279 coolant temperature in the intercooler front section
280 temperature sensor gear
281 The indicator light necessary Engine
282 Light indicator exceeding the permissible engine speed
283 Indicator Light air filter
284 Radio on EMS (electronic control system) (the signal of the engine)
285 overheating indicator light, engine coolant
286 Indicator light low oil pressure
287 Miniature digital output? 7
288 Miniature digital output? 8
289 Fuel pressure - before the fuel filter
290 pressure sensor in the pump drive engine cooling fan
The solenoid 291 engine cooling fan
292 solenoid hydraulic oil cooling fan
293 power analog output? 3
294 power analog output? 4
The control unit 295 hydraulic excavator heavy-duty
296 gearbox control unit
297 all-wheel drive system control
298 The probe brake pedal
299 position sensor gear lever
300 The primary windings of ignition coils
301 The primary winding of the ignition coil? 1
302 The primary winding of the ignition coil? 2
303 The primary winding of the ignition coil? 3
304 The primary winding of the ignition coil? 4
305 The primary winding of the ignition coil? 5
306 The primary winding of the ignition coil? 6
307 The primary winding of the ignition coil? 7
308 The primary winding of the ignition coil? 8
309 The primary winding of the ignition coil? 9
310 The primary winding of the ignition coil? 10
311 The primary winding of the ignition coil? 11
312 The primary winding of the ignition coil? 12
313 The primary winding of the ignition coil? 13
314 The primary winding of the ignition coil? 14
315 The primary winding of the ignition coil? 15
316 The primary winding of the ignition coil? 16
317 load cell
318 Right knock sensor
319 Left knock sensor
320 RPM Sensor / injection timing
321 Key switch reset / diagnostic confirmation
322 engine stop switch
323 The indicator light engine stop
324 Alarm lamp
325 detonation caused by the ignition system
Detonation System 326
327 Wrong number of knock sensors
328 Wrong number of cylinders of the engine
329 Error Link
330 Login with contact sensor propane content
331 Ignition Switch
332 keyboard switch
333 switch alarm
334 Reserve output
335 solenoid screw scraper
336 switch engine control
337 Remote Switch emergency stop
338 Relay pre-lube pump motor
339 contact pressure transducer pre-lube the engine
340 solenoid shut-off air
The solenoid 341? 4 warm-hydraulic distributor
342 Auxiliary speed sensor engine crankshaft
343 injector NOx catalyst in the exhaust gas
344 Relay injection pump converter of nitrogen oxides in exhaust gases
Pressure sensor 345 of the injection NOx catalyst in the exhaust gas
346 Relay stabilization system of the implement when driving
347 solenoid feed control (working volume) motor hydrostatic transmission
348 lock switch gearbox
Solenoid 349 gearbox synchronization
350 position sensor rod lift
351 position sensor rod misalignment
352 Sensor lift lever (in the cockpit)
353 sensor lever skew (in the cockpit)
The solenoid 354? 1 lift
The solenoid 355? 1 lowering
The solenoid 356? 1 unloading
357 Solenoid No. 1 return
358 Drive pressurization of the control loop hydraulic system work equipment
359 solenoid locking lifting
360 solenoid lock lowering
The electromagnet 361 tilt lock to download
362 solenoid control the fan speed of the engine
363 Drive stabilization system of the implement when driving
364 pressure sensor piston cavity lift cylinder
365 switch for limiter
366 contact gauge semiautomatic recess
367 Switch stabilization system of the implement when driving
368 switch, automatic / manual mode transmission
369 Login with shift indicator on the gearbox
370 Solenoid floating position arrows
Solenoid 371 beep
372 solenoid opening bucket (for excavator shovel)
373 solenoid closing bucket trucks through the hinged bottom (for excavator shovel)
374 Solenoid swing brake
375 Solenoid swing brake
376 Warning stroke
377-way solenoid brake
378 solenoid automatic lubrication system of the machine
379 Pressure Sensor automatic machine lubrication
380 contact pressure transducer modulation shift gearbox
381 Contact neutral position sensor lift lever (in the cockpit)
382 lever position sensor coupling
383 position sensor coupling
384 shifter
385 contact sensor neutral position tilt (in the cockpit)
386 solenoid lifting hitch
387 Solenoid lowering hitch
388 Contact line solenoid coupling
389 The probe neutral auxiliary lever
The solenoid 390 controlling the flow of hydraulic oil through the forward clutch
The solenoid 391 controlling the flow of hydraulic oil through the reversing
392 solenoid oil supply
The solenoid 393 to drive the front wheels
The solenoid 394 controlling the flow of oil through the drive motor
395 solenoid switch actuator pressure of the front wheel
396 Light on lamp-wheel drive (AWD)
397 contact pressure transducer feed pump
398 pressure sensor in the front wheel drive
399 sensor to the control lever-wheel drive (AWD)
400 The secondary windings of ignition coils
More Fault Codes HERE Caterpillar DTC
on Dec 20, 2016 | Cars & Trucks
Hello, I have a oil fired hot water heater, the motor comes on for about 30 seconds, and then stops running, I have oil and a flame, what do you think, thank you ,,,Greg
It sounds to me like it could be one of three things....
1. You have a poor quality flame. This could be caused by a dirty nozzle, or a lack or air. Ensure that the airband on the oil burner is not all plugged up with dust, lint, pet hair, etc..
2. You have a defective or dirty Cad Cell Eye/Assy. To check this you will need to turn the power to the water heater off. Loosen or remove the screws that hold the ignition transformer down to the burner. The transformer is hinged and should now swing open for you. With the transformer swung open you should see the cad cell assy. It is a round object most likely mounted on the transformer itself, in between the high voltage leads/contact. The eye itself will pull out of the assy. Use a clean cloth and wipe down the eye. Reseat into the socket and resecure the transformer. Turn power back on and test.
3. Bad Primary Control This would be the most costly of the problems, and would mean your control, located on the side of the burner needs to be replaced.
The final testing will require the use of an ohmmeter. Disconnect the two wires located on the side of the primary control, designated "FF".
These are most likely going to be yellow in color. Connect one wire to each side of the ohmmeter and turn the unit on. Your ohm reading will tell you the "strength" of the flame. The lower the number the better!
0-400 ohms is ideal; 400-800 is okay, anything above 1000 ohms means you need to replace the cad cell. Note: While perfoming this test place a jumper wire across the open "FF" teminals after the burner has fired up. (If done before the unit will not turn on). If the system shuts off on safety while perfoming your test (as long as you let it run over the 30 sec.) then you will know you have a bad primary control.
Hope this helps
Mar 02, 2012 | Heating & Cooling
We have a Bradford White Hydrojet Gas Water Heater. Model# MITW5016CX12. The blower comes on and stays on and the the igniter flame does not light. We are afraid that the blower will get too hot when we...
here's what Bradford White lists....
Burner Will Not Ignite
REASON REMEDY Excess primary air Adjust air shutter to reduce air supply -- if supplied No gas Check with utility Dirt in main burner orifice Clean orifice -- check for source of dirt and eliminate Dirt in gas lines Notify utility -- install dirt trap in gas line Venturi clogged Clean -- check for source of trouble and correct Pilot line clogged Clean -- check for source of trouble and correct Main burner line clogged Clean -- check for source of trouble and correct Defective thermocouple lead Replace with new thermocouple lead Defective thermostat Replace Defective magnetic valve Replace entire control Thermostat set too low Turn temperature knob to desired temperature Heater installed in confined space Provide ventilation by use of louvers in wall or door time for a service tech.
Mar 05, 2018 | Fasco Bradford White Hot Water Heater...
My oil burner trips the m.c.b, what is the cause?
Commonly Reported HVAC Problems: [Copyright © 1996-2011. Hannabery HVAC. All rights reserved.]That would be the little red button on the box at the oil burner itself. If your oil burner stops running the first thing you should check is the reset button. If you press it and the burner fires up then that was the problem. If the button should trip again then there is a definite problem and you should schedule a service call immediately. Do not keep resetting the button and ignoring the problem. afg-redbut.jpg Now, what is this button and why does it trip? It is a safety device. It shuts the burner down when it thinks there is a problem. It is on the primary control and is hooked-up to a cad cell. A light sensor. (The same thing that turns outside lights on at dusk.)
On a call for heat, with the burner running, the cad cell senses the light of the flame. If it stops sensing the light of the flame, it causes the red button to trip, shutting down the burner before any significant damage is done. Next question. Why would the sensor stop sensing light while the burner is running? Many reasons. Almost all of which require a service call. Below is a list of possible causes and things to check. Items in blue usually require a service call. Items in red however can be addressed, even fixed by the homeowner.
  • Faulty or dirty cad cell
  • Faulty primary control
  • Bad or weak ignition transformer
  • Bad burner motor
  • Bad fuel pump
  • Blocked oil filter, strainer or nozzle
  • Delayed oil valve not opening (some units)
  • Cracked electrodes
  • Improperly set electrodes
  • Air in fuel line
  • Burner running with a very high smoke
  • Burner sooted-up
  • Loose electrical connections
  • Damaged flexible coupling
  • Water in oil tank
  • Out of oil - Have your tank filled
  • Chimney blocked - Have it cleaned
  • Closed oil valve - Open valve
  • Air, Pump not primed - Prime pump - may need to call for service
Smart Filters
The bottom causes in red are common problems and can be addressed by the homeowner. Try to check for these conditions first before calling for service. Hope this helps, remember - these are just rough guidelines and not all possible situations are covered.
I found this article on the Web So I can't take credit for it..... But it is a very good place to start for your problem It is what I would start checking if you called me for service .......Good Luck
May 02, 2011 | Heating & Cooling
My oil burner blows smoke when it kicks on, then after 3 times it shuts down smoke test is good, new nozzle what else can i check?
There should be an air adjustment collar on the oil pump side of the burner. Give it a bit more air. Have you replaced the oil filter and oil pump strainer? Flip open the transformer on the top of the oil burner and look for a small black round cylinder. This is your Cad cell eye. Take a paper towel and polish the end that looks down the burner tube. You did not mention how long the unit fires prior to shutting down, could be a bad primary control.
Dec 23, 2009 | Heating & Cooling
Gas flow
Your regulater connected on tank has a shut down safety inside of it. disconnect tank hookup, then reconnect, always open tank valve slowely when you open to fast regulator thinks there is a leak and starts shutting down valve to slow leak. Opening slowely will solve your problem.
Aug 17, 2009 | Weber Genesis Silver B Grill
Boiler makes twitching sound and doenst stay on
If the boiler uses oil (#2 fuel diesel); there are several factors that could cause this problem:
* Lack of oil due to clogged oil filter or restricted oil line.
* Cad resistance greater than 1500 ohms.
* Defective Primary control.
* Shoot accumulated on the retention head.
* En pinching flame in combustion chamber.
* Collapsed combustion chamber into firing range.
* There are other reason not listed here.
* Some problems require expensive testing equipment to make an accurate diagnosis.
* Get in touch with an oil burner technician with several years of experience. I have a license to practice in the state of Massachusetts. My number is 978-5443783
Mar 05, 2009 | Water Heaters
Pilot light
Assuming that your make up air and exhaust hood are properly balanced, no negetive pressure conditions exist, your gas manifold pressure is at 4" wc, your air/gas mix on the burner set correctly, the your problem would be the pilot adjustment. If the flame is not intense enough flame to survive the sudden air shock, it will go out.
The pilot height should be about 1 1/2". Your Pilot orfice could also need cleaning. Eliminate excessive draft in your kitchen.
Here is the manual for your unit, it covers these topics.
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5355.pdf
Jan 24, 2009 | Frymaster Dean H17-SC Deep Fryer
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
