My Honeywell R8184G1393 is defective and I am replacing it with a Honeywell R7284.
I have looked at the manuals for both models but I would like to know exactly what wire from the new unit connects to which wires of the old.
  • 205 Answers
SOURCE: wiring on thermostat tl7235a1003
OK, here's my guess at this...I hope someone more knowledgable will confirm or correct me.
A line voltage thermostat switches the power to the baseboard heater. In other words, it's just like a wall light switch except it activates and deactivates based on the temperature.
I think your old model CT62 was wired exactly like a light switch. The hot wire to the light is broken then run to the wall switch and then back to the light so there's no neutral wire at a light switch box. This worked fine for your CT62 because it did not need power, it only needed to switch it.
The new model TL7235A1003 requires electrical power because it's programmable so you need both a hot wire and neutral wire at it's installed location. In addition you also need 2 wires leading to the baseboard heater so the thermostat can supply it's power.
I believe L1-L2 are to be connected to the hot/neutral wires, and the Load wires go to the baseboard heater.
If I am correct you will not be able to use this thermostat without some re-wiring.
Good luck.
Posted on Nov 27, 2007
chillmaster
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
koolbreezes
  • 540 Answers
SOURCE: I want to replace the old mercury termostat with
R--red comming n the thermostat and white is heat going to the furnace!
Posted on Dec 21, 2009
bobicehouse
  • 1524 Answers
SOURCE: I'm installing a Honeywell RTH6350D
One to R terminal the other to W terminal
Posted on Nov 04, 2010
  • 330 Answers
SOURCE: I just bought a Honeywell
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Posted on Dec 11, 2010
Tip
Manual Honeywell How to Find Honeywell Manuals
Finding the manual for Honeywell products can be a very frustrating experience if you do not know where to look. I will try to give information here as to exactly how you can easily find the manual you are looking for.
Doing a generic search for the specific Honeywell manual that you want becomes very frustrating and time consuming. So here is what you need to do to get to the Honeywell instruction or installation manual that you need quickly.
Type into your browser www.customer.honeywell.com
When that page opens up look down on the bottom right hand side of the page
And you will see Literature/Image search.
Type into that box the model number of the product you are working with.
Hit the little red arrow and.....
A list of .pdf files will come up and you can choose the one that you want to download from there.
Now you have what you wanted quickly and very simply!
Honeywell manuals, installation instructions, etc.. can be at you finger tips in a few clicks IF you know where to look.
on Jan 15, 2010 | Heating & Cooling
I need an owner's manual for Honeywell Air Purifier HHT-082-TGT and cannot find it on the Honeywell Instruction Manual website
Hello, this is Ava with Think Crucial.
You may find you online instructional manual for your Honeywell model by clicking the link below.
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/hht080hht100.html
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 12, 2015 | Honeywell Pet Cleanair Air Purifier...
My Honeywell thermostat keeps flashing the battery icon even after I changed the batteries. It will not kick on my heater why?
The replacement batteries may have been installed incorrectly or the replacement batteries may be defective
Feb 07, 2013 | Honeywell Rth110b Horizontal Digital...
Honeywell R7284 lockout
cant get ignition has lock out mode 35 times what do i do it,s electronic 1 year old
Feb 06, 2013 | Heating & Cooling
Looking for an owners manual for a digital programmable Honeywell thermostat-model CT3455A4443
you can get that online at honeywell,local hvac supply houses, and by calling the 800 # that should be online and in your stat please rate my comment and give me a vote I just started this
Sep 15, 2010 | Honeywell Heating & Cooling
Instruction manual for Honeywell air purifier 17352
Please refer to the link below for the Honeywell model series 17000 online manual:
Honeywell 17000S Owner Manual
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Jun 25, 2010 | Honeywell 17352 Quiet Care Programmable...
I am renting a townhome and cannot reprogram the thermostat. It is a Honeywell Magic Stat Model #97-4730 Rev. A. I looked on line and could not locate this number.
That is actually not the model number. That's some sort of a code on the flip-up panel with the programming instructions, right? You have to remove the thermostat from the plate that holds it to the wall and look on the back to find the actual model number. Yours is probably model CT3200. If so here is a link to the owner's manual on the Honeywell web site:
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0653.pdf
Sep 27, 2009 | Heating & Cooling
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
