Question about Panasonic Microwave Ovens
Is a banging sound from the microwave when it is working dangerous; it is not the turntable an it is from inside ; the sound is intermittent
  • 21 Answers
I still think its the glass turn table mine does it too its ok not danger
Posted on Nov 11, 2014
Testimonial: "I had a spare turntable from my previous microwave (also a Panasonic that lasted 10+ years) and I tried this one after receiving your post; there are no banging noises now; thank you!!!"
MicrowaveSvc
  • 9047 Answers
SOURCE: Problem with Maytag MMV5000BDB Microwave
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: OTR microwave turntable won't rotate
If not, please post your brand and model.
It's probably the motor, but possibly the coupler.
One quick check is to remove the turntable and support / roller ring and try to turn the coupler. It should be a little hard to get started, then you should hear a whirring sound, not a clicking or grinding, which would indicate a bad motor.
If the coupler turns loosely with no resistance, then it's probably bad.
Here is my text on replacing couplers, which had steps which are necessary when replacing motors. Note that if yours is a built-in model, ignore the part about turning it on its side *grin*
NOTES ON REPLACING TURNTABLE COUPLERS
Copyright 2007 by William E. Miller - MicrowaveDisplay.com
UNPLUG THE OVEN FROM THE WALL FIRST OR YOU WILL EXPOSE YOURSELF TO LETHAL VOLTAGES!
Note that I am not encouraging you to work on electrical items if you are not qualified, and I assume no liability for any consequences of your decision to do so.
When replacing the turntable coupler on most models, it is necessary to loosen or remove the screws that mount the turntable motor to the bottom of the chassis.
It is usually easier to do this with the microwave oven on its right (heaviest) side because you will need two hands for alignment.
Be sure to put a towel or similar cushion on the work surface to avoid scratching the oven wrapper (oven cover) or the work surface.
It is not necessary to remove the wrapper or the wires from the turntable motor itself, but you may need to remove a small metal duct covering the turntable motor if your oven has one.
It should only be held on by one or two screws.
Although a broken coupler may come out easily or even fall out, the new coupler will not go in without at least loosening the turntable motor.
Look at the hole in the new coupler. You'll notice it has (most do have) a flat side to it. That flat side will line up with the flat side on the motor shaft.
When the old coupler is out and the motor is loose, you can ease the new coupler in the hole with one hand while turning the coupler very slightly back and forth as you gently push the motor toward it. Do not force the part in.
When the coupler has mated properly with the motor, you should feel it go in.
Be sure it's right, or you may break the new coupler or bend the mounting ears of the motor when you attempt to tighten the screws.
Reassemble in reverse order.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
SOURCE: Goldstar MV 1501BQ microwave
Thanks for the reply but my old microwave is resting peacefully in the dumpster. I think the ultimate problem was that Gold Star or LG, as its called now is junk.
Posted on Jun 29, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: JVM2070SH01 shut off intermittently. Now it just won't heat at all.
It's almost certain that your magnetron has failed.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Jul 05, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Goldstar Microwave turntable does not work.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can also do that to attach AC voltmeter leads to the leads of the motor. Then run the microwave to see if it has voltage present.
If so, you have a bad motor.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
You'll probably have to call them to find parts for your model.
(If yours is not an LG/Goldstar, please reply back with your brand and model number so we can help you)
If you don;t see the voltage, then you most likely have a problem with the control panel.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 13, 2008
My microwave turntable stopped turning but the microwave still heats up and works, otherwise.
You didn't say what model microwave you have, but most that I have seen have two separate circuits inside. One operates the magnetron (which makes the microwaves) and the other operates the other things like the turntable or the inside light etc.. It is quite possible that you have a problem in that second circuit. This allows the heating without the turning. To fix this type of problem, if indeed that is the case, requires some skillful trouble shooting inside the microwave which I don't recommend your try unless you are a skilled technician, because of dangerous voltages. Go ahead and post the brand and model number and I can be more specific as to what action to take.
Dec 24, 2015 | Microwave Ovens
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
Panasonic NN-A755
It does sound like the magnetron is failing, when it shuts down it is because the thermal fuse is detecting to much heat from the magnetron and shutting it down, I might add this part is the heart of the system, rough cost would be in the area of $100.00 maybe cheaper. Intallation of this part is very tricky and there is the danger of high voltage, I recommend a pro for safety and correct installation.
Apr 12, 2012 | Panasonic Microwave Ovens
Replace mircowave turntable motor
The replacement of the turntable motor is a tricky repair, and there are lethal voltages present. I highly recommend a professional because of the degree of difficulty and the present dangers inside the item.
Mar 09, 2012 | Panasonic NN-SN657S Microwave Oven
Turntable stopped working. What should I do?
The turntable motor has become defective and must be replaced, since high voltage is a danger, I recommend a suitable professional for the job and because it is a tricky repair.
Jun 20, 2011 | Magic Chef CHEF9 Microwave Oven
Turntable has ceased to function when oven is on. Is it dangerous to use like this?
Not dangerous, but your food will not be efficiently or evenly heated. To change the motor do the following:-
There is a panel under the microwave, held on by one or more screws. Remove it and you will see the synchronous motor inside. There should be a plug to disconnect the wires. Remove the motor and fit a new one. Ensure that the microwave is disconnected from the wall outlet before attempting any work on it.
Feb 16, 2011 | DeLonghi Microwave Ovens
Turntable stopped turning
Some microwaves have a button on the control panel that disables the turntable. Make sure that this button hasn't been pressed.
Next most likely causes are a the stirring (turntable) motor has malfunctioned or possibly a turntable belt is broken or slipping (if equipped). This will involve opening up your microwave (and probably removing it from the wall), diagnosing the problem, ordering the parts, then replacing them.
Remember, while you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, let me know and I will point you in the direction of some good resources.
Oct 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable turns intermittently so unit will not operate
The turntable fan and light all share the same feed, first check wiring for loose connections the problem though is most likely with the controller
Dec 28, 2009 | Viking DMOC205SS Microwave Oven
My microwave oven has are rust spots;can I paint over them?
Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
May 03, 2009 | Microwave Ovens
Microwave does'nt heat up everything else works,just don't heat up
WHAT IS WRONG WITH YOUR MICROWAVE?
small_6_37.jpg For a detailed Microwave illustration, click below.
redarrow.gif Counter top
redarrow.gif Built in
Danger! You can receive a serious electrical shock from the components inside your microwave oven--even when it's unplugged. Only a qualified appliance repair technician should perform any repair.
It doesn't work at all
It sounds normal, but there's no heat
I can't adjust the power level
The carousel won't turn
I have intermittent cooking problems
The display flickers
There's no heat, but it buzzes loudly
It quit after I slammed the door
It looks like there's lightning (arcing) inside my microwave
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Panasonic NN-S541 Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
