Question about Garden
MY HOMELITE RANGER CHAINSAW UT10532 PRIMER BULB NOW AL OF A SUDDEN PUSHES IN BUT DOES NOT COME OUT NOW---REPLACED PRIMER BULB--STILL DOES THE SAME THING
  • 1,169 Answers
If hadn't changed the fuel lines prior to this problem it is probably the internal filter screen in the carburetor plugged or the tank's fuel filter.
If you had replaced the fuel lines then it is probably the plumbing of the fuel lines. The primer is suppose to suck through the carburetor and return the excess fuel back to the fuel tank. It fuel system plumbed backwards, which can be done several ways, the carburetor internal check valve will prevent proper operation of both itself and the primer.
Posted on Nov 11, 2014
  • 7 Answers
SOURCE: how do I replace the primer bulb on a Homelite
Most of them snap in, meaning there are two small blades that are cast into the plastic for the primer bulb housing. These tabs fit into a recess and lock when pushed in from the outside. You will need the entire replacement as you cannot just replace the bulb like is possible on a Zama or Walbro carb. Whatever you do, make sure you mark the routing of the hoses. Its always fun to get them hoses mixed up and then wonder how theyre supposed to route...
Posted on Aug 31, 2009
Testimonial: "thanks for the advice, very helpful! "
dontbother10
  • 2220 Answers
SOURCE: Primer bulb-carb routing
It should be like this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 10, 2010
keyway
  • 7 Answers
SOURCE: i have a Homelite Pro 4620c chainsaw. the primer
take nipple assembly apart clean thougholy with engine degreaser or simular product then seal onthe inside with rtc silocone sealer l
Posted on May 26, 2010
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
SOURCE: Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Posted on Jul 02, 2011
Is the primer bulb replacable on 200 classic chainsaw.or do I have to buy a new gas cap.
Hi Shirley:
My apologies if I'm incorrect, but I've never seen a chainsaw that had the primer bulb connected to the gas cap.
So,,,,,
I'm hoping you're asking two questions at the same time.
1) Primer bulbs are replaceable but it's extremely rare that it is necessary
2) Gas caps are replaceable but only needs to be done if they are broken.
If you reply as a comment on this post I'll be able to respond to you.
Cheers.
Oct 14, 2015 | Homelite Garden
Primer bulb tightens
Sounds like it is filling with fuel...a good thing
May 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
Sep 01, 2011 | Homelite Consumer Products MightyLite...
Homelite chainsaw gas line diagram witch one goes where have the primer bulb
Take the primer bulb off.Look on the back side of it.Most will say tank and carb.If not try putting them on if the bulb doesen't get gas in it.Change them around.
Feb 27, 2011 | Homelite ZR10926 16" Chain Saw
My chainsaw (Homelite UT10514) will not prime fuel. I have changed the primer bulb and checked the fuel lines for damage, they seem to be in good shape.
You need to make sure the lines are connected properly to the bulb. Also, if the carburetor diaphragms are not working properly the carburetor will not prime.
Feb 12, 2011 | Homelite Garden
Walbro WT891 carb on a Craftsman chainsaw. Carb is brand new, all fuel lines and fule filter replaced. I prime the carb with the little plunger, chainsaw starts up and runs out of fuel within 30 seconds....
Who connected these hoses? the normal routing for a machine with a primer is like this, the fuel hose from the tank with the filter on the end goes to the carb fuel inlet nozzel ( not to the primer ) nearest to the pump cover ( cover on carb held with one screw ) the pipe from the metering side of the carb connects to the shorter nozzel on the primer bulb ( suction side ), the longer nozzel on the primer ( pressure side ) connects to the pipe going back to the tank, just remember the primer pulls fuel from the carb,into the bulb, and pushes it back into the tank, it is not actually a primer it is a purge. because it is connected this way it is impossible to flood the engine no matter how many times the bulb is pressed.
Let me know if it starts and runs.
Jan 31, 2011 | Poulan Garden
How to replace the fuel primer bulb and fuel lines in McCulloch 3516 chainsaw? the fuel primer bulb broke and the plastic lines have crumbled. i need to know how to run the lines from the fuel tank to...
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Dec 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Jun 24, 2009 | Garden
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
