Question about Hitachi 70VS810 70" Rear Projection HDTV
Hello, I have a Hitachi 70VS810 that just started going out. I'll be watching TV and the picture will fade away, go out without sound too. The power button blinks fast the whole time its out. It stays out for 30-50 seconds and comes back on. It works as it should for about 10 minutes and goes out again and keeps repeating. Only once did it go out and the temp light came on. I have checked all 3 fans and they all are working. I took the lower back panel off and had a standup fan blowing across the whole electronics. It it were a temp problem, it shouldnt have gone out with that fan blowing. But it did. I dont know what to check next. I thought about disconnecting the temp sensor to see if it stays on but I cant find it. When I search, the results come up for the 50inch. What it shows in the picture for the 50"(a yellow wire)isnt like the inside of mine.
    Sergeant:
  • 295 Answers
This is more likely to be an issue with your power supply not being able to supply the correct voltage to a certain board all the time. Most likely bad/aging capacitors. You could probably find a new repalcement power supply board on line. Check with Shop Jimmy, they may have one fairly cheep.
Posted on Nov 13, 2014
Sony KPR-53EXR15 pictures fades in and out
Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
Mar 31, 2017 | Televison & Video
The power is on , no pictures or sound. Blank screen.
sounds like a bad lamp most lamps are rated at 2000 hours hope this helps ya
Apr 14, 2010 | Hitachi 70VS810 70" Rear Projection HDTV
I have a Hitachi 70 inch lcd rear projection tv (70vs810). When the tv is turned back on the screen is very blurry. We have had a problem with it over the past 6 months but it would go away after warming...
This is a well described problem with model #. Thanks for that. Now it could be a tv lamp at the end of its life if the tv lamp is around two years old. Its easy to change lamps and the procedure is explained in owner's manual. If the lamp was replaced recently or the problem stays even after changing the tv lamp, its the optical block going bad. That need professional help and you should not try to mess with it. Check out at www.fixurtvs.com These repairs could be expensive and may be wiser to go in for another TV.
Feb 26, 2010 | Hitachi 70VS810 70" Rear Projection HDTV
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
I recently moved and when I powered up my Hitachi model 70vs810 the temp light is flashing and the tv won't light up
it sounds like theres something wrong with your tvs air filter.
my advice is to take it to the store you got it from and ask them if theres anything they can do
they should be able to clean
i really wouldnt sujust trying to get it out your self it can be tricky putting back togther
Nov 09, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
My TV has good sound but no picture. Recently the picture has faded away after 30 minutes of watching.
dirty CRT socket or leaked capacitor or disoldered resistors .You need to see a qualified technician.
Oct 09, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Large black box keeps covering 80% of the screen
i have the same problem, when i turn the volume knob on hitachi remote it goes away. Anyone heard of thi s???
Aug 30, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Please help need to watch tv
Well this gives you someplace to start!
Symptom: NO POWER
Cause: DEFECTIVE I912
Symptom: SHUTDOWN
Cause: Q777,I901
Symptom: SHUTDOWN
Cause: E994,D724
Symptom: SHUTDOWN
Cause: DEFECTIVE I401
Symptom: SHUTDOWN
Cause: DEFECTIVE I601
Symptom: SHUTDOWN
Cause: DEFECTIVE C715
Symptom: SHUTDOWN/OPEN E995,E996
Cause: DEFECTIVE T702
Jan 29, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Open Questions:
See all Hitachi 70VS810 70" Rear Projection HDTV Questions
Hitachi 70VS810 70" Rear Projection HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
